Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #46 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: srilanka & bangladesh
Member: 789364 Status: Offline Sonork: 100.1585484 Thanks: 296
| w200i cannot unlock w200i cannot unlock v0.914030/UNI CARD SERIAL:????????? Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35201402505419 CERT:RED FLASH CID:52 COLOR:RED Model:W200i Brand:Generic MAPP CXC article: R4GB001 prgCXC1250720_CHINA_ME MAPP CXC version: R4GB001 Language Package:EUROPE_1 CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 234-33 Network LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE NOT PRESENT "R4GB001_CXC1250720_CHINA_ME.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. please help me.how can i unlock when i try to unlock then show me this massage: RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE NOT PRESENT "R4GB001_CXC1250720_CHINA_ME.zip" YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS" Last edited by sharif_tell; 06-21-2008 at 18:28. Reason: correction serial number |
| | #47 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks: 701
| Quote:
YOU MUST FLASH SUPPORTED FIRMWARE TO USE "ALTERNATIVE SECURITY BYPASS, flash it another version, | |
| | #49 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2007
Member: 442620 Status: Offline Thanks: 1
| v0.914036/UNI CARD SERIAL: Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35601901669991 CERT:RED FLASH CID:52 COLOR:RED Model:K550i Brand:Generic MAPP CXC article: R6BC002 prgCXC1250669_GENERIC_LI MAPP CXC version: R6BC002 Language Package:S_ASIA_LEVAN CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1250671 Default version: R6BC002 PROVIDER: 242-01 Extended LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 6 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35601901669991 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM43 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 138 secs. i have such error (SIM is in) |
| | #50 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Allways here
Member: 476774 Status: Offline Thanks: 351
| Quote:
SEARCHING FOR PHONE, "STOP" TO ABORT the detach fone and insert sim in fone nd trun on ur fone and open sim menu nd go in games press on executor ur fone will trun off dunt worry now open software window and select corect model nd in setting only tick on enable prelodaer by pass............ press unlock button nd hold on c and attach fone with cable after few sec........ur fone will unlocked ![]() after unlock must delete executor from fone in games or follow this thread http://www./showthread.php?t=548754 | |
| The Following User Says Thank You to salamatali For This Useful Post: |
| | #58 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2003 Location: russia georgia Age: 31
Member: 32589 Status: Offline Thanks: 7
| bro thanks,,,, but i have downloaded bypass folder extracted into my setool v914037 but when i connect w880 it says by bypass package not found where am i going wrong????please help and correct me many thanks |
| | #60 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: Closer to your's
Member: 442526 Status: Offline Thanks: 0
| v0.914037/UNI CARD SERIAL: 00000786 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:3561960150000 CERT:RED FLASH CID:52 COLOR:RED Model:W200i Brand:Generic MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME MAPP CXC version: R4GB001 Language Package:S_ASIA_LEVAN CDA article: CDA12345678/123 CDA version: R2A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 000-00 Service provider LOCKED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35619601500000CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM22 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 225 secs. [SIZE=6]Please help me now what i do?[/SIZE] Last edited by SE4U; 07-29-2008 at 12:11. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| DB2012 CID52 Unlock Procedure (FLASH Method) | salamatali | SETool2 | 10 | 04-28-2010 08:13 |
| DB2012 CID52 Unlock Procedure (RESTORE Method) | adelgsm | SETool2 | 16 | 05-29-2009 21:16 |
| Who will make fist DB2012 CID52 Unlock by Patch | tito millo | Sony Ericsson | 245 | 07-15-2008 18:07 |
| DB2012 CID52 Unlock Procedure (FLASH Method) | adelgsm | SETool2 | 3 | 05-14-2008 15:45 |
| Can add DB2012 CID52 unlocking | EMINEMGSM | FuriouS TeaM Products | 5 | 12-01-2007 14:06 |
