03-30-2017, 09:22 | #2 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2110911 Status: Offline Thanks Meter: 22 | Flash any firmware from support, use this order: FS elabel APP elabel file is the key to avoid red screen on mtk devices, if there's more than one elabel file then use row_row or any file without country notation, example, au, az, etc. In folder root from any device you can find a file text with configuration for any rom from support. |
10-02-2017, 11:31 | #9 (permalink) | |||
Crazy Poster Join Date: Nov 2004 Location: My home Age: 43
Member: 94230 Status: Offline Thanks Meter: 41 | Quote:
Write this script it will be OK tawrite | |||
The Following User Says Thank You to poucamp For This Useful Post: |
10-02-2017, 23:13 | #11 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Greece
Member: 217170 Status: Offline Thanks Meter: 43 | Error my frient Processing script "G:\ΚΙΝΗΤΑ\SE TOOL CRARD VERSION\SE TOOL FLS\F3311_xperia_e5 37.0.A.2.156\tawrite.txt" ... PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... llbug: read error: "Η συσκευή δεν αναγνωρίζει αυτήν την εντολή" supported phone was not detected FAILED TO SETUP PHONE Elapsed: 27 seconds i have FAILED 2227:56 00 00 2228:01 02 03 04 08 0A 0C 2229:08 0C 01 02 04 |
10-02-2017, 23:22 | #13 (permalink) |
Member: 217170 Status: Offline Thanks Meter: 43 | the second time my friend all thank you very much!!!!!!!!!!!!!!! SIGNED MODE (USING SERVER) CFG:100000000000 Processing script "G:\ΚΙΝΗΤΑ\SE TOOL CRARD VERSION\SE TOOL FLS\F3311_xperia_e5 37.0.A.2.156\tawrite.txt" ... PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "S1_Boot_MT6735_M0.MP16_27" ACTIVE_COMP_AID : 0004 HWCONF_AID : 0004 LOADER_AID : 0004 BOOT_AID : 0004 [ llcomm: 00800000,00080000 ] DEVICE ID: 48C94A0B3314152D FLASH ID: "0015/01000001" LOADER VERSION: S1_Boot_MT6735_M0.MP16_27 PHONE IMEI : 35374808401564 Writing TA unit 0002/08B3/0004 Elapsed: 7 seconds |
07-23-2018, 15:02 | #14 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Dear I have same problem with my F3311 after flash with latest firmware phone has a code please share here script file Thanks in advance |
