05-13-2008, 10:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | DB2012 CID52 Unlock Procedure (RESTORE Method) 1 - Make sure that you are using latest SETool SW version (v0.914030 currently), and your phone must have fully charged battery. 2 - Turn on your phone without SIM inserted. Attatch it to USB (DCU-60) cable and, when prompted, install appropriate drivers (you can find all drivers that you need on "download/software files/drivers for CSCA procedure/" folder on SETool support area). 3 - Start SETool SW. On "Settings" tab, check both "SIGNED MODE (USE SERVER FOR BYPASS/CSCA)" and "ENABLE ALTERNATIVE SECURITY BYPASS" options. 4 - Now go to "Sony Ericsson" tab, select correct phone model and press "Identify". Attach turned off phone to USB cable and hold "C" key. Check if the restoration file is present. If yes, go to step 7. If not, continue reading. Check the provider that the phone is locked to (in this example, phone is locked to 724-05 Claro Br provider), because you will need to use an accepted SIM or a Test SIM during this process. Check the SW of the phone too (in this example, R4JA011 Generic ME) to locate appropriate restore file. If you canīt found your needed restore file, follow THIS thread to request it or use FLASH Method. 5 - To find your restore file, go to SETool support area ("download/software files/original setool2 rest files/collection" folder), search for it and download file to "Rest" folder inside SETool main folder. 6 - To be sure that youīve downloaded correct rest file, press "Identify" again and check info. 7 - Now, press "Unlock/Repair" function and attach turned off phone to USB cable holding "C" key. unlock process will start. http://img122.imageshack.us/img122/5660/imagem6ob8.png |
05-14-2008, 09:58 | #7 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Egypt_Cairo Age: 41
Member: 111140 Status: Offline Thanks Meter: 75 | Unlock SonyEricsson W200 VIDEO TUTORIAL Peace be with you Thanks for Setool Team for Free update and thanks for help us. Unlock SonyEricsson W200 VIDEO TUTORIAL BestRegards. GsmOrient. |
05-14-2008, 15:41 | #9 (permalink) |
No Life Poster Join Date: May 2008 Location: City Center
Member: 770272 Status: Offline Sonork: 100.1603193 Thanks Meter: 227 | sir how to unlock this phone please help me thanks in advance v0.914031/UNI CARD SERIAL: ****** Loaded 51 flash descriptors ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:51 skipping empty loader... OTP LOCKED:1 CID:51 PAF:1 IMEI:35464001322095 CERT:RED Model:Z310i Brand:T-mobile MAPP CXC article: R1JC002 prgCXC1250594_GENERIC_AL MAPP CXC version: R1JC002 Language Package:T_MOB_INT_A CDA article: CDA102670/48 CDA version: R8A Default article: cxc1250595 Default version: R1JC002 PROVIDER: 234-30 Extended LOCKED RESTORATION FILE NOT PRESENT "R1JC002_CXC1250594_GENERIC_AL" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED SECURITY UNITS BACKUP CREATED. Elapsed: 3 secs. |
05-14-2008, 16:20 | #10 (permalink) |
Freak Poster Join Date: Aug 2006 Location: egypt
Member: 332555 Status: Offline Sonork: 100.114258 Thanks Meter: 30 | 14/05/2008 18:02:58 v0.914029/UNI 14/05/2008 18:02:58 CARD SERIAL: 14/05/2008 18:02:58 Loaded 51 flash descriptors 14/05/2008 18:03:34 ChipID:8040,EMP protocol:0301 14/05/2008 18:03:34 NEW SECURITY MODEL DETECTED 14/05/2008 18:03:34 erom_readvar: error reading unit 1/725 14/05/2008 18:03:34 error while reading SIMLOCK SIGNATURE unit 14/05/2008 18:03:34 phone was tampered with other software 14/05/2008 18:03:34 SECURITY UNITS CAN'T BE READ ! 14/05/2008 18:03:34 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE 14/05/2008 18:03:34 Can't load ID loader ! 14/05/2008 18:03:35 Elapsed: 4 secs. 14/05/2008 18:04:12 ChipID:8040,EMP protocol:0301 14/05/2008 18:04:12 NEW SECURITY MODEL DETECTED 14/05/2008 18:04:12 erom_readvar: error reading unit 1/725 14/05/2008 18:04:12 error while reading SIMLOCK SIGNATURE unit 14/05/2008 18:04:12 phone was tampered with other software 14/05/2008 18:04:12 SECURITY UNITS CAN'T BE READ ! 14/05/2008 18:04:12 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE 14/05/2008 18:04:12 Can't load ID loader ! 14/05/2008 18:04:13 Elapsed: 4 secs. 14/05/2008 18:05:29 Open COM port OK 14/05/2008 18:05:33 ChipID:8040,EMP protocol:0301 14/05/2008 18:05:33 NEW SECURITY MODEL DETECTED 14/05/2008 18:05:33 14/05/2008 18:05:33 PHONE IS RED RETAIL PRODUCT 14/05/2008 18:05:33 FLASH CID detected:52 14/05/2008 18:05:33 Speed:921600 14/05/2008 18:05:34 OTP LOCKED:1 CID:51 PAF:1 IMEI:35970701278202 CERT:RED 14/05/2008 18:05:34 phone CID not supported in that mode 14/05/2008 18:05:34 Elapsed: 5 secs. 14/05/2008 18:06:09 RECOVERY MODE STARTED 14/05/2008 18:06:09 Open COM port OK 14/05/2008 18:06:13 NEW SECURITY MODEL DETECTED 14/05/2008 18:06:13 14/05/2008 18:06:13 err: 32 (9) 14/05/2008 18:06:13 loader header not accepted 14/05/2008 18:06:14 Open COM port OK 14/05/2008 18:06:24 NEW SECURITY MODEL DETECTED 14/05/2008 18:06:24 14/05/2008 18:06:24 err: 32 (9) 14/05/2008 18:06:24 loader header not accepted 14/05/2008 18:06:24 All possible recovery loaders fail. That phone not supported 14/05/2008 18:06:25 Elapsed: 15 secs. 14/05/2008 18:07:45 Processing script "J:\1ST\all box\se tool\new setup\New Folder\v0.914029\script\070323_DB2012_CROD_CID_51_ to_CID_52_Red.gdfs"... 14/05/2008 18:07:45 Open COM port OK 14/05/2008 18:07:51 ChipID:8040,EMP protocol:0301 14/05/2008 18:07:51 NEW SECURITY MODEL DETECTED 14/05/2008 18:07:51 14/05/2008 18:07:51 PHONE IS RED RETAIL PRODUCT 14/05/2008 18:07:51 FLASH CID detected:52 14/05/2008 18:07:51 Speed:921600 14/05/2008 18:07:52 OTP LOCKED:1 CID:51 PAF:1 IMEI:35970701278202 CERT:RED 14/05/2008 18:07:52 phone CID not supported in that mode 14/05/2008 18:07:53 Elapsed: 7 secs. 14/05/2008 18:08:44 ChipID:8040,EMP protocol:0301 14/05/2008 18:08:44 NEW SECURITY MODEL DETECTED 14/05/2008 18:08:44 erom_readvar: error reading unit 1/725 14/05/2008 18:08:44 error while reading SIMLOCK SIGNATURE unit 14/05/2008 18:08:44 phone was tampered with other software 14/05/2008 18:08:44 SECURITY UNITS CAN'T BE READ ! 14/05/2008 18:08:44 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE 14/05/2008 18:08:44 Can't load ID loader ! 14/05/2008 18:08:44 Elapsed: 16 secs. 14/05/2008 18:16:27 SIGNED MODE (USING SERVER). 14/05/2008 18:16:27 ALTERNATIVE SECURITY BYPASS ENABLED. 14/05/2008 18:16:31 ChipID:8040,EMP protocol:0301 14/05/2008 18:16:31 NEW SECURITY MODEL DETECTED 14/05/2008 18:16:31 erom_readvar: error reading unit 1/725 14/05/2008 18:16:31 error while reading SIMLOCK SIGNATURE unit 14/05/2008 18:16:31 phone was tampered with other software 14/05/2008 18:16:31 SECURITY UNITS CAN'T BE READ ! 14/05/2008 18:16:31 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE 14/05/2008 18:16:31 Can't load ID loader ! 14/05/2008 18:16:32 Elapsed: 5 secs. need help with phone thankxx |
05-14-2008, 17:11 | #11 (permalink) | |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | Quote:
05-14-2008, 19:59 | #13 (permalink) |
Member: 332555 Status: Offline Sonork: 100.114258 Thanks Meter: 30 | can some one explain how to repair this error with setool in w200i 14/05/2008 18:16:27 SIGNED MODE (USING SERVER). 14/05/2008 18:16:27 ALTERNATIVE SECURITY BYPASS ENABLED. 14/05/2008 18:16:31 ChipID:8040,EMP protocol:0301 14/05/2008 18:16:31 NEW SECURITY MODEL DETECTED 14/05/2008 18:16:31 erom_readvar: error reading unit 1/725 14/05/2008 18:16:31 error while reading SIMLOCK SIGNATURE unit 14/05/2008 18:16:31 phone was tampered with other software 14/05/2008 18:16:31 SECURITY UNITS CAN'T BE READ ! 14/05/2008 18:16:31 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE 14/05/2008 18:16:31 Can't load ID loader ! 14/05/2008 18:16:32 Elapsed: 5 secs. |
05-14-2008, 21:09 | #15 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 135 | i cant open the sites with blue font. Quote:
DB2012 CID52 Unlock Procedure (RESTORE Method) | salamatali | SETool2 | 134 | 11-24-2018 16:23 |
DB2012 CID52 Unlock Procedure (FLASH Method) | salamatali | SETool2 | 10 | 04-28-2010 08:13 |
Who will make fist DB2012 CID52 Unlock by Patch | tito millo | Sony Ericsson | 245 | 07-15-2008 18:07 |
DB2012 CID52 Unlock Procedure (FLASH Method) | adelgsm | SETool2 | 3 | 05-14-2008 15:45 |
Can add DB2012 CID52 unlocking | EMINEMGSM | FuriousGold | 5 | 12-01-2007 15:06 |
