Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 09-06-2012, 01:43   #1 (permalink)
kevinand's Avatar
Member: 1563865
Sonork: 100.1604896
Thanks Meter: 7
Help unlock SONY st21i (NOT SE)
Hello
Can somebody say me whow i can unlock SONY st21i. I saw option in Setool soft, inside PDA, but i cant identify because soft say me that i must press "back" button (dont exist, it isn´t a button) or press volume down, but nothing. I make plug, un-plug, all buttons...
Please, can somebody help me?
Thanks
Regards
The Following User Says Thank You to kevinand For This Useful Post:
Old 09-06-2012, 01:51   #2 (permalink)
Member: 293270
Thanks Meter: 43
Switch ON your SONY ST21i Xperia tipo with a not Accepted SIM Card
Enter the Unlock Code we send to you
Your SONY ST21i Xperia tipo is unlocked
or, If the phone doesn't ask for an unlock code:
Switch on your SONY ST21i Xperia tipo with accepted SIM card,
Compose #987654321#
You will see a lock window
Ente the code we sent you and comfirm.
How to check the code counter in Sony phones:
Switch on your phone without SIM card,
Compose *#*#7378423#*#*
Select Service Info and then Simlock
If X is with Network and it is not 0 you can unlock your phone via code
If X is 0 your counter is locked and unlocking via code is not possible.
Old 09-06-2012, 03:17   #3 (permalink)
kevinand's Avatar
Member: 1563865
Sonork: 100.1604896
Thanks Meter: 7
Hello
Thanks but where is the code sent to me? Setool soft doesnt recognice the phone. i cant make any unlock/identify process.
Any other idea? Do i need press another buttons combinations? Thanks
Regards
Old 09-06-2012, 07:28   #4 (permalink)
Danish Shafiq's Avatar
Member: 1118710
Sonork: 100.1604414
Thanks Meter: 4,910
U Can Not Unlock This Model With Setool.
S1 Server is Offline.
Old 09-06-2012, 14:02   #5 (permalink)
kevinand's Avatar
Member: 1563865
Sonork: 100.1604896
Thanks Meter: 7
This is a second part. First is a conection between phone and Setool. Button combination is needed.
Any other idea? please
Regards
Old 09-07-2012, 18:56   #6 (permalink)
Member: 9519
Thanks Meter: 1,460
Regards
connect powered off st21 phone while holding volume down button, make sure usbflash drivers installed ( usbflash device appear in device manager )
then download software
Device Remover - The Powerful Device Manager
run it, wait until it finish collecting device info,then click once on button
"trigger hw detection"
after that connect powered off st21 phone while holding volume down button
copy ( right button, copy all ) "application messages" from program and attach it here.
Old 09-08-2012, 18:14   #7 (permalink)
Member: 9519
Thanks Meter: 1,460
problem solved, please redownload current setool2 version from support area or from official rapidshare link in news thread
sorry for inconveniences
Old 09-26-2012, 21:51   #8 (permalink)
mzkahack29's Avatar
Member: 7334
Sonork: 100.112291
Thanks Meter: 45
how many logs for this phone Mr the laser ???
Old 09-26-2012, 22:29   #9 (permalink)
koperta4512's Avatar
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
Now not possible to unlock this phone.
Old 10-13-2012, 15:29   #10 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
Thanks Meter: 150
any existing solution for this phone?
Old 10-13-2012, 15:44   #11 (permalink)
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
Send phone to SOMC center or buy NCK code.
Old 10-14-2012, 17:57   #12 (permalink)
Member: 60001
Sonork: 100.106474
Thanks Meter: 150
locked phone is 50 euro here in germany.. unlock is 50 euro but unlocked device cost 95 euro.. nothing more to say
Old 10-16-2012, 11:11   #13 (permalink)
Member: 192296
Sonork: 100.1623059
Thanks Meter: 21
10/16/2012 11:04:17 AM :: Starting Application ...Device Remover [Beta 5] 0.9.4290.34732 - by Kerem Gümrükcü
10/16/2012 11:04:17 AM :: Application Binary MD5 Hash: 895e4f707d963be14bc323ff520569d1
10/16/2012 11:04:17 AM :: Application Binary SHA1 Hash: bf2c6fe41b41b4eb579a9ce7c095b245facd825c
10/16/2012 11:04:17 AM :: Starting on Host "ORJI" from User "czar"
10/16/2012 11:04:17 AM :: Hardware System: Vendor: GenuineIntel, Processor Name: Intel(R) Core(TM)2 Duo CPU     T7500  @ 2.20GHz, Identifier: x86 Family 6 Model 15 Stepping 11
10/16/2012 11:04:17 AM :: Operating System: Microsoft Windows NT 5.1.2600 Service Pack 2 Windows XP Professional Edition
10/16/2012 11:04:17 AM :: Operating System Architecture: 32-Bit System
10/16/2012 11:04:20 AM :: Operating System Product Type from System: Microsoft Windows XP Professional
10/16/2012 11:04:20 AM :: Running on CPU Speed:
CPU Number 1: [2193] Mhz
CPU Number 2: [2193] Mhz
10/16/2012 11:04:20 AM :: Bound .NET Runtime: v2.0.50727
10/16/2012 11:04:20 AM :: Initialize Startup Data ...
10/16/2012 11:04:21 AM :: Checking whether Native Image needs to be generated ...
10/16/2012 11:04:21 AM :: Extracting resource data from Device Remover memory "pcidatabase.ids" ...
10/16/2012 11:04:21 AM :: Generating Native Image.
Image will be created on Device Remover Binary:
"C:\Program Files\Device Remover\DeviceRemover.exe".
 Please wait ...
10/16/2012 11:04:21 AM :: Extracting resource data from Device Remover memory "pcidatabase.ids" ...success.
10/16/2012 11:04:21 AM :: Device Remover Helper Library is not available. Extracting from PE Image ...
10/16/2012 11:04:21 AM :: Extracting resource data from Device Remover memory "devremlib.dll" ...
10/16/2012 11:04:22 AM :: Extracting resource data from Device Remover memory "devremlib.dll" ...success.
10/16/2012 11:04:22 AM :: Device Remover Helper Library is not available. Extracting from PE Image ... success.
10/16/2012 11:04:22 AM :: Device Remover Helper Library is available now. Version: 1.0.1.0
Binary Info:
File:             C:\Program Files\Device Remover\devremlib.dll
InternalName:     devremlib.dll
OriginalFilename: devremlib.dll
FileVersion:      1.0.1.0
FileDescription:  Device Remover Helper Library
Product:          devremlib.dll
ProductVersion:   1.0.1.0
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     False
SpecialBuild:     False
Language:         English (United States)
10/16/2012 11:04:22 AM :: Windows NT Image Helper Library is available. Version: 5.1.2600.2180
Binary Info:
File:             C:\WINDOWS\system32\imagehlp.dll
InternalName:     IMAGEHLP.DLL
OriginalFilename: IMAGEHLP.DLL
FileVersion:      5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
FileDescription:  Windows NT Image Helper
Product:          Microsoft® Windows® Operating System
ProductVersion:   5.1.2600.2180
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     False
SpecialBuild:     False
10/16/2012 11:04:23 AM :: Microsoft Windows Symbolic Debugger Engine is not available. Extracting from PE Image ...
10/16/2012 11:04:23 AM :: Extracting resource data from Device Remover memory "dbghelp.dll" ...
10/16/2012 11:04:24 AM :: Extracting resource data from Device Remover memory "dbghelp.dll" ...success.
10/16/2012 11:04:24 AM :: Microsoft Windows Symbolic Debugger Engine is not available. Extracting from PE Image ... success.
10/16/2012 11:04:24 AM :: Microsoft Windows Symbolic Debugger Engine is available now.
Binary Info:
File:             C:\Program Files\Device Remover\dbghelp.dll
InternalName:     DBGHELP.DLL
OriginalFilename: DBGHELP.DLL
FileVersion:      6.11.0001.404 (debuggers(dbg).090225-1745)
FileDescription:  Windows Image Helper
Product:          Debugging Tools for Windows(R)
ProductVersion:   6.11.0001.404
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     True
SpecialBuild:     False
10/16/2012 11:04:24 AM :: Microsoft Windows Driver Package Installer is not available. Extracting from PE Image ...
10/16/2012 11:04:24 AM :: Extracting resource data from Device Remover memory "dpinst.exe" ...
10/16/2012 11:04:25 AM :: Extracting resource data from Device Remover memory "dpinst.exe" ...success.
10/16/2012 11:04:25 AM :: Microsoft Windows Driver Package Installer is not available. Extracting from PE Image ... success.
10/16/2012 11:04:25 AM :: Microsoft Windows Driver Package Installer is available now.
Binary Info:
File:             C:\Program Files\Device Remover\dpinst.exe
InternalName:     DPInst
OriginalFilename: DPInst.exe
FileVersion:      2.1
FileDescription:  Driver Package Installer
Product:          Driver Package Installer (DPInst)
ProductVersion:   2.1
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     True
SpecialBuild:     False
10/16/2012 11:04:25 AM :: Microsoft Windows Driver Install Frameworks for API library module is not available. Extracting from PE Image ...
10/16/2012 11:04:25 AM :: Extracting resource data from Device Remover memory "DIFxAPI.dll" ...
10/16/2012 11:04:26 AM :: Extracting resource data from Device Remover memory "DIFxAPI.dll" ...success.
10/16/2012 11:04:26 AM :: Microsoft Windows Driver Install Frameworks for API library module is not available. Extracting from PE Image ... success.
10/16/2012 11:04:26 AM :: Microsoft Windows Driver Install Frameworks for API library module is available now.
Binary Info:
File:             C:\Program Files\Device Remover\DIFxAPI.dll
InternalName:     DIFxAPI
OriginalFilename: DIFxAPI.dll
FileVersion:      2.1
FileDescription:  Driver Install Frameworks for API library module
Product:          Driver Install Frameworks API (DIFxAPI)
ProductVersion:   2.1
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     True
SpecialBuild:     False
10/16/2012 11:04:26 AM :: Preloading Application used Dlls ...
10/16/2012 11:04:26 AM :: Preloading Application used Dlls ... success
10/16/2012 11:04:27 AM :: Trying to load Device Remover Kernel Driver ...
10/16/2012 11:04:28 AM :: Extracting resource data from Device Remover memory "devremdrv.sys" ...
10/16/2012 11:04:29 AM :: Extracting resource data from Device Remover memory "devremdrv.sys" ...success.
10/16/2012 11:04:29 AM :: Device Remover Kernel Driver is available now. Binary Info:
File:             C:\Program Files\Device Remover\devremdrv.sys
InternalName:     devremdrv.sys
OriginalFilename: devremdrv.sys
FileVersion:      1.0.0.0
FileDescription:  Device Remover Kernel Driver
Product:          Device Remover Kernel Driver
ProductVersion:   1.0.0.0
Debug:            False
Patched:          False
PreRelease:       False
PrivateBuild:     False
SpecialBuild:     False
10/16/2012 11:04:31 AM :: Trying to load Device Remover Kernel Driver ... success.
10/16/2012 11:04:32 AM :: Initializing PCI Vendor and ID Databases ...
10/16/2012 11:04:32 AM :: Initializing PCI Vendor and ID Databases ...success.
10/16/2012 11:04:33 AM :: Registering for Device Notifications ...
10/16/2012 11:04:33 AM :: Registering for Device Notifications ... success.
10/16/2012 11:04:33 AM :: Registering for Shell Notifications ...
10/16/2012 11:04:33 AM :: Registering for Shell Notifications ...success.
10/16/2012 11:04:47 AM :: Microsoft (R) CLR Native Image Generator - Version 2.0.50727.42
Copyright (C) Microsoft Corporation 1998-2002. All rights reserved.
Installing assembly C:\Program Files\Device Remover\DeviceRemover.exe
Compiling 1 assembly:
    Compiling assembly C:\Program Files\Device Remover\DeviceRemover.exe ...
Warning: System.TypeLoadException: Could not load type 'System.GCCollectionMode' from assembly 'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'. while resolving 0x1000260 - System.GCCollectionMode.
Warning: System.MissingMethodException: Method not found: 'Void System.Windows.Forms.FileDialog.set_AutoUpgradeEnabled(Boolean)'. while resolving 0xa0001b1 - System.Windows.Forms.FileDialog.set_AutoUpgradeEnabled.
Warning: System.MissingMethodException: Method not found: 'Void System.GC.Collect(Int32, System.GCCollectionMode)'. while resolving 0xa00085f - System.GC.Collect.
Method not found: 'Void System.Windows.Forms.FileDialog.set_AutoUpgradeEnabled(Boolean)'. while compiling method DRPCIDatabasesExplorerForm.drButtonClassUpdatePCIIDsDatabase_Click
Method not found: 'Void System.GC.Collect(Int32, System.GCCollectionMode)'. while compiling method DeviceRemoverCommands.GarbageCollectDeviceRemover
Method not found: 'Void System.Windows.Forms.FileDialog.set_AutoUpgradeEnabled(Boolean)'. while compiling method ShellProcessOperations.OpenFileWithAppplication_ThrowsException
DeviceRemover, Version=0.9.4290.34732, Culture=neutral, PublicKeyToken=e95e4383d40cdaf6
10/16/2012 11:04:47 AM :: Generating Native Image ...done!
10/16/2012 11:04:48 AM :: Gathering Device Classes Information ...
10/16/2012 11:04:57 AM :: Gathering Device Classes Information ... ...success. Total Device Classes examined: 62
10/16/2012 11:04:57 AM :: Building Devices Data List and Tree ...
10/16/2012 11:04:57 AM :: Building Devices Data List and Tree. Mode: ALL_PRESENT_ACTIVE_DEVICES
10/16/2012 11:06:50 AM :: Building Devices Data List and Tree ... success. Total Devices Enumerated: 167
10/16/2012 11:06:51 AM :: Application Startup initiated at: 11:03:45 AM
10/16/2012 11:06:51 AM :: Application Startup finished at: 11:06:51 AM
10/16/2012 11:06:51 AM :: Time elapsed for Application Startup: 00:03:05
10/16/2012 11:07:31 AM :: "10/16/2012 11:07:31 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:07:31 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:07:35 AM :: "10/16/2012 11:07:35 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:07:36 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:07:37 AM :: "10/16/2012 11:07:37 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{a5dcbf10-6530-11d2-901f-00c04fb951ed}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}}"
10/16/2012 11:07:37 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:07:37 AM :: "10/16/2012 11:07:37 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{d644a377-f969-43d7-b953-343eb04817fc}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{d644a377-f969-43d7-b953-343eb04817fc}}"
10/16/2012 11:07:37 AM :: "10/16/2012 11:07:37 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:07:37 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:07:44 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices, please wait ...
10/16/2012 11:07:44 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices ... success. Rescanning System Buses done ...
10/16/2012 11:08:21 AM :: "10/16/2012 11:08:21 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:21 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:21 AM :: "10/16/2012 11:08:21 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{d644a377-f969-43d7-b953-343eb04817fc}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{d644a377-f969-43d7-b953-343eb04817fc}}"
10/16/2012 11:08:21 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:08:22 AM :: "10/16/2012 11:08:22 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{a5dcbf10-6530-11d2-901f-00c04fb951ed}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}}"
10/16/2012 11:08:22 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:08:25 AM :: "10/16/2012 11:08:25 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:25 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:28 AM :: "10/16/2012 11:08:28 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:28 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:29 AM :: "10/16/2012 11:08:29 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{a5dcbf10-6530-11d2-901f-00c04fb951ed}, Device Name:{\\?\USB#Vid_0fce&Pid_e170#BX9037MWF6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}}"
10/16/2012 11:08:29 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:30 AM :: "10/16/2012 11:08:30 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:30 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:30 AM :: "10/16/2012 11:08:30 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f56307-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\USBSTOR#Disk&Ven_SONY&Prod_Mass_storage&Rev_0000#BX9037MWF6&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:30 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:30 AM :: "10/16/2012 11:08:30 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:31 AM :: "10/16/2012 11:08:31 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:31 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:31 AM :: "10/16/2012 11:08:31 AM""DBT_DEVICEARRIVAL""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:08:31 AM :: "10/16/2012 11:08:31 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:31 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:33 AM :: "10/16/2012 11:08:33 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:33 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:34 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f56307-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\USBSTOR#Disk&Ven_SONY&Prod_Mass_storage&Rev_0000#BX9037MWF6&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:34 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f56307-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\USBSTOR#Disk&Ven_SONY&Prod_Mass_storage&Rev_0000#BX9037MWF6&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:34 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:34 AM :: "10/16/2012 11:08:34 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:35 AM :: "10/16/2012 11:08:35 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:35 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:35 AM :: "10/16/2012 11:08:35 AM""DBT_DEVICEARRIVAL""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:08:35 AM :: "10/16/2012 11:08:35 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:35 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:35 AM :: "10/16/2012 11:08:35 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:35 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:08:36 AM :: "10/16/2012 11:08:36 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:08:36 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:08:36 AM :: "10/16/2012 11:08:36 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630a-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:36 AM :: "10/16/2012 11:08:36 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:36 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:08:37 AM :: "10/16/2012 11:08:37 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:08:37 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:08:37 AM :: "10/16/2012 11:08:37 AM""DBT_DEVICEARRIVAL""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:08:37 AM :: "10/16/2012 11:08:37 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:08:37 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:09:39 AM :: "10/16/2012 11:09:39 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:09:39 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:09:40 AM :: "10/16/2012 11:09:40 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\STORAGE#RemovableMedia#7&37e39afe&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:09:40 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:09:40 AM :: "10/16/2012 11:09:40 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_VOLUME""G:\""Volume Type:{0}, Volume Letter:{G:}"
10/16/2012 11:09:40 AM :: "10/16/2012 11:09:40 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{53f56307-b6bf-11d0-94f2-00a0c91efb8b}, Device Name:{\\?\USBSTOR#Disk&Ven_SONY&Prod_Mass_storage&Rev_0000#BX9037MWF6&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}}"
10/16/2012 11:09:41 AM :: "10/16/2012 11:09:41 AM""DBT_DEVICEREMOVECOMPLETE""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{a5dcbf10-6530-11d2-901f-00c04fb951ed}, Device Name:{\\?\USB#Vid_0fce&Pid_e170#BX9037MWF6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}}"
10/16/2012 11:09:41 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEREMOVECOMPLETE
10/16/2012 11:10:18 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices, please wait ...
10/16/2012 11:10:18 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices ... success. Rescanning System Buses done ...
10/16/2012 11:10:29 AM :: "10/16/2012 11:10:29 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:10:29 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:10:31 AM :: "10/16/2012 11:10:31 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{a5dcbf10-6530-11d2-901f-00c04fb951ed}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}}"
10/16/2012 11:10:31 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVICEARRIVAL
10/16/2012 11:10:31 AM :: "10/16/2012 11:10:31 AM""DBT_DEVICEARRIVAL""DEVICETYPE_DEVICEINTERFACE""N/A""Device Interface Class Guid:{d644a377-f969-43d7-b953-343eb04817fc}, Device Name:{\\?\USB#Vid_0fce&Pid_adde#5&20f5db59&1&3#{d644a377-f969-43d7-b953-343eb04817fc}}"
10/16/2012 11:10:31 AM :: "10/16/2012 11:10:31 AM""DBT_DEVNODES_CHANGED""N/A""N/A""N/A"
10/16/2012 11:10:31 AM :: WM_DEVICECHANGE arrived...detail: DBT_DEVNODES_CHANGED
10/16/2012 11:10:34 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices, please wait ...
10/16/2012 11:10:34 AM :: Initiating Hardware Bus and Nodes Enumeration for pending/new Devices ... success. Rescanning System Buses done ...
Old 10-22-2012, 09:31   #14 (permalink)
patric's Avatar
Member: 8228
Thanks Meter: 123
is there any new solution to unlock this model
Old 10-24-2012, 18:06   #15 (permalink)
rorcorporation's Avatar
Member: 1664131
Sonork: 100.1636755
Thanks Meter: 27
same problem.... Waiting for unlock sony smartphones
Page generated in 0.55001 seconds with 7 queries
