09-12-2013, 13:16 | #1 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1255437 Status: Offline Thanks Meter: 0 | Hi, I use SETOOL unlock X8 (e15i), there is a problem SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: D8B88AA719E5BA430E6667CDFA550385D3E0A3C8 FLASH ID: "0020/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 01244800420287 Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... GETTING ROOT ACCESS ... * daemon not running. starting it now on port 5037 * * daemon started successfully * ** daemon still no ... failed, err: [* daemon not running. starting it now on port 5037 * * daemon started successfully * error: device not found ] Unlock FAILED Elapsed: 42 secs. |
