09-12-2012, 05:00 | #1 (permalink) |
Registered User Join Date: Feb 2003 Location: cavite Age: 43
Member: 23455 Status: Offline Thanks Meter: 2 | help st18a dead after unlock. how to solve this problem?? DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 can't get S1 command header LOADER NOT RESPONDING FAILED TO SETUP PHONE Unlock FAILED Elapsed: 49 secs. |
09-12-2012, 08:53 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | most probably, you killed phone by doing testpoint wrong. however, there is slight chance, that it is just not enough power for phone from USB port. to check that, when program tell you Code: PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" if still same, then you damaged flash ic by wrong testpoint application for sure. |
