02-28-2010, 15:42 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
Well i haven't come acros something like this.... but u can try one thing to make full gdfs backup and then try to downgrade it, just in case something goes wrong you still have everything in your hands. | |
02-28-2010, 16:03 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35350501356108 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):Z550a Brand:Generic Trade MAPP CXC article: R6GA004 prgCXC1250583_GENERIC_ML MAPP CXC version: R6GA004 Language Package: EUROPE_1 CDA article: CDA102577/10 CDA version: R6A Default article: cxc1250506 Default version: R6CA009 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE NOT PRESENT "R6GA004_CXC1250583_GENERIC_ML" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE hi brother by mistake i upgrade cid 51 to 52 any more idea i want unlock |
02-28-2010, 16:10 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Post your log under CODE # Tags !!! This is a DB2012, you can do reset doing following steps : Code: CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all (NO MORE SIGNED MODE) 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. Of course this costs 1 credit ! And next time try to learn from faq instead of playing with phone BR Max_B |
02-28-2010, 16:18 | #7 (permalink) | |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
HOW TO WORK WITH A1-BASED PHONES BR Max_B | |
02-28-2010, 19:26 | #10 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | hi one more problam i have w380i customer says that my mobilink sim working perfect but when i change sim mobile says correct sim card when i identify show log PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35502502199021 CERT:RED Model (from GDFS):W380i erom_readvar: error reading unit 2/DE5 MAPP CXC article: R11CA002 prg1201-4421_GENERIC_LE MAPP CXC version: R11CA002 Language Package: ORANGE_CH CDA article: 1205-0510 CDA version: R2A Default article: 1201-4439 Default version: R11CA002 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 10 secs. so i unlock after l PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 OTP: LOCKED:1 CID:52 PAF:1 IMEI:35502502199021 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER FLASH ID:2019 LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM70 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID000,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:921600 STARTING BOOTLOADER... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2 FLASH ID:2019 FOUND VERSION "R11CA002_1201-4421_GENERIC_LE" USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock FINISHED Elapsed: 134 secs. when i again identify w380i no unlocked what probalm PHONE STATE: "RETAIL" FLASH CID: 0053 skipping empty loader... OTP: LOCKED:1 CID:52 PAF:1 IMEI:35502502199021 CERT:RED Model (from GDFS):W380i Brand:Generic MAPP CXC article: R11CA002 prg1201-4421_GENERIC_LE MAPP CXC version: R11CA002 Language Package: ORANGE_CH CDA article: 1205-0510 CDA version: R2A Default article: 1201-4439 Default version: R11CA002 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 8 secs. thanks in advance |
02-28-2010, 19:56 | #11 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | I really don't understand why do you like pasting BIG logs without CODE # tags !!! It's very bothering for the reader ! Your phone is probably unlocked, put a simcard inside BR Max_B |
Pls help for se tool | .RAM | Sony Ericsson Hardware Repair | 0 | 01-13-2010 16:57 |
SE Tool experts please tell??? | nofear99 | Sony Ericsson | 3 | 12-05-2009 18:49 |
Need help with se tool | NKO | Old Ericsson Phones & Sony Phones | 12 | 12-01-2009 14:04 |
Need Experts Help!!! on SE tool!! | mobilelink | Sony Ericsson Hardware Repair | 5 | 11-18-2007 07:00 |
need help me SE TOOL 2 | Flash0r | Sony Ericsson | 9 | 05-11-2005 01:27 |
