03-22-2010, 12:13 | #1 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | confused about unlocking step I have an V630 CID 52, and want to unlock it, in usualy I check : 1) Signed mode 2) En alternative bybass 3) En preloader, and unlock/ repair button, when the process is finished, I stop it with STOP button, run Executor and chek only : 3) En preloader, so now when I have the message : press STOP if process not continue in 15 secondes, the software can't continue, maybe have a probleme when I remove the battery after runing Executor, I have the same probleme with COM port or USB cable, and after this I flash the phone again for reviver it, Best Regards, JAVA Good. |
03-22-2010, 12:25 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | Hi Flash phone repeat procedure if same..then ...Execute reset procedure..simple will be unlocked and well working |
The Following User Says Thank You to BackOFF For This Useful Post: |
03-22-2010, 13:18 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | In the newest exe i Found same error sometimes(but not always) What i use to do is ,i use 62 for unlocking purposes and v1.0 for reset procedure. Hope it helps, Bye |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
03-22-2010, 13:26 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: punjab india
Member: 330468 Status: Offline Sonork: 100.1587596 Thanks Meter: 121 | Quote:
The Following User Says Thank You to sandeephanda78 For This Useful Post: |
03-22-2010, 13:56 | #6 (permalink) |
Member: 66136 Status: Offline Thanks Meter: 200 | @Umair Rashid tks for the reply, I use the v 0.xxxx45 and work good, @sandeephanda78 tks for your reply, I test this with the latest version v1.01 before you help me and don't work, but the probleme is on version, but nice information, this work on all CID 52 or only on some familly of SE phone ? about A2 I know need only ckeck the 1 and 2 option, Best Regards, JAVA Good. |
03-22-2010, 14:16 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | for db2020 cid 52 you can use old methode unlock 1)-use old version of setool 2)-chose your main+fs cid52 3)-in seeting chec *complet affter flash *unlock affter flash *use server *enable security bypass 4)- clic flash and enjoy |
The Following User Says Thank You to algerienbox For This Useful Post: |
Confuse! Confuse! About T156 new sec! Please do something | memobiles | FuriousGold | 5 | 11-15-2009 11:45 |
W800i unlock step step by step | somratjisan | Cruiser Suite | 1 | 12-13-2008 08:28 |
Somewhat Confused about Unlocking? | Mattkostan | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-02-2004 20:03 |
confused about bosch 909 dual s | IBRAHIM95 | Various | 3 | 07-29-2002 06:38 |
Still confused about DCT-4 purchase??? | Spalato | Main Sales Section | 0 | 06-24-2002 19:18 |
