Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 07-28-2009, 07:29   #1 (permalink)
Member: 185776
G900 flashing problem
G900 flashing stopped in the middle,see log
7/28/2009 11:11:24 AM v0.915036/UNI
7/28/2009 11:11:24 AM CARD SERIAL: xxxxxxxx
7/28/2009 11:11:24 AM Loaded 51 flash descriptors
7/28/2009 11:11:44 AM CFG:000000000000000
7/28/2009 11:11:44 AM PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
7/28/2009 11:11:56 AM detected MASTER on COM43, SLAVE on COM44
7/28/2009 11:11:56 AM PDA EROM VERSION: 1202-0238 R1A01
7/28/2009 11:11:59 AM ChipID:7100,EMP protocol:0301
7/28/2009 11:11:59 AM NEW SECURITY (MARITA RESPIN) PHONE
7/28/2009 11:11:59 AM PHONE STATE: "RETAIL"
7/28/2009 11:11:59 AM FLASH CID: 0053
7/28/2009 11:11:59 AM Speed:921600
7/28/2009 11:12:00 AM Flash ID check:2010
7/28/2009 11:12:00 AM Flash props sent ok
7/28/2009 11:12:00 AM OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602332209 CERT:RED
7/28/2009 11:12:00 AM FLASH CID:53 COLOR:RED
7/28/2009 11:12:00 AM phone model (from GDFS): G900
7/28/2009 11:12:00 AM part number: FAD-3022019-BV
7/28/2009 11:12:00 AM Phone part version: 1203-6566 R9M003
7/28/2009 11:12:00 AM Organizer part version: 1205-0647 R6J825
7/28/2009 11:12:00 AM CDA part version: 1207-8384 R10A
7/28/2009 11:12:00 AM CCPU part version: 1203-6568 R5C01
7/28/2009 11:12:00 AM USERCODE:0000
7/28/2009 11:12:01 AM
7/28/2009 11:12:01 AM Elapsed: 16 secs.
7/28/2009 11:40:46 AM CFG:000000000000000
7/28/2009 11:40:46 AM writing "J:\g900\G90A0_MR2_FRANCE__R9N002_R1F_R6K842_R6K83 6_.zip"
7/28/2009 11:40:46 AM Processing package
7/28/2009 11:40:46 AM J:\g900\G900_MR2_FRANCE__R9N002_R1F_R6K842_R6K836_ .zip
7/28/2009 11:40:56 AM detected MASTER on COM43, SLAVE on COM44
7/28/2009 11:40:56 AM PDA EROM VERSION: 1202-0238 R1A01
7/28/2009 11:40:56 AM package not contains ISP files
7/28/2009 11:40:56 AM Processing ACPU files
7/28/2009 11:40:57 AM PROCESSING: Core OS
7/28/2009 11:42:06 AM FILE FLASHED OK
7/28/2009 11:42:06 AM PROCESSING: ROFS1
7/28/2009 11:43:30 AM FILE FLASHED OK
7/28/2009 11:43:30 AM PROCESSING: ROFS1 Extension
7/28/2009 11:44:46 AM FILE FLASHED OKA
7/28/2009 11:44:46 AM PROCESSING: ROFS2
7/28/2009 11:45:43 AM FILE FLASHED OK
7/28/2009 11:45:43 AM PROCESSING: USERDATA
7/28/2009 11:46:52 AM FILE FLASHED OK
7/28/2009 11:46:53 AM PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
7/28/2009 11:46:53 AM fetched MASTER on COM43, SLAVE on COM44
7/28/2009 11:46:55 AM ChipID:7100,EMP protocol:0301
7/28/2009 11:46:55 AM NEW SECURITY (MARITA RESPIN) PHONE
7/28/2009 11:46:55 AM PHONE STATE: "RETAIL"
7/28/2009 11:46:55 AM FLASH CID: 0053
7/28/2009 11:46:55 AM Speed:921600
7/28/2009 11:46:56 AM OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602332209 CERT:RED
7/28/2009 11:46:57 AM LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003
7/28/2009 11:46:57 AM Flash ID check:2010
7/28/2009 11:46:57 AM Flash props sent ok
7/28/2009 11:46:58 AM Processing CCPU files
7/28/2009 11:46:58 AM PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re
7/28/2009 11:46:59 AM CURRENT FLASH FILE CID:53
7/28/2009 11:46:59 AM SSW uses full hash, hash len is: 160
7/28/2009 11:46:59 AM Will flash 8 blocks...
7/28/2009 11:47:09 AM SSW loading returns:0
7/28/2009 11:47:09 AM PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are
7/28/2009 11:47:11 AM CURRENT FLASH FILE CID:53
7/28/2009 11:47:11 AM SSW uses full hash, hash len is: 2120
7/28/2009 11:47:12 AM Will flash 106 blocks...
7/28/2009 11:49:04 AM SSW loading returns:0
7/28/2009 11:49:04 AM Processing update files
7/28/2009 11:49:04 AM PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
7/28/2009 11:49:05 AM fetched MASTER on COM43, SLAVE on COM44
7/28/2009 11:49:07 AM ChipID:7100,EMP protocol:0301
7/28/2009 11:49:07 AM NEW SECURITY (MARITA RESPIN) PHONE
7/28/2009 11:49:07 AM PHONE STATE: "RETAIL"
7/28/2009 11:49:07 AM FLASH CID: 0053
7/28/2009 11:49:07 AM Speed:921600
7/28/2009 11:49:08 AM OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602332209 CERT:RED
7/28/2009 11:49:08 AM phone CID not supported in that mode
7/28/2009 11:49:08 AM Break.
7/28/2009 11:49:09 AM Elapsed: 503 secs.
Old 07-28-2009, 07:59   #2 (permalink)
Member: 785601
check cid corrent flash file then flash
Old 07-28-2009, 10:08   #3 (permalink)
bimes's Avatar
Member: 729381
@cellbhai
use signed mode
Old 07-28-2009, 10:29   #4 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Yes mate you should check sign mode on Settings tab.
Old 07-28-2009, 15:42   #5 (permalink)
Member: 185776
Thanks done see log,
7/28/2009 7:44:42 PM v0.915040/UNI
7/28/2009 7:44:42 PM CARD SERIAL: xxxxxxxx
7/28/2009 7:44:42 PM Loaded 51 flash descriptors
7/28/2009 7:45:10 PM SIGNED MODE (USING SERVER)
7/28/2009 7:45:10 PM CFG:10000000000000
7/28/2009 7:45:10 PM writing "J:\g900\G900_MR2_FRANCE__R9N002_R1F_R6K842_R6K836 _.zip"
7/28/2009 7:45:10 PM Processing package
7/28/2009 7:45:10 PM J:\g900\G900_MR2_FRANCE__R9N002_R1F_R6K842_R6K836_ .zip
7/28/2009 7:45:21 PM detected MASTER on COM43, SLAVE on COM44
7/28/2009 7:45:21 PM PDA EROM VERSION: 1202-0238 R1A01
7/28/2009 7:45:21 PM package not contains ISP files
7/28/2009 7:45:21 PM Processing ACPU files
7/28/2009 7:45:22 PM PROCESSING: Core OS
7/28/2009 7:46:32 PM FILE FLASHED OK
7/28/2009 7:46:32 PM PROCESSING: ROFS1
7/28/2009 7:47:55 PM FILE FLASHED OK
7/28/2009 7:47:55 PM PROCESSING: ROFS1 Extension
7/28/2009 7:49:12 PM FILE FLASHED OK
7/28/2009 7:49:12 PM PROCESSING: ROFS2
7/28/2009 7:50:08 PM FILE FLASHED OK
7/28/2009 7:50:08 PM PROCESSING: USERDATA
7/28/2009 7:51:16 PM FILE FLASHED OK
7/28/2009 7:51:16 PM PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
7/28/2009 7:51:16 PM fetched MASTER on COM43, SLAVE on COM44
7/28/2009 7:51:18 PM ChipID:7100,EMP protocol:0301
7/28/2009 7:51:18 PM NEW SECURITY (MARITA RESPIN) PHONE
7/28/2009 7:51:18 PM PHONE STATE: "RETAIL"
7/28/2009 7:51:18 PM FLASH CID: 0053
7/28/2009 7:51:18 PM Speed:921600
7/28/2009 7:51:19 PM OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602332209 CERT:RED
7/28/2009 7:51:21 PM LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003
7/28/2009 7:51:21 PM Flash ID check:2010
7/28/2009 7:51:21 PM Flash props sent ok
7/28/2009 7:51:21 PM Processing CCPU files
7/28/2009 7:51:21 PM PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re
7/28/2009 7:51:22 PM CURRENT FLASH FILE CID:53
7/28/2009 7:51:22 PM SSW uses full hash, hash len is: 160
7/28/2009 7:51:22 PM Will flash 8 blocks...
7/28/2009 7:51:32 PM SSW loading returns:0
7/28/2009 7:51:33 PM PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are
7/28/2009 7:51:35 PM CURRENT FLASH FILE CID:53
7/28/2009 7:51:35 PM SSW uses full hash, hash len is: 2120
7/28/2009 7:51:35 PM Will flash 106 blocks...
7/28/2009 7:53:30 PM SSW loading returns:0
7/28/2009 7:53:31 PM Processing update files
7/28/2009 7:53:41 PM LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E
7/28/2009 7:53:41 PM loader startup: executed
7/28/2009 7:53:41 PM loader GDFS startup: executed
7/28/2009 7:53:41 PM loader unlock: executed
7/28/2009 7:53:41 PM Writing GDFS var 0002/06D6/0001
7/28/2009 7:53:49 PM Success
7/28/2009 7:53:49 PM Writing GDFS var 0002/06D4/0005
7/28/2009 7:53:49 PM Writing GDFS var 0002/06D3/000F
7/28/2009 7:53:49 PM Writing GDFS var 0000/0094/0001
7/28/2009 7:53:50 PM Success
7/28/2009 7:53:50 PM Writing GDFS var 0002/079E/0053
7/28/2009 7:53:51 PM Elapsed: 520 secs.
Old 07-29-2009, 04:48   #6 (permalink)
Member: 687312
OK Welldone mate keep it up.
WBR
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
g900 flash problem traxgsm SETool2 3 03-16-2010 11:23
G900 restart problem sajidmirza Sony Ericsson Hardware Repair Area 3 02-15-2010 10:10
G900 flash problem lilong_lee Universalbox 6 11-21-2009 16:47
G900 Flash??? hakancpu SETool2 7 05-29-2009 07:53
Page generated in 0.26347 seconds with 11 queries
