09-30-2014, 18:54 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | Help unlock xperia E C1505 30-09-2014 18:34:07 SIGNED MODE (USING SERVER) 30-09-2014 18:34:07 ALTERNATIVE SECURITY BYPASS ENABLED 30-09-2014 18:34:07 CFG:110010000000 30-09-2014 18:34:09 PLEASE ATTACH TURNED OFF PHONE NOW 30-09-2014 18:34:09 PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 30-09-2014 18:34:20 30-09-2014 18:34:20 RUNNING S1_BOOT VER "R10D030" 30-09-2014 18:34:20 30-09-2014 18:34:20 ACTIVE_COMP_AID : 0002 30-09-2014 18:34:20 HWCONF_AID : 0002 30-09-2014 18:34:20 LOADER_AID : 0002 30-09-2014 18:34:20 BOOT_AID : 0002 30-09-2014 18:34:20 30-09-2014 18:34:25 DEVICE ID: ABCA9AED2CABEAC3E765B2806D04A5F44C0DF248 30-09-2014 18:34:25 FLASH ID: "0003/00000015" 30-09-2014 18:34:25 LOADER VERSION: "R5D030" 30-09-2014 18:34:25 30-09-2014 18:34:25 PHONE IMEI : 35742105122564 30-09-2014 18:34:25 Checking for signature ... 30-09-2014 18:34:25 signature found, skipping calculation 30-09-2014 18:34:25 30-09-2014 18:34:25 REMOVE SIM CARD FROM PHONE 30-09-2014 18:34:25 FULLY POWER ON PHONE 30-09-2014 18:34:25 ENABLE "USB DEBUGGING" IN PHONE: 30-09-2014 18:34:25 MENU,SETTINGS,APPLICATIONS,DEVELOPMENT 30-09-2014 18:34:25 INSTALL ADB DRIVERS IF NEEDED 30-09-2014 18:34:25 30-09-2014 18:34:25 WARMING UP ... 30-09-2014 18:35:08 CHECKING ROOT ACCESS ... 30-09-2014 18:35:09 PROCESSING ... 30-09-2014 18:35:09 C1505 [6ee57e21] 30-09-2014 18:35:09 FATAL FAILURE : 30-09-2014 18:35:09 FINALIZING ... 30-09-2014 18:35:09 Unlock FAILED Try two times same error.... Any help? I tick optini 1 - 2 -5 tanks |
10-01-2014, 10:32 | #3 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | Flash the phone and the log is 01-10-2014 10:23:13 RUNNING v 1.1405/01.15/UNI 01-10-2014 10:23:13 CARD SERIAL 00072118 01-10-2014 10:23:13 USBFLASH DRIVER VERSION 02.02.00.05 01-10-2014 10:25:44 SIGNED MODE (USING SERVER) 01-10-2014 10:25:44 ALTERNATIVE SECURITY BYPASS ENABLED 01-10-2014 10:25:44 CFG:110010000000 01-10-2014 10:25:47 PLEASE ATTACH TURNED OFF PHONE NOW 01-10-2014 10:25:47 PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 01-10-2014 10:28:01 01-10-2014 10:28:01 RUNNING S1_BOOT VER "R10D030" 01-10-2014 10:28:01 01-10-2014 10:28:01 ACTIVE_COMP_AID : 0002 01-10-2014 10:28:01 HWCONF_AID : 0002 01-10-2014 10:28:01 LOADER_AID : 0002 01-10-2014 10:28:01 BOOT_AID : 0002 01-10-2014 10:28:01 01-10-2014 10:28:05 DEVICE ID: ABCA9AED2CABEAC3E765B2806D04A5F44C0DF248 01-10-2014 10:28:05 FLASH ID: "0003/00000015" 01-10-2014 10:28:05 LOADER VERSION: "R5D030" 01-10-2014 10:28:05 01-10-2014 10:28:05 PHONE IMEI : 35742105122564 01-10-2014 10:28:06 Checking for signature ... 01-10-2014 10:28:06 signature found, skipping calculation 01-10-2014 10:28:06 01-10-2014 10:28:06 REMOVE SIM CARD FROM PHONE 01-10-2014 10:28:06 FULLY POWER ON PHONE 01-10-2014 10:28:06 ENABLE "USB DEBUGGING" IN PHONE: 01-10-2014 10:28:06 MENU,SETTINGS,APPLICATIONS,DEVELOPMENT 01-10-2014 10:28:06 INSTALL ADB DRIVERS IF NEEDED 01-10-2014 10:28:06 01-10-2014 10:28:06 WARMING UP ... 01-10-2014 10:28:11 found existing ADB server 1.0.31, killing ... 01-10-2014 10:30:15 CHECKING ROOT ACCESS ... 01-10-2014 10:30:16 GETTING ROOT ACCESS ... 01-10-2014 10:30:18 PROCESSING ... 01-10-2014 10:30:18 C1505 [6ee57e21] 01-10-2014 10:30:18 FATAL FAILURE : 01-10-2014 10:30:19 FINALIZING ... 01-10-2014 10:30:19 Unlock FAILED Unlock failed.. |
10-01-2014, 11:37 | #4 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | there is some program, which using adb server on your pc, like sony pc companion, htc sync, samsung companion and so on. remove it and repeat procedure. can't help you more, sorry. |
