05-11-2008, 08:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Allways here
Member: 476774 Status: Offline Thanks Meter: 399 | DB2012 CID52 Unlock Procedure (FLASH Method) 1 - Make sure that you are using latest SETool SW version (v0.914030 currently), and your phone must have fully charged battery. 2 - Turn on your phone without SIM inserted. Attach it to USB (DCU-60) cable and, when prompted, install appropriate drivers (you can find all drivers that you need on "download/software files/drivers for CSCA procedure/" folder on SETool support area). 3 - Start SETool SW. On "Settings" tab, check "SIGNED MODE (USE SERVER FOR BYPASS/CSCA)", "ENABLE ALTERNATIVE SECURITY BYPASS", "COMPLETE PHONE AFTER FLASH" and "UNLOCK AFTER FLASH" options. 4 - Now go to "Sony Ericsson" tab, select correct phone model and press "Identify". Attach turned off phone to USB cable and hold "C" key. Verify SW version installed on phone, CID version and check the provider that the phone is locked to (in this example, phone is locked to 724-05 Claro Br provider), because your will need to use an accepted SIM or a Test SIM during this process. Before continue, please take care with this advertise: Quote: Originally Posted by The_Laser Precautions: please take care that there is NO (at least, i can't get) cid52 firmwares for following db2010 phones: k310,k510,w810,z530,z550 luckily, k310,k510 can be flashed with w200 firmware, so we can always return them to original state. but it is NOT related to w810,z530,z550 phones. cause there is no firmwares, we can't recover them in case of error. because of that, one mistake with that phones - and you get deadweight. you have been warned. 5 - Go to SETool support area and download appropriate SW version for your phone. If you canīt locate exactly version, use highest version possible. Double check CID file version. It must be CID 52. Now, press "Add" button and add MAIN and FS files. You can also use "Custpacks" if you need. 6 - Press "Flash" button and attach turned off phone to USB cable, holding "C" key. Phone will be detected and flash procedure will starts. 7 - When prompted, disconnect phone, insert an accepted SIM card (in this example, a Claro Br SIM) or Test SIM, turn it on and continue holding "C" key during powering process. 8 - When phone is fully turned on, attach it to USB cable. Phone will be found by SETool SW and unlock process will continues. 9 - SETool SW will write MAIN and FS files to phone, than will start unlock procedure. 10 - In the end, if everything goes fine, you will receive "Phone detached, Elapsed Time" message. You phone is now ready to work with any providerīs SIM card. B.r. salamatali |
05-11-2008, 23:44 | #6 (permalink) | |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Quote:
The Following User Says Thank You to Nurettin Duman For This Useful Post: |
DB2012 CID52 Unlock Procedure (RESTORE Method) | salamatali | SETool2 | 134 | 11-24-2018 16:23 |
DB2012 CID52 Unlock Procedure (RESTORE Method) | adelgsm | SETool2 | 16 | 05-29-2009 21:16 |
Who will make fist DB2012 CID52 Unlock by Patch | tito millo | Sony Ericsson | 245 | 07-15-2008 18:07 |
DB2012 CID52 Unlock Procedure (FLASH Method) | adelgsm | SETool2 | 3 | 05-14-2008 15:45 |
Can add DB2012 CID52 unlocking | EMINEMGSM | FuriousGold | 5 | 12-01-2007 15:06 |
