12-14-2008, 11:15 | #1 (permalink) |
Junior Member Join Date: Nov 2008
Member: 893955 Status: Offline Thanks Meter: 1 | flash R306 die CARD SERIAL: 66886688 Loaded 51 flash descriptors Connecting to UFS... Found 1 FTDI device(s). Can't detect any UFS boxes. only COM/UFS supported Can't load ID loader ! Elapsed: 1 secs. only COM/UFS supported Can't load ID loader ! Elapsed: 0 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 MODEL:R306 FACTORY CXC:CXC1250616_R5A036 CURRENT CXC:R1AB002 CURRENT CDA:R9A USERLOCK PRESENT Elapsed: 1970 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 writing D:\THIET BI\SETOOL\SE Flash\R306\R306i_RTL_new_R1AB002_COMMON_FILES\R1AB 002_1211_6339_ICN_JIALI_BROWN.software writing D:\THIET BI\SETOOL\SE Flash\R306\R306i_RTL_new_R1AB002_COMMON_FILES\R1AB 002_1212_9864_MC_JIALI_BROWN.software writing D:\THIET BI\SETOOL\SE Flash\R306\R306_RTL_new_GEN_ENTRY08_VIETNAM_R1AB00 2_1212_6302_R9A\R1AB002_1211_6112_VIETNAM_JIALI_BR OWN.software writing D:\THIET BI\SETOOL\SE Flash\R306\R306_RTL_new_GEN_ENTRY08_VIETNAM_R1AB00 2_1212_6302_R9A\R9A_CDA__1212_6302.software Elapsed: 395 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 writing D:\THIET BI\SETOOL\SE Flash\R306\R306_RTL_new_GEN_ENTRY08_VIETNAM_R1AB00 2_1212_6302_R9A\R1AB002_1211_6112_VIETNAM_JIALI_BR OWN.software writing D:\THIET BI\SETOOL\SE Flash\R306\R306_RTL_new_GEN_ENTRY08_VIETNAM_R1AB00 2_1212_6302_R9A\R9A_CDA__1212_6302.software Elapsed: 114 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 writing C:\Documents and Settings\adminadmin\Desktop\r306a_r1ba011_common\R 1BA011_1212_9858_MC_JIALI_RED.software writing C:\Documents and Settings\adminadmin\Desktop\r306a_r1ba011_common\R 1BA011_1211_6339_ICN_JIALI_RED.software flash block not confirmed Elapsed: 306 secs. SIGNED MODE (USING SERVER). PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 writing C:\Documents and Settings\adminadmin\Desktop\r306a_r1ba011_common\R 1BA011_1212_9858_MC_JIALI_RED.software flash block not confirmed Elapsed: 299 secs. SIGNED MODE (USING SERVER). PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 29 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 54 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 58 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID (EEFD130000) NOT SUPPORTED failed FAILED TO SETUP PHONE Elapsed: 16 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... error #1 not received failed Can't load ID loader ! Elapsed: 8 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... error #1 not received failed Can't load ID loader ! Elapsed: 101 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) readfls tmo at 07FD0000 Can't create RAM TA image Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 49 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... error #1 not received failed Can't load ID loader ! PROCEDURE WAS STOPPED BY USER Elapsed: 164 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... FLASH ID: 0089/8904 (00040000) SECURITY AREA BACKUP CREATED. PHONE IMEI:35587602115869 MODEL:R306 FACTORY CXC:CXC1250616_R5A036 CURRENT CXC:R1AB002 CURRENT CDA:R9A USERLOCK PRESENT Elapsed: 26 secs. to die here, the machine know who to get help thank you |
How To Flash R306 correctly?? | chinesetea | Cruiser Suite | 3 | 02-22-2010 16:21 |
A60 full flash was died, Can't unlock? | vanhh | E-Gold Based Phones | 5 | 03-17-2005 04:55 |
T508 after flashing is die | Alexandr V.Mekh | VLSI, Conexant, Skyworks and Old Models | 0 | 12-09-2004 11:22 |
