11-01-2008, 17:50 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | Frequently asked questions (faq). Tips and tricks. for start: Q: what is db2000,db2010,db2020,pnx5230,db3150,db3210 ? A: that is chipsets of new SEMC phones. db2000 (otherwise called marita "full") is inside next phones: z1010/v800/z800/w900/lg3g/sharp3g db2010 (otherwise called "marita compact") is inside j300/k300/k500/k700/s700/k750 phones. db2020 (otherwise called "marika") is inside k610/k550/k790/k800/w850/w880/z610/well, almost in all new phones. pnx5230 is inside z310,w350,w380,z555 phones. db3150 is A2 generation, phones like k850,w910,w890,z750,etc have it db3210 is next revision of A2 platform and there is not yet retail phones released with that ASIC. db3350 is even future platform from SEMC. Q: how to enable "search mode" and "GSM/3g networks" in "mobile networks" menu item of v800/k600/k608 ? A: use following script (all in one string,without spaces !!!!) Code: gdfswrite:00020CCD00000000000000000000000000000000000000000000000001000000000000000000000000000000000000000000000000000000000000000000 Q: how to use script ? what is script ? A: script is text file, which consists of commands. commands described here usage is simple: make a text file with commands, then select file in "misc. files" edit, then press "write script" button. Q: i unlocked my z520 and my phone is dead !!! help ! help ! A:detach phone from cable, remove battery for 20 seconds ,then insert it back and try to turn phone on. must be ok. still not work ? select in "main firmware file" edit file eroms\k750_w800_z520_new_erom.ssw and flash it. detach cable, remove battery, wait for 20 seconds, insert it back. must work. if still not work - you made something besides simple pressing "unlock" button and phone must be repaired other way. Q: i flashed my phone and it became dead !!! aaargh !!! help me , help ! A:relax. current semc phones can't be killed completely by software. well, some can, but setool2 will not allow it to do it.. simple general way to do: scenario: a friend comes with phone. phone not powers on at all. way: 1. try to flash phone with corresponding flashfiles. if it flashes - good, flash it. following step should not be applied to db2020/pnx5230/db2010 cid49/cid50/cid51/cid52 phones. 2. if after complete phone reports "csloader startup error, fs startup error 1,2,23" then you need to restore erom. all needed EROMs is inside "eroms" folder of setool2 distribution. for db2000 phones erom is z800_v800_k600_old_erom.ssw for db2010 phones erom is k750_w800_z520_old_erom.ssw for w550/w600/s600 phone erom is w550_erom.ssw when flashing EROM you MUST set cid to OTP cid !!!!! 3. if after succefull flashing (complete ok) phone powers on with white screen/freezes on "please wait" step - you need to UNLOCK phone 4. if it can't be unlocked - most probably gdfs is damaged and you must rewrite gdfs with re-formatting (go to settings tab, check "format gdfs"). all needed gdfs is inside "gdfs_in_bin_format,gdfs_in_ssw_format" folders of setool2 distr. select corresponding gdfs in "misc files" edit and press "write gdfs" always make "unlock" after write gdfs. please note, that you SHOULD NOT mess with gdfs in db2020 phones, pnx5230 phones, cid50/51/52 db2010 phones. actually, you only can safely rewrite gdfs on db2000/db2010 cid16/29/36/49 phones. Q: how to remove "strange" "1e0w" or simular from service menu? A: for z1010 use script: Code: gdfswrite:00040CBF00 Code: gdfswrite:00020CB800 Code: gdfswrite:00020DE400000000000000000000 A:all pre-defined gprs and so on account stored in customize.xml file. you can readout that file from phone with such accounts,using script command Code: readfile:/tpa/preset/custom/customize.xml (file will be in PC directory ph_out\tpa\preset\custom\customize.xml) Code: wrfile:test.xml,/tpa/preset/custom/customize.xml |
11-01-2008, 17:51 | #2 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | Acronym explanations. -------------------------------------------------------------------------------- Some general information: CID = Certificate ID. You can say that this "number" defines the version of SE's protection present in the phone. Each CID require their own loaders. New CIDs are deployed from time to time, for the sole reason of preventing them from beeing unlocked/flashed/tampered with by non-SE service tools. Current CIDs in use by SE are 29/36/37/49/50/51/52. SE-based LG/Sharp phones use the same system (but different versions), hence they are supported by SETool. The OTP (One Time Programmable memory) and EROM of a phone might be protected by different CIDs, usually the case in newer K600s/K608s. If SETool reports OTP CID36 and Flash CID49, doing a "Recovery" in the software and replacing the EROM with a CID36 one will render the phone a normal and fully non-TP supported CID36 one. CDA = This "number" defines which variant of a specific firmware a phone is supposed to have. It lets among others SEUS (Sony Ericsson Update Service) know which language-pack/branding/bandlocks a phone is to be flashed with. A generic (unbranded) K750 for use in Scandinavia will be CDA102337/12, whilst a Telenor-branded K750 will be CDA102338/62. Both will be flashed with the same languages/dictionaries, but the latter will be flashed with Telenor-branded firmware (branded firmwares are considered by most as utter crap). BLUE/BROWN/RED: This "color" defines what kind of phone we are dealing with. BLUE phones has been assembled at the factory, but never been programmed with software/GDFS/IMEI (remember kids: the IMEI is stored in the OTP (One Time Programmable memory)) BROWN phones are usually "developer phones", for testing. Less restrictions are present, as these are used for "debugging/beta" purposes. In the case of CID36, a phone has to be converted to BROWN for unlocking. If you ever encounter an OTP CID49 BROWN phone, it must be converted to RED for servicing. (Click here for a guide.) RED phones are your typical retail ones. GDFS: This is the phones "stash", where all settings and calibration data is stored (this also goes for the firmwares IMEI-resource as well as the SIMlocks). Similar to other brands use of NVRAM (Non-Viotile Random Access Memory). IMEI = International Mobile Equipment Identity. A 15-digit number which includes information on the origin, model, and serial number of the device. The model and origin comprise the initial 8-digit portion of the IMEI, known as the "Type Allocation Code/TAC". The remainder of the IMEI is manufacturer-defined, with a "Luhn check digit" at the end (which is never transmitted). The "Luhn check digit" is calculated from the rest of the IMEI. It should be noted that in SE-based phones, the IMEI is stored in two places, the OTP (One Time Programmable memory) and GDFS. The GDFS IMEI is normally read from the OTP, but this can be circumvented by SETool function to "change" the IMEI. This patches the firmware into allowing different OTP/GDFS IMEIs. It is the GDFS IMEI that is reported to the network, so changing this will "de-bar" blocked phones. SEUS is not fooled by this, on the other hand, and it should also be noted that doing this is illegal in most countries. EMMA = Service software/solution by SE themselves. Protected by the EMMA smartcard to prevent non-licensed usage. Current version is EMMA3, though EMMA2 is still alive (but kinda useless on newer phones). The EMMA smartcard contains an algorithm that allows EMMA to communicate directly to/with the phones CID, so performing operations the way they were intended. The smartcard and its algorithm has not been cracked. Current EMMA access levels exists: Service Update - Can't unlock phones. Service Update Pro - Can't unlock phones. Network Operator - Can't unlock phones (but sure as hell can lock them ). Service Center Std - Can't unlock phones. Service Center Rc - Can unlock phones, as they have a special version of the smartcard with a CSCA key. Research & Development - Can unlock phones, as they have a special version of the smartcard with a CSCA key. |
11-01-2008, 18:05 | #4 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | New discovery: GDFS and Bluetooth ID problem. With solution! -------------------------------------------------------------------------------- OK, let say you have 2 K600, K600-A and K600-B for example. K600-A is GDFS damaged, so you read GDFS from K600-B and write it to K600-A. Now, two phones shall be using the same GDFS. But, when you try to pair these 2 K600s with Bluetooth, the phone will hang and reboot. I am not sure about other models, but in my case, the K600 will hang and reboot! Because these 2 phones are using the same BT ID stored in the GDFS (See attached photo). With help from Mr. the_laser, we can solve this problem by changing the Bluetooth ID stored in your phone. Use the script below to read the BT ID: -----cut---- gdfsread:0000002B -----cut---- You will get a file named "gdfs_var_00_002B_your_imei.txt" In this file, you will see your BT ID as: gdfswrite:0000002B221EA9070E00 Where "221EA9070E00" is your BT ID. Just change whatever you like and use the Write Script function to write this file back to your phone and you will have a new BT ID. Of course, the hang & reboot problem will be fixed PS: All credit goes to Mr. the_laser BT_ID.jpg |
11-01-2008, 18:07 | #5 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | q: How to use script to backup GPRS/MMS/Browser settings then write back?? a: script readpkg:/system/wap/profile/ will create pkg_imei.pkg then,to write it back use writepkg:/pkg_imei.pkg |
11-01-2008, 18:09 | #6 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | Q: a customer brings me a phone, i trying to unlock/flash/etc it and only come to the " GUI v0.91373018/UNI Card serial:0000XXXX Loaded 49 flash descriptors Open COM port OK ChipID:8000,EMP protocol:0301 PHONE IS RET RETAIL PRODUCT FLASH CID detected:29 Speed:115200 err: 45 loader prologue returns invalid status failed to load CERTLOADERS,try to use RECOVERY. Elapsed:2 secs. " help,help, what i can do ??? A: problem in software of ,better say, in man, who make that phone before you. a certificate is mismatched inside phone, which is always bad. what we need to do ? reflash phone properly. first - press unlock ------------------------------ RECOVERY MODE STARTED Recovery:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Fetching phone data from OTP OTP status:0 locked:1 CID:36 PAF:1 IMEI:35841300****** CERT:RED Recovery succefull. Reflash phone now Elapsed:8 secs. ----------------------------------- we can see - it is OTP RED36 phone, but firmware has RED29 certificate inside. i NOT supporting such combination, because that is wrong. now, after recovery, our phone is dead and we need reflash it. but TAKE A NOTE - SELECT YOUR OTP CID in CID CHANGE droplist ! (i.e. red36 in our case) then flash only main (if you know version) or just flash standart main+fs+complete. and no need talk to me "hw-k,cr-uiser, tbz blogger,cheap **** is supported phone without reflash". it is INCORRECT to have such combo inside flash, and so it MUST be corrected. |
11-01-2008, 18:10 | #7 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | -------------------------------------------------------------------------------- Q: i want to unloch sh703/903 phone, i flashed patched firmware from support, but phone not turns on ! help,help,etc A: after flashing, select your model in dropdown list and press unlock. probably, in next versions i will embed direct patching of newer 703/903 fw so you only need to press unlock (old sharp fw already supported, just try to unlock before flash patched fw) note: in latest version direct patching supported... |
11-01-2008, 18:31 | #8 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | SEMC posted some documents about problems with Z520. Introduction There is a problem with some Z520 phones where the phone has no network. When you look at the PCB, you may see that R1242 or R1245 are missing, damaged, or askew. (See attached word doc with photos) Comments The problem area on the PCB may appear as mechanical damage. You may even see scrape marks. This is not customer abuse. This damage is being caused in the factory. These phones should be repaired under warranty. Both of the parts (R1242 & R1245) are in the parts list and are shown on the component placing drawing. If you find the part missing, and if the damage does not affect other parts, and if the pads are still intact, replace the missing parts. If the part is slightly askew, and there is not solder damage, then leave it. (The example in the photo is acceptable as is.) If it is severely askew, (less than 50% contact coverage) de-solder and re-solder it. download link |
11-01-2008, 18:32 | #9 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | notes on DB2000/DB2010 RED CID49 support. it must work only on non-touched (new) phones. if phone was "tuned" with other software - no any warranty, but, generally, it should work. during ANY operations with red49 phone it became unusable (dead) until you flash so-called "restoration" file or flash "main" part of phone software. i prepared restoration files for most versions of red49 firmwares,they reside in "rest" folder of setool2 distribution. usage of restoration file is simple. just determine your firmware version and select corresponding restoration file in "restoration file" edit. in current versions auto REST files search and restore implemented. for that, you need to download rest file archive from support area and unpack it into %setool%\rest directory. "REST file" edit must be clear for start of auto restore process. if your unlucky and there is no restoration file for yours version of firmware, then you must fullflash phone (WITHOUT TOUCH TO GDFS AREA), just main+fsimage+complete. from setool2 version 031 you can create restoration files automatically during flashing w900 phones on some (i think most) com cables, CHECK option "disable USB" - phone somehow assumes it is on usb, but it is on com. some example: q: i have red49 w550, i don't know what firmware version inside, i want it unlocked and russian. a: go to semc tab. press clear names. select needed w550 flashfiles (main,fsimage). russian inside emea1 go to settings tab. CHECK complete. CHECK "unlock after flash". UNCHECK "revert to red. go to semc tab, press flash when prompted, remove and insert battery, press button "testpoint ok" phone must be unlocked and flashed. q: i have k600, i want to unlock it, i know that inside r2ae001 version. a: select in "restoration file" edit correct restoration file. current version will auto determine restoration file press unlock. when prompted, remove and insert battery, press button "READY" phone must be unlocked and restored, means - working. NOTES ON PROFILES button "S" saves all files and settings for current model in current window. button "L" restores saved files and settings from current model in current window. profiles works on all tabs. Q: What is "W550/W600 OLD" and "W550/W600 NEW" ? i have a w550 red49, what model i must select ? A: first try "W550/W600 OLD" model, if it will say you to use "W550/W600 NEW" - select it and repeat procedure. |
11-01-2008, 18:35 | #10 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | q: I have tried to flash Z1010 with unbranded file. This is the result. GUI v0.91380009/UNI Card serial:00000004 Loaded 49 flash descriptors Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:29 Speed:921600 DB2000 only supports 460800,fallback. OTP status:0 locked:1 CID:29 PAF:1 IMEI:35345600144480 CERT:RED Loader:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:8964 Flash props sent ok Switching to USB... Phone stays at current interface. writing C:\Documents and Settings\c1am1k\My Documents\UNLOCK\SONY ERICSON\z1010\z1010_r1h_fs.hk.cry CURRENT FLASH FILE CID:16 ........ SSW loading returns:0 CSloader version: 041109 1252 GOHCXC125904_SEMC_VIOLA_FILE_SYSTEM_LOADER_R1E loader startup: executed loader filesystem startup: executed csloader refused to start gdfs services,error is:29 loader gdfs startup failed, that is fatal Elapsed:517 secs. RECOVERY MODE STARTED Open COM port OK DB2000 only supports 460800,fallback. Recovery:041213 1451 MATCXC1325413_CERTLOADER R3S Fetching phone data from OTP OTP status:0 locked:1 CID:29 PAF:1 IMEI:35345600144480 CERT:RED Recovery succefull. Reflash phone now Elapsed:17 secs. a: your phone OTP CID is 29, while flashfiles CID is 16. CIDs can be greater, but not lower. you need to do now 1. recovery (you done it) 2. select cid change= redcid16 3. flash main+fs+complete |
The Following User Says Thank You to TUR@N ALAM For This Useful Post: |
11-01-2008, 18:38 | #11 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | k750,v800 CID36 EROMs!!! startup fs error 1,29 !!! can't complete problems! -------------------------------------------------------------------------------- important following info only valid for db2000/db2010 phones with CID 16,29,36 sometimes, we can kill our phones during flashing process , power on, reset, bad charged battery, disaster on mars planet, etc. if after it usual reflash not work, try that thing in order ! 1. recovery phone 2. flash corresponding EROM file 3. flash main and fsimage 4. complete phone or write custpack in VERY rare cases you can damage phones gdfs. well i only can do it by special meaning, not during usual flashing. anyway, in that case write corresponding gdfs file (check forum,gdfs_in_bin_format,gdfs_in_ssw_format) then unlock phone. addon. in cases of startup fs error :0,1,etc startup gdfs error: 0,1,29 flash corresponding EROM and repeat operation. in current versions all EROMs and GDFS stored inside distributive __________________ http://www.setool.net |
11-01-2008, 18:39 | #12 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | .:IMEI CHANGE TUTORIAL FOR SONYERICSSON:. -------------------------------------------------------------------------------- 1. Choose correct model (only DB2000/DB2010 phones supported, from 093 version CID49/51 DB2012/DB2020 phones supported via patch, from v0.914029 DB2010/DB2020/PNX5230 CID49/CID50/CID51/CID52/CID53 supported via patch) 2. Choose "SETTINGS" tab. Check "PATCH OTP<>GDFS CHECK IN FIRMWARE" "ALLOW TO CHANGE IMEI WHEN UNLOCKING" for DB2012/DB2020 only "USE SERVER FOR UNLOCK/FLASH" "USE ALTERNATIVE SECURITY BYPASS" 3. go back to SEMC tab, press UNLOCK 4. when prompted, enter needed IMEI, NOTE: for pnx5230/db2012/db2020 phones REAL IMEI NOT changed, flashpatch "forges" IMEI via some trick. no worry though, network (and customer) will see NEW IMEI. but, once phone will be updated on SEUS it will return to original IMEI. same applies to flashing main part of firmware. you need 1 credit to change IMEI for db2010/db2020/pnx5230 phones cid49/cid50/cid51 phones, you not need anything for cid52/cid53 db2010/db2020/pnx5230 phones (setool2 version should be >=v0.914029) you NOT need anything for cid49 db2000/db2010 phones. BE AWARE THAT CHANGING IMEI IS ILLEGAL AND PROHIBITED BY LAW. USE IT FOR EDUCATIONAL PURPOSE OR WHEN YOU HAVE CHANGED FLASH CHIP WITH ALREADY FILLED OTP!!! __________________ http://www.setool.net |
11-01-2008, 18:41 | #13 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | about gdfs file formats. there is 2 gdfs format,which setool2 can support. first format is "common" format, "small" file , where only units and their values stored. that file must be written using "misc. files" edit and "write gdfs" button. such file can be produced with "read gdfs button" if gdfs area is damaged, or loader can't find be written and thats why we came to ... second format. it is pure flash image of gdfs area. can be written only as "firmware files". can be written regardless of damaged or not gdfs area. i suggesting to use "gdfs-in-ssw-format" in situations of "complete dead" phone (for example, after we tried to write s700 firmware into k300 |
11-01-2008, 18:54 | #14 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | K850 - Keyflex update Description There has a quality problem with the K850 keyflex (1200-2656) causing touchkey problem. When pressing a touchkey, the visual indication in the lower part of the display will not work, nor will the actual touchkey. This may be intermittent as there might be microscopic cracks in the solder joints of the affected component that is soldered onto the keyflex. Solution: use new keyflex. |
11-01-2008, 18:56 | #15 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,735 | locosto/calypso lite/arima (ODM phones) patch unlock is free no unlock via server db2000 cid17/cid41/cid42/cid54 (lg3g) db2000 cid24 (old sharp 3g) full unlock is free patch unlock is free no unlock via server db2000 cid16 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid29 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid36 full unlock is free patch unlock is free full unlock via server - 1 credits db2000/db2010 cid49 full unlock is free patch unlock is free full unlock via server - 1 credits db2020 cid49 patch unlock via server - 1 credit patch unlock standalone - free (required setool2 >=v0.914033) Full unlock 2+1=3 credits required (when signature server works) db2010 cid50 patch unlock via server - 1 credit patch unlock standalone - free (required setool2 >=v0.914033) full unlock - 1 credits db2010/db2020/pnx5230 cid51 patch unlock via server - 1 credit patch unlock standalone - free (required setool2 >=v0.914033) Full unlock 2+1=3 credits required (when signature server works) db2020 cid52 patch unlock is free Full unlock 2+1=3 credits required (when signature server works) db2010/pnx5230 cid52 patch unlock is free (required setool2 >=v0.914029) Full unlock 2+1=3 credits required (when signature server works) db2010/db2020/pnx5230 cid53 patch unlock is free (required setool2 >=v0.914029) Full unlock 2+1=3 credits required (when signature server works) db3150 (a2 platform) cid49,51,52 no patch unlock Full unlock via server: 2+1=3 credits required (when signature server works) full standalone unlock is free db3210 (a2 platform) cid49,51,52 no patch unlock Full unlock via server: 2+1=3 credits required (when signature server works) full standalone unlock is free db2000 cid53 no patch unlock Full unlock 2+1=3 credits required (when signature server works) |
Frequently Asked Questions (FAQ), Tips & Tricks | FullFLASHgSMPH | 3GKey / BB-Box | 8 | 05-17-2010 11:07 |
Frequently asked questions (faq). Tips and tricks. | Mohsin-* | SETool2 | 57 | 04-10-2010 15:44 |
...::: Frequently Asked Questions (faq). Tips And Tricks:::... | NADEEM GONDAL | SETool2 | 3 | 07-09-2008 03:55 |
Frequently Asked Questions (faq). Tips And Tricks. | .:T0PNET_GSM:. | SETool2 | 1 | 06-29-2008 21:56 |
My tips and tricks and questions for N73 6280 etc | pearsonjohnboy | BB5BOX | 7 | 03-06-2008 14:58 |
