02-07-2009, 16:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 936896 Status: Offline Thanks Meter: 14 | Help Unlocking SE w350i Im new to the unl;ocking world ... i have setool box and wanted to know how to unlock the se 350i, i mean is it there any turorial that does explain how to use setool and plus i heard that for some mobiles is required to have some files to unlock them ,, what do i require for se w350i and where can i get it? |
02-07-2009, 16:20 | #2 (permalink) |
Junior Member Join Date: Oct 2006
Member: 370506 Status: Offline Thanks Meter: 0 | try looking at http://www.setool.net/video/index.php there are guides for unlocking on SEtool. |
03-11-2009, 08:21 | #6 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | hi! if you are using setool for the first time then you should download rest file from support. also download usb driver for w350 and for any other cyber shot fone u want to flash or unlock. switch your fone on,then connect ur usb cable and install driver. on setool,identify then see wat cid your fone is,if rest file is present or not and if bypass package is present or not. if both rest file and bypass package present then in settings just choose signed mode,alternative bypass and security bypass then unlock.u must of course have test sim to insert it when it ask you too or use use original sim. if rest file not present and bypass package present then have to make rest file,in settings just choose alternative bypass and preloader bypass.then click identify so it will make rest file then unlock. if bypass package not present then have to full flash fone(main + fs).to flash choose signed mode and complete fone after flash in settings.then unlock. good luck |
The Following User Says Thank You to wearephones For This Useful Post: |
06-27-2013, 15:11 | #11 (permalink) |
Freak Poster Join Date: Jan 2013 Location: spain
Member: 1867931 Status: Offline Sonork: 100.1625521 Thanks Meter: 36 | unlock done sony w350 free unlock ok by setool CARD SERIAL: 00025968 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 skipping empty loader... OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502844776 CERT:RED Model:W350i Brand:Vodafone ES MAPP CXC article: R10BA015 prg1205-7402_VODAFONE_JH MAPP CXC version: R10BA015 Language Package:VFE_LIVE_1 CDA article: 1208-9089 CDA version: R7A Default article: 1204-3119 Default version: R10BA015 PROVIDER: 214-01 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 39 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 OTP LOCKED:1 CID:52 PAF:1 IMEI:35586502844776 CERT:RED LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER Flash ID check:897E Flash props sent ok LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM158 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID000,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:53 Speed:921600 Trying to launch embedded bootloader... INT LDR:PNX5230_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok FOUND: R10BA015_1205-7402_VODAFONE_JH Restore from:R10BA015_1205-7402_VODAFONE_JH full sig complete. USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 321 secs. |
how unlock SE w350i? | defcon2 | DreamBox | 5 | 03-30-2009 23:51 |
Need Help Unlocking SE W580i! Please Help! | babycafe | Seking Server | 1 | 01-18-2008 01:35 |
** Help unlocking SE K700i with Semctool or Usbsmart | Jonny B | SonyEricsson (USB-Smart) | 12 | 05-27-2006 01:13 |
Hi FuriousTeam PLEASE HELP UNLOCK SE T616 | simclub1 | FuriouS II | 1 | 03-15-2006 14:49 |
