07-29-2008, 15:34 | #61 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
Did u powered the phone with test sim or accepted sim ??????????? or without it ....... | |
07-30-2008, 08:16 | #63 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Closer to your's
Member: 442526 Status: Offline Thanks Meter: 11 | Thanks sir for reply my mobile is T-Mobile locked but this one also not accepted T-Mobile Sim Card when me put T-Mobile sim card its showing insert correct sim card. Test card and T-Mobile card error same. |
07-30-2008, 10:24 | #64 (permalink) |
No Life Poster Join Date: Jun 2004 Location: lebanon Age: 45
Member: 68311 Status: Offline Thanks Meter: 34 | ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35612701128615 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok phone CID not supported in that mode Elapsed: 5 secs. what is the problim????? |
07-30-2008, 13:50 | #66 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Quote:
first check the option of signed mod and then do anything. | |
The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
08-04-2008, 09:10 | #68 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Allways here
Member: 476774 Status: Offline Thanks Meter: 399 | Quote:
u must need acepted sim card or any test card ................... u can use tonado sim card motorolla testd card etc.................. no other solution for it only test point unlocking(dream box) or use testpoint unlocking with setool no need any sim card for it | |
The Following User Says Thank You to salamatali For This Useful Post: |
08-04-2008, 09:39 | #70 (permalink) |
Member: 442526 Status: Offline Thanks Meter: 11 | Hey mates if someone have solution of my problem please tell him how to fix this problem. My mobile is T-Mobile locked but it's also not accepted T-Mobile Sim Card when me put T-Mobile sim card its showing insert correct sim card. Anyother sim card and T-Mobile card both error same. |
08-04-2008, 12:56 | #71 (permalink) |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | well bro so its better to use the Test Card...... cozz Tmobile sim not only working in one country it may be from diff countries ... so u need to chek exactly from which country the phone is ... and use that Sim ... or the best i already told to use test card........ |
DB2012 CID52 Unlock Procedure (FLASH Method) | salamatali | SETool2 | 10 | 04-28-2010 08:13 |
DB2012 CID52 Unlock Procedure (RESTORE Method) | adelgsm | SETool2 | 16 | 05-29-2009 21:16 |
Who will make fist DB2012 CID52 Unlock by Patch | tito millo | Sony Ericsson | 245 | 07-15-2008 18:07 |
DB2012 CID52 Unlock Procedure (FLASH Method) | adelgsm | SETool2 | 3 | 05-14-2008 15:45 |
Can add DB2012 CID52 unlocking | EMINEMGSM | FuriousGold | 5 | 12-01-2007 15:06 |
