01-07-2013, 10:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | e15I unlock failed, setool activated CARD SERIAL 00055555 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 397ADD6E9E2F86E03FE9CEE45D0624780FF24262 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01256000065005 MODEL (from GDFS): E15i SOFTWARE VERSION: 1236-9291_1.3.A.0.50 CUSTOM VERSION: 1241-4605_R9A FILESYSTEM VERSION: WORLD-1-8_1.3.A.0.50 Network LOCK : 21402-* Network LOCK : 21407-* SERIAL NO: CB511R4WVL Elapsed: 145 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 397ADD6E9E2F86E03FE9CEE45D0624780FF24262 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01256000065005 Checking for signature ... REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... APPLYING ROOT RIGHTS ... PROCESSING ... failed, err: [error: protocol fault (no status) ] Unlock FAILED Elapsed: 507 secs. |
01-07-2013, 11:33 | #3 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Quote:
08-05-2013, 14:52 | #5 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1737671 Status: Offline Thanks Meter: 69 | RUNNING v 1.1300/01.15/UNI CARD SERIAL 0017xxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 31 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: 94BDEC119C8F1B9987D6DF7662FF5387AB9052B0 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 3567xxxxxxxxxxx Checking for signature ... REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... * daemon not running. starting it now on port 5037 * * daemon started successfully * E15i-user 2.1-upda ... failed, err: [adb server is out of date. killing... * daemon started successfully * protocol failure] Unlock FAILED Elapsed: 149 secs. |
