Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 09-13-2009, 16:55   #46 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: Hidden
i do not think it is software problem.
perhaps, reball/rehot of flash ic will help
Old 09-14-2009, 07:31   #47 (permalink)
Member: 185776
Today K550i sucesully GDFS repaired see log,
9/14/2009 11:07:26 AM v0.915045/UNI
9/14/2009 11:07:26 AM CARD SERIAL: 00xxxxxx
9/14/2009 11:07:26 AM Loaded 51 flash descriptors
9/14/2009 11:07:57 AM SIGNED MODE (USING SERVER)
9/14/2009 11:07:57 AM CFG:10100000000000
9/14/2009 11:07:58 AM No server found.
9/14/2009 11:08:00 AM CARD COUNTERS: FLASH 72, UNLOCK 32
9/14/2009 11:08:00 AM Elapsed: 3 secs.
9/14/2009 11:08:08 AM SIGNED MODE (USING SERVER)
9/14/2009 11:08:08 AM CFG:10100000000000
9/14/2009 11:08:09 AM SERVER CREDITS LEFT/USED: 23/7
9/14/2009 11:08:11 AM CARD COUNTERS: FLASH 72, UNLOCK 32
9/14/2009 11:08:11 AM Elapsed: 2 secs.
9/14/2009 11:10:12 AM SIGNED MODE (USING SERVER)
9/14/2009 11:10:12 AM CFG:10000000000000
9/14/2009 11:10:17 AM PROCEDURE WAS STOPPED BY USER
9/14/2009 11:10:17 AM Can't load ID loader !
9/14/2009 11:10:17 AM Elapsed: 5 secs.
9/14/2009 11:11:11 AM SIGNED MODE (USING SERVER)
9/14/2009 11:11:11 AM CFG:10100000000000
9/14/2009 11:11:12 AM No server found.
9/14/2009 11:11:14 AM CARD COUNTERS: FLASH 72, UNLOCK 32
9/14/2009 11:11:14 AM Elapsed: 3 secs.
9/14/2009 11:11:16 AM SIGNED MODE (USING SERVER)
9/14/2009 11:11:16 AM CFG:10100000000000
9/14/2009 11:11:17 AM bad username/password.
9/14/2009 11:11:19 AM CARD COUNTERS: FLASH 72, UNLOCK 32
9/14/2009 11:11:19 AM Elapsed: 2 secs.
9/14/2009 11:11:57 AM SIGNED MODE (USING SERVER)
9/14/2009 11:11:57 AM CFG:10100000000000
9/14/2009 11:11:58 AM SERVER CREDITS LEFT/USED: 23/7
9/14/2009 11:12:01 AM CARD COUNTERS: FLASH 72, UNLOCK 32
9/14/2009 11:12:01 AM Elapsed: 3 secs.
9/14/2009 11:12:08 AM SIGNED MODE (USING SERVER)
9/14/2009 11:12:08 AM CFG:10000000000000
9/14/2009 11:12:08 AM RESET MODE STARTED
9/14/2009 11:12:15 AM PROCEDURE WAS STOPPED BY USER
9/14/2009 11:12:15 AM Elapsed: 7 secs.
9/14/2009 11:12:44 AM SIGNED MODE (USING SERVER)
9/14/2009 11:12:44 AM CFG:10000000000000
9/14/2009 11:12:44 AM RESET MODE STARTED
9/14/2009 11:12:47 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:12:47 AM Speed:921600
9/14/2009 11:12:50 AM RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA
9/14/2009 11:12:50 AM FLASH ID:897E
9/14/2009 11:12:51 AM GOT SEED:BB4CE3072380317115C00273
9/14/2009 11:12:52 AM P96 AUTH PASSED
9/14/2009 11:12:52 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:12:53 AM PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
9/14/2009 11:12:54 AM Elapsed: 10 secs.
9/14/2009 11:14:55 AM CFG:00000000000000
9/14/2009 11:14:58 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:14:58 AM Speed:921600
9/14/2009 11:14:59 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:14:59 AM FLASH CID:49 COLOR:BROWN
9/14/2009 11:15:01 AM LDR:060721 1021 DB2020_SERVICE_LOADER
9/14/2009 11:15:01 AM FLASH ID:897E
9/14/2009 11:15:01 AM writing "D:\v0.915045\gdfs_in_ssw_format\db2020\k550_gdfs_SSW.ssw"
9/14/2009 11:15:03 AM CURRENT FLASH FILE CID:49
9/14/2009 11:15:03 AM SSW uses full hash, hash len is: 640
9/14/2009 11:15:03 AM Will flash 32 blocks...
9/14/2009 11:15:37 AM Setting up GDFS...
9/14/2009 11:15:38 AM OTP WRITE NOT EXECUTED
9/14/2009 11:15:38 AM WRITING CLEAR SIMLOCK UNITS...
9/14/2009 11:15:38 AM ALL UNLOCK/LOCK CODES SET TO "06727061"
9/14/2009 11:15:40 AM SIGNING...
9/14/2009 11:15:41 AM Elapsed: 45 secs.
9/14/2009 11:16:29 AM SIGNED MODE (USING SERVER)
9/14/2009 11:16:29 AM ALTERNATIVE SECURITY BYPASS ENABLED
9/14/2009 11:16:30 AM CFG:10100000000000
9/14/2009 11:16:30 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:16:30 AM Speed:921600
9/14/2009 11:16:31 AM FLASH ID:897E
9/14/2009 11:16:31 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:16:31 AM FLASH CID:49 COLOR:BROWN
9/14/2009 11:16:44 AM PROCEDURE WAS STOPPED BY USER
9/14/2009 11:16:44 AM can't get packet start.
9/14/2009 11:16:45 AM no ack during gdfs_readvar !
9/14/2009 11:16:45 AM SCRC READ FAILURE
9/14/2009 11:16:45 AM Elapsed: 15 secs.
9/14/2009 11:16:46 AM SIGNED MODE (USING SERVER)
9/14/2009 11:16:46 AM ALTERNATIVE SECURITY BYPASS ENABLED
9/14/2009 11:16:46 AM CFG:10100000000000
9/14/2009 11:16:48 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:16:48 AM Speed:921600
9/14/2009 11:16:49 AM FLASH ID:897E
9/14/2009 11:16:49 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:16:49 AM FLASH CID:49 COLOR:BROWN
9/14/2009 11:17:20 AM can't get packet start.
9/14/2009 11:17:20 AM no ack during gdfs_readvar !
9/14/2009 11:17:20 AM SCRC READ FAILURE
9/14/2009 11:17:21 AM Elapsed: 34 secs.
9/14/2009 11:19:15 AM CFG:00000000000000
9/14/2009 11:19:18 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:19:18 AM Speed:921600
9/14/2009 11:19:19 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:19:19 AM FLASH CID:49 COLOR:BROWN
9/14/2009 11:19:22 AM LDR:060721 1021 DB2020_SERVICE_LOADER
9/14/2009 11:19:22 AM FLASH ID:897E
9/14/2009 11:19:22 AM writing "D:\v0.915045\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw"
9/14/2009 11:19:23 AM CURRENT FLASH FILE CID:49
9/14/2009 11:19:23 AM SSW uses full hash, hash len is: 40
9/14/2009 11:19:23 AM Will flash 2 blocks...
9/14/2009 11:19:26 AM Setting up GDFS...
9/14/2009 11:19:27 AM OTP WRITE NOT EXECUTED
9/14/2009 11:19:27 AM WRITING CLEAR SIMLOCK UNITS...
9/14/2009 11:19:27 AM ALL UNLOCK/LOCK CODES SET TO "40451017"
9/14/2009 11:19:29 AM SIGNING...
9/14/2009 11:19:29 AM Elapsed: 13 secs.
9/14/2009 11:19:47 AM SIGNED MODE (USING SERVER)
9/14/2009 11:19:47 AM ALTERNATIVE SECURITY BYPASS ENABLED
9/14/2009 11:19:47 AM CFG:10100000000000
9/14/2009 11:19:50 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:19:50 AM Speed:921600
9/14/2009 11:19:51 AM FLASH ID:897E
9/14/2009 11:19:51 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:19:51 AM FLASH CID:52 COLOR:RED
9/14/2009 11:19:52 AM
9/14/2009 11:19:52 AM Model (from GDFS):K550i
9/14/2009 11:19:53 AM Brand:Generic
9/14/2009 11:19:53 AM MAPP CXC article: R1JD001     prgCXC1250670_CHINA_LI
9/14/2009 11:19:53 AM MAPP CXC version: R1JD001
9/14/2009 11:19:53 AM Language Package: C_ASIA
9/14/2009 11:19:53 AM CDA article: CDA12345678/123
9/14/2009 11:19:53 AM CDA version: R2A
9/14/2009 11:19:53 AM Default article: cxc1250671
9/14/2009 11:19:53 AM Default version: R1JD001
9/14/2009 11:19:53 AM PROVIDER: 000-00
9/14/2009 11:19:53 AM SIMLOCKS NOT DETECTED
9/14/2009 11:19:53 AM RESTORATION FILE NOT PRESENT
9/14/2009 11:19:53 AM "R1JD001_CXC1250670_CHINA_LI"
9/14/2009 11:19:53 AM YOU MUST PERFORM FULL FLASHING
9/14/2009 11:19:53 AM WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
9/14/2009 11:19:53 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
9/14/2009 11:19:54 AM Elapsed: 6 secs.
9/14/2009 11:23:27 AM SIGNED MODE (USING SERVER)
9/14/2009 11:23:27 AM ALTERNATIVE SECURITY BYPASS ENABLED
9/14/2009 11:23:27 AM CFG:10100000000000
9/14/2009 11:23:31 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:23:31 AM Speed:921600
9/14/2009 11:23:32 AM FLASH ID:897E
9/14/2009 11:23:32 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:23:32 AM FLASH CID:52 COLOR:RED
9/14/2009 11:23:33 AM
9/14/2009 11:23:33 AM Model (from GDFS):K550i
9/14/2009 11:23:34 AM Brand:Generic
9/14/2009 11:23:34 AM MAPP CXC article: R1JD001     prgCXC1250670_CHINA_LI
9/14/2009 11:23:34 AM MAPP CXC version: R1JD001
9/14/2009 11:23:34 AM Language Package: C_ASIA
9/14/2009 11:23:34 AM CDA article: CDA12345678/123
9/14/2009 11:23:34 AM CDA version: R2A
9/14/2009 11:23:34 AM Default article: cxc1250671
9/14/2009 11:23:34 AM Default version: R1JD001
9/14/2009 11:23:34 AM PROVIDER: 000-00
9/14/2009 11:23:34 AM SIMLOCKS NOT DETECTED
9/14/2009 11:23:34 AM SEARCH:D:\se tool\K550i\R1JD001_1250670_CHINA_LI.ssw
9/14/2009 11:23:42 AM "R1JD001_CXC1250670_CHINA_LI" CREATED
9/14/2009 11:23:42 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
9/14/2009 11:23:42 AM Elapsed: 15 secs.
9/14/2009 11:23:44 AM SIGNED MODE (USING SERVER)
9/14/2009 11:23:45 AM ALTERNATIVE SECURITY BYPASS ENABLED
9/14/2009 11:23:45 AM CFG:10100000000000
9/14/2009 11:23:46 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:23:46 AM Speed:921600
9/14/2009 11:23:47 AM FLASH ID:897E
9/14/2009 11:23:47 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:23:47 AM FLASH CID:52 COLOR:RED
9/14/2009 11:23:49 AM
9/14/2009 11:23:49 AM Model (from GDFS):K550i
9/14/2009 11:23:49 AM Brand:Generic
9/14/2009 11:23:49 AM MAPP CXC article: R1JD001     prgCXC1250670_CHINA_LI
9/14/2009 11:23:49 AM MAPP CXC version: R1JD001
9/14/2009 11:23:49 AM Language Package: C_ASIA
9/14/2009 11:23:49 AM CDA article: CDA12345678/123
9/14/2009 11:23:49 AM CDA version: R2A
9/14/2009 11:23:49 AM Default article: cxc1250671
9/14/2009 11:23:50 AM Default version: R1JD001
9/14/2009 11:23:50 AM PROVIDER: 000-00
9/14/2009 11:23:50 AM SIMLOCKS NOT DETECTED
9/14/2009 11:23:50 AM RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
9/14/2009 11:23:50 AM BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
9/14/2009 11:23:50 AM Elapsed: 5 secs.
9/14/2009 11:24:33 AM SIGNED MODE (USING SERVER)
9/14/2009 11:24:33 AM CFG:10001000000000
9/14/2009 11:24:38 AM ChipID:9900,EMP protocol:0301
9/14/2009 11:24:38 AM Speed:921600
9/14/2009 11:24:39 AM OTP: LOCKED:1 CID:51 PAF:1 IMEI:35665701471084 CERT:N/A
9/14/2009 11:24:39 AM FLASH CID:52 COLOR:RED
9/14/2009 11:24:42 AM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
9/14/2009 11:24:44 AM LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
9/14/2009 11:24:44 AM FLASH ID:897E
9/14/2009 11:24:44 AM writing "D:\se tool\K550i\R1JD001_1250670_CHINA_LI.ssw"
9/14/2009 11:24:48 AM CURRENT FLASH FILE CID:52
9/14/2009 11:24:48 AM SSW uses full hash, hash len is: 9200
9/14/2009 11:24:49 AM Will flash 460 blocks...
9/14/2009 11:32:59 AM writing "D:\se tool\K550i\R1JD001_FS_EUROPE_1_LI_RED_CID52.ssw"
9/14/2009 11:33:02 AM CURRENT FLASH FILE CID:52
9/14/2009 11:33:02 AM SSW uses full hash, hash len is: 3300
9/14/2009 11:33:03 AM Will flash 165 blocks...
9/14/2009 11:36:07 AM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
9/14/2009 11:36:07 AM loader startup: executed
9/14/2009 11:36:17 AM loader GDFS startup: executed
9/14/2009 11:36:24 AM loader filesystem startup: executed
9/14/2009 11:36:24 AM loader unlock: executed
9/14/2009 11:36:24 AM using GENERIC phone customization
9/14/2009 11:36:24 AM tpa/preset/custom/C3_PCA_G3v2.cer
9/14/2009 11:36:24 AM tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
9/14/2009 11:36:24 AM tpa/preset/custom/customize.xml
9/14/2009 11:36:25 AM tpa/preset/custom/DESKTOP_HOOK_2.itm
9/14/2009 11:36:25 AM tpa/preset/custom/Entrust.net Root Certificate.cer
9/14/2009 11:36:25 AM tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
9/14/2009 11:36:26 AM tpa/preset/custom/FM_PICTURES_HOOK_3.itm
9/14/2009 11:36:26 AM tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
9/14/2009 11:36:27 AM tpa/preset/custom/FM_THEMES_HOOK_3.itm
9/14/2009 11:36:28 AM tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
9/14/2009 11:36:29 AM tpa/preset/custom/GAMES_HOOK_3.itm
9/14/2009 11:36:30 AM tpa/preset/custom/GTE_CyberTrust_Root.cer
9/14/2009 11:36:30 AM tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
9/14/2009 11:36:30 AM tpa/preset/custom/Root.cer
9/14/2009 11:36:30 AM tpa/preset/custom/SEMC_E2E_Root_CA.crt
9/14/2009 11:36:30 AM tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
9/14/2009 11:36:31 AM tpa/preset/custom/ThawtePremium.der
9/14/2009 11:36:31 AM tpa/preset/custom/ThawteServerCA.cer
9/14/2009 11:36:31 AM tpa/preset/custom/Utiroot.cer
9/14/2009 11:36:32 AM tpa/preset/custom/VeriSignClass3Root.cer
9/14/2009 11:36:32 AM tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
9/14/2009 11:36:32 AM Phone detached
9/14/2009 11:36:34 AM Elapsed: 721 secs.
The Following User Says Thank You to cellbhai For This Useful Post:
Old 09-15-2009, 11:31   #48 (permalink)
Member: 504633
great setool team very nice.
Old 09-16-2009, 15:46   #49 (permalink)
kurip's Avatar
Member: 526318
Sonork: dc2000
nice very good post thanks bro...
Old 09-17-2009, 05:58   #50 (permalink)
Member: 758137
greeeaaat.....thank for sharing.....
Old 09-17-2009, 23:28   #51 (permalink)
nik_immy's Avatar
Member: 139853
Sonork: 100.1590178
can anyone confirm setool gdfs and s1 unlocking not free . need one credit for any of these service ....
Old 09-17-2009, 23:32   #52 (permalink)
Member: 1071056
Old 09-18-2009, 17:56   #53 (permalink)
Member: 421117
Sonork: Hidden
Don't worry
First post edited !!! See again
Next time use small font's
The Following 2 Users Say Thank You to Umair Rashid For This Useful Post:
Old 09-18-2009, 21:27   #54 (permalink)
treo29's Avatar
Member: 279394
Sonork: 1591760
excellent
thankz
br+
treo29
Old 09-18-2009, 21:37   #55 (permalink)
Member: 55442
Old 09-19-2009, 12:10   #56 (permalink)
Member: 660830
there is solution at d end.u re doing a good job
Old 09-20-2009, 16:43   #57 (permalink)
hassan riach's Avatar
Member: 366329
Sonork: Essaouira
thanks umair rasheed this the great work keep it up
The Following 3 Users Say Thank You to hassan riach For This Useful Post:
Old 09-23-2009, 05:22   #58 (permalink)
maeane's Avatar
Member: 795913
what should i press instead of "c" in t280 new sec....
cause c and power are same, it cant detect, instead it will power
Old 09-23-2009, 07:43   #59 (permalink)
Member: 421117
Sonork: Hidden
Hold '2+5' and Connect Your phone.
Old 09-23-2009, 07:49   #60 (permalink)
Member: 421117
Sonork: Hidden
Video procedure repair Red Blinking RESET Mode with setool using credit.
http://rapidshare.com/files/27856163...dit_setool.rar
Video procedure Unlocking SEMC ODMT303a with SE-Tool using Credit
http://rapidshare.com/files/27853956...kan_Credit.rar
(Thanks To CHEVKA)
The Following 4 Users Say Thank You to Umair Rashid For This Useful Post:
how to repair gdfs with tp ayaz ali SETool2 1 12-21-2009 08:20
How to repair gdfs without logs? .:MobileLife:. SETool2 5 12-07-2009 15:00
How to repair gdfs wo tp with D-unlocker ? jetli1 D-Unlock Suite 4 06-07-2009 20:56
Repair GDFS Without TP CID50,51,52 & 53...... dil_PAKISTANI SETool2 11 11-18-2008 14:05
Page generated in 0.36917 seconds with 12 queries
