Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 05-13-2008, 07:57   #1 (permalink)
salamatali's Avatar
Member: 476774
Thanks Meter: 390
Smile DB2012 CID52 Unlock Procedure (RESTORE Method)
This steps should work with all DB2012 CID52 phones, but for this description, iīve used a W200i phone. To apply in another models, just use appropriate files (Drivers and Restore) for desired phone.
1 - Make sure that you are using latest SETool SW version (v0.914030 currently), and your phone must have fully charged battery.
2 - Turn on your phone without SIM inserted. Attatch it to USB (DCU-60) cable and, when prompted, install appropriate drivers (you can find all drivers that you need on "download/software files/drivers for CSCA procedure/" folder on SETool support area).
3 - Start SETool SW. On "Settings" tab, check both "SIGNED MODE (USE SERVER FOR BYPASS/CSCA)" and "ENABLE ALTERNATIVE SECURITY BYPASS" options.
4 - Now go to "Sony Ericsson" tab, select correct phone model and press "Identify". Attach turned off phone to USB cable and hold "C" key. Check if the restoration file is present. If yes, go to step 7. If not, continue reading. Check the provider that the phone is locked to (in this example, phone is locked to 724-05 Claro Br provider), because you will need to use an accepted SIM or a Test SIM during this process. Check the SW of the phone too (in this example, R4JA011 Generic ME) to locate appropriate restore file.
5 - To find your restore file, go to SETool support area ("download/software files/original setool2 rest files/collection" folder), search for it and download file to "Rest" folder inside SETool main folder.
6 - To be sure that youīve downloaded correct rest file, press "Identify" again and check info.
7 - Now, press "Unlock/Repair" function and attach turned off phone to USB cable holding "C" key. unlock process will start.
8 - When prompted, disconnect phone, insert an accepted SIM card (in this example, a Claro Br SIM) or Test SIM, turn it on and continue holding "C" key during powering process.
9 - When phone is fully turned on, attach it to USB cable. Phone will be found by SETool SW and unlock process will continues.
10 - Normally phone will restart by itself. If itīs not, remove battery, insert on phone again and attach phone to USB cable holding "C" key. SETool will continue to unlock phone.
11 - Now just wait until unlock procedure done. Usually entire process goes on 160~180 secs, but takes 213 secs because i was taking screenshots during process!
Note: If you go to "Games" folder after make this procedure, you will find a new application called "executor". If you are sufficient "curious" and execute this aplication to see what happens without know what are you doing for, your note that your phone will turn off and will not turn on again after this. This application will be used only to minimize boot steps and saving operational time in future works on this same phone. To get phone fully working again, go to "Settings" tab on SETool SW, check only "ENABLE PRELOADER SECURITY BYPASS", than click on "Unlock/Repair" function, attach phone to USB cable holding "C" key and wait to finish process. After this, your phone will be working again.
B.R.
salamatali
The Following 171 Users Say Thank You to salamatali For This Useful Post:
Old 05-19-2008, 08:14   #2 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,429
great work brother
ur a setool master i like that bery exlent guide
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 05-19-2008, 09:14   #3 (permalink)
muhammad irshad's Avatar
Member: 304793
Sonork: 100.1593824
Thanks Meter: 45
great work brother
Old 05-19-2008, 16:19   #4 (permalink)
Registered User
unlock-king's Avatar
Member: 713233
Thanks Meter: 13
unlocked sucessfully testim or orginal operator locked sim required
Old 05-20-2008, 14:08   #5 (permalink)
mujahid_ali's Avatar
Member: 547967
Thanks Meter: 646
good work man thanxs for ur help it works for me in unlocking w200
Thanxs
Old 05-20-2008, 14:22   #6 (permalink)
.::ricky rayya::.'s Avatar
Member: 254397
Thanks Meter: 224
WOUNDERFULL THREAD GOOD JOB
..::RICKY RAYYA::..
The Following 3 Users Say Thank You to .::ricky rayya::. For This Useful Post:
Old 05-20-2008, 14:24   #7 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,692
NOW same Procedure will work for
db201x cid50/cid51, pnx5230 cid49/cid51, db2020 cid49/cid51.
using latest gui v33 as all supported standalone...no logs needed any more
The Following 3 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 05-20-2008, 14:39   #8 (permalink)
Member: 91045
Thanks Meter: 8,692
Only one change
in order to enable NEW (STANDALONE) alternative security bypass,
you MUST check ALSO "enable preloader security bypass".
otherwise server-based security bypass will be used.
The Following 2 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 05-20-2008, 14:57   #9 (permalink)
amit_varietymob's Avatar
Member: 399228
Thanks Meter: 66
Great Work Sir , Today I Have Unlocked 2 W200i Cid 52 Successfully. Thanks A Lot.
The Following 2 Users Say Thank You to amit_varietymob For This Useful Post:
Old 05-20-2008, 15:38   #10 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
Nice & Good Work !
Keep It Up .............
The Following 2 Users Say Thank You to .:Kuku:. For This Useful Post:
Old 05-20-2008, 19:17   #11 (permalink)
Member: 697582
Thanks Meter: 2
nice good working
tanks mr
The Following User Says Thank You to esm-gsm For This Useful Post:
Old 05-20-2008, 19:17   #12 (permalink)
Member: 697582
Thanks Meter: 2
one sim test for one phone sony ericsson?
Old 05-21-2008, 11:05   #13 (permalink)
hafiz's Avatar
Member: 78936
Sonork: 100.1575790
Thanks Meter: 426
@ salamatali
nice to see all this
br
hafiz
www.unlockfonez.com
The Following 2 Users Say Thank You to hafiz For This Useful Post:
Old 05-21-2008, 11:20   #14 (permalink)
dmaetrey's Avatar
Member: 315550
Thanks Meter: 110
any steps for Unlocking cid 52 k530???
much appreciated thanks a lot!
Old 05-21-2008, 11:25   #15 (permalink)
.::LUQMAN::.'s Avatar
Member: 413053
Sonork: 100.114351
Thanks Meter: 457
B.R.
salamatali
gr88 work my dear brother.........
The Following 11 Users Say Thank You to .::LUQMAN::. For This Useful Post:
DB2012 CID52 Unlock Procedure (FLASH Method) salamatali SETool2 10 04-28-2010 09:13
DB2012 CID52 Unlock Procedure (RESTORE Method) adelgsm SETool2 16 05-29-2009 22:16
Who will make fist DB2012 CID52 Unlock by Patch tito millo Sony Ericsson 245 07-15-2008 19:07
DB2012 CID52 Unlock Procedure (FLASH Method) adelgsm SETool2 3 05-14-2008 16:45
Can add DB2012 CID52 unlocking EMINEMGSM FuriousGold 5 12-01-2007 15:06
Page generated in 0.40107 seconds with 8 queries
