07-28-2010, 14:02 | #1 (permalink) |
No Life Poster Join Date: May 2010
Member: 1300483 Status: Offline Thanks Meter: 27 | gt 405 problem stuk on lg logo whn try ti write gdf check logs plz CARD SERIAL 00124998 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:E900,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0053 OTP LOCKED:1 CID:53 PAF:1 IMEI:35821803543734 CERT:RED LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] GOT SEED:7FD8798F35804A773560BF84 P96 AUTH PASSED Backup security data... Erasing locks... Unlock DONE Elapsed: 40 secs. SIGNED MODE (USING SERVER) CFG:101000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982903036245] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982903036245 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "C:\Documents and Settings\UNI & INFINITY\Desktop\setools flash files\G405\gt405_cxc_lgpxo_sys_cabs_lp_nand_commer cial_org_ch.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 339 blocks... ssw file accepted writing "C:\Documents and Settings\UNI & INFINITY\Desktop\setools flash files\G405\gt405_cxc000000_application_phone_sb_ia r-arm-nand_commercial_org_ch.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 619 blocks... ssw file accepted writing "C:\Documents and Settings\UNI & INFINITY\Desktop\setools flash files\G405\gt405_cxc_fs_cabs_lp_nand_commercial_or g_ch.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 1475 blocks... [a2_fout_ssw] can't get NET header Elapsed: 778 secs. SIGNED MODE (USING SERVER) CFG:101000000000 Processing script "C:\Documents and Settings\UNI & INFINITY\Desktop\setools flash files\G405\gt405_update_gdfs_app_20100324.gdf.gdfs "... ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35982903036245] OTP LOCKED:1 CID:54 PAF:0 IMEI:35982903036245 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM Writing GDFS var 0000/011A/0004 [gdfs_writevar] err:000B Writing GDFS var 0000/032D/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/070B/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/070C/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/070D/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/070E/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/070F/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0710/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0715/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0717/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/071A/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/071E/0003 [gdfs_writevar] err:000B Writing GDFS var 0000/0721/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0722/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0724/0032 [gdfs_writevar] err:000B Writing GDFS var 0000/0725/0001 [gdfs_writevar] err:000B Writing GDFS var 0000/0726/0001 [gdfs_writevar] err:000B Writing GDFS var 0000/072E/0001 [gdfs_writevar] err:000B Writing GDFS var 0000/072F/00A0 [gdfs_writevar] err:000B Writing GDFS var 0000/0730/0001 [gdfs_writevar] err:000B Writing GDFS var 0000/0731/000A [gdfs_writevar] err:000B Writing GDFS var 0000/0732/0001 [gdfs_writevar] err:000B [startGDFS_force] err:000B Elapsed: 39 secs. |
07-28-2010, 14:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Morocco
Member: 136492 Status: Offline Thanks Meter: 286 | do that. get "BIN_GT400AT-00-V10e-EUR-XX-JUN-07-2010+0" 1. flash gt40x_syspart_fix.ssw 2. flash gt505_drm_fix.ssw 3. flash GT40x_CXC_FS_CABS_LP_NAND_commercial_EUR_OPEN.ssw GT40x_CXC_LGPXO_SYS_CABS_LP_NAND_commercial.ssw 4. flash GT40x_cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw 5. do unlock 6. finally, flash gt40x_boot_fix.ssw EACH step is SEPARATE operation. GT400 & GT405 are the same. |
The Following User Says Thank You to CHEZRACHID For This Useful Post: |
07-28-2010, 18:24 | #7 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 646256 Status: Offline Thanks Meter: 63 | it is absolutely necessary to use fix files from setool2 version at least 1.083 Source: last post from HOW TO WORK WITH A2-BASED PHONES So use the latest version 1.085 |
07-31-2010, 19:04 | #9 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: KEF_TUNISIA
Member: 681313 Status: Offline Thanks Meter: 506 | Quote:
solution work perfect , i have repaired gt 400 with this steps | |
12-10-2011, 10:35 | #11 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: Barcelona
Member: 1185793 Status: Offline Thanks Meter: 94 | Quote:
this method works 100%...thanks dude... SSW files you can find in SETOOL installed folders. | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
