07-10-2010, 16:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: GHANA
Member: 1240625 Status: Offline Sonork: LABISTA Thanks Meter: 48 | err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. CARD SERIAL 00026483 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:18C96B232380F86C253090D4 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35557602870659 CERT:RED PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 15 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35557602870659 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "D:\SOFTWARES\DECOODING\setools\gdfs_in_ssw_format \db2020\w200_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... writing "D:\SOFTWARES\DECOODING\setools\eroms\db2020\DB202 0EROM_CNV_RED53_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "45218815" SIGNING... Elapsed: 51 secs. SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. pls help me |
07-10-2010, 22:49 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | u can try it pls. * select w200 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get brown 49 w200 after successful RECOVERY * switch to empty board tab * select w200 * add w200_gdfs_ssw.ssw * add DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw * click flash * now u get red 52 w200 * flash with red 52 firmware * DONE. |
07-11-2010, 11:41 | #3 (permalink) | ||
Freak Poster Join Date: Dec 2007
Member: 646256 Status: Offline Thanks Meter: 63 | Quote:
Setool_v1.81\eroms\db2010\db2012_erom_cid52.ssw Setool_v1.81\eroms\db2010\db2012_erom_cid52.ssw Setool_v1.81\eroms\db2010\db2012_erom_cid52.ssw Setool_v1.81\eroms\db2010\db2012_erom_cid52.ssw | ||
07-12-2010, 10:47 | #5 (permalink) | |
Member: 1240625 Status: Offline Sonork: LABISTA Thanks Meter: 48 | Quote:
i | |
07-12-2010, 12:36 | #6 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
* select w200 * mark only SIGN MODE ( 1.01 version already gdfs repair free) * press RECOVERY * connect phone with usb or com port * you get red 51 w200 after successful RECOVERY * go to empty board tab * select w200 * add w200_gdfs_ssw.ssw * add db2012_erom_cid51.ssw * click flash * now u get red 51 w200 * flash with red 51 firmware * DONE. | |
07-12-2010, 16:04 | #7 (permalink) | |
CARD SERIAL xxxxxxxxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35735401728229 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 Executing CSCA-based unlock. PLEASE SELECT "USB" AS INTERFACE Elapsed: 80 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35735401728229 CERT:RED LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738 FLASH ID: 897E LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... bad username/password. signature calculation not done,err: 144 Elapsed: 30 secs. SIGNED MODE (USING SERVER) CFG:100000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35735401728229 CERT:RED ACTIVE CID:52 COLOR:RED Model (from GDFS):W200i MAPP CXC article: R4GB001 prgCXC1250725_ORANGE_ME MAPP CXC version: R4GB001 Language Package: ORANGE_GEN CDA article: CDA102738/71 CDA version: R9A Default article: cxc1250728 Default version: R4GB001 PROVIDER: 234-33 Network LOCKED USERCODE:1312 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 75 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F FLASH ID: 897E GOT SEED:94356F9B2380F86C253090D4 P96 AUTH PASSED OTP LOCKED:1 CID:51 PAF:1 IMEI:35557602870659 CERT:BROWN PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 44 secs. CFG:000000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "DEVELOPER" FLASH CID: 0051 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35557602870659 CERT:BROWN LDRB2010_RESPIN_PRODLOADER_SETOOL2 FLASH ID: 897E writing "D:\SOFTWARES\DECOODING\setools\gdfs_in_ssw_format \db2020\w200_gdfs_in_ssw_format.ssw" CURRENT FLASH FILE CID:UNIVERSAL SSW uses dynamic hash, dynamic hash len is: 32 Will flash 32 blocks... writing "D:\SOFTWARES\DECOODING\setools\eroms\db2020\DB202 0EROM_CNV_RED51_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 80 Will flash 4 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "77223066" SIGNING... Elapsed: 54 secs. SIGNED MODE (USING SERVER) CFG:101000000000 NEW SECURITY (RESPIN) PHONE ChipID:8040,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0051 Speed:921600 err: 32 (9) loader header not accepted FAILED TO SETUP PHONE Elapsed: 1 secs. tried n had this problem when i tyr to flash | |
07-12-2010, 16:40 | #8 (permalink) | |
1 Read carefully the above posts until you will understand them 2 Another thing, don't mix phones (IMEIs) while requesting help | |
The Following User Says Thank You to KHD19 For This Useful Post: |
07-12-2010, 19:34 | #9 (permalink) | |
07-12-2010, 19:39 | #10 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: MARS
Member: 444981 Status: Offline Thanks Meter: 45 | simple simple Quote:
bro after recovery dont do signd mode remove it and than wright your gdfs first and erom gdfs first gdfs first dont forget bro hope it will help | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
