Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Mar 2008
Member: 717427 Status: Offline Thanks: 4
| v0.914037/UNI CARD SERIAL: 0007777 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601725950 CERT:N/A FLASH CID:53 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35170701616552 Model:K810i Brand:Generic MAPP CXC article: R1KC001 prgCXC1250811_GENERIC_SM MAPP CXC version: R1KC001 Language Package:EUROPE_4 CDA article: CDA111111/DEV CDA version: R2A Default article: cxc1250813 Default version: R1KC001 PROVIDER: 000-00 Network LOCKED RESTORATION FILE NOT PRESENT "R1KC001_CXC1250811_GENERIC_SM" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 189 secs. this model is k800i.. if i try to identify this phone with my se tool box this model of phone show k810i.. how can i repair this using se tool? TIA |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 143889 Status: Offline Sonork: 100.1584685 Thanks: 218
| u can use K810 firmware on K800 thats not a problem. by info dont see any major problem. tell us whats the problem on phone??? |
| The Following User Says Thank You to Softway For This Useful Post: |
| | #3 (permalink) | |
| Quote:
so i can use flashfile of k810i to k800i? thats what you mean sir. because this is the 1st time i encounter this problem sir by the way thank you for reading my thread more power to you sir!! Last edited by muscle c0ntrol; 08-24-2008 at 20:01. | |
| | #4 (permalink) | |
| Quote:
if u need step by step instruction then its impossible to give here. use msn or sonork to contact me directly ill assist u np | |
| | #6 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2004 Location: ALGERIA W09
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks: 34
| if u use K810 firmware on K800 u will have keypad light problem but phone will work normal but tell us what is phone peoblem exactly (red-blink , white screen ,.....) |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: Infront in my PC Age: 32
Member: 716001 Status: Offline Sonork: 100.1597485 Thanks: 87
| i have finish to flash it lg u8120 bro ready to work thanks v0.914039/UNI CARD SERIAL: 000..... Loaded 51 flash descriptors SIGNED MODE (USING SERVER). Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:17 Speed:921600 DB2000 only supports 460800,fallback. OTP LOCKED:1 CID:17 PAF:0 IMEI:35329000693114 CERT:B SIGNED MODE (USING SERVER). Open COM port OK ChipID:7100,EMP protocol:0301 PHONE IS BROWN FLASH CID detected:17 Speed:921600 DB2000 only supports 460800,fallback. OTP LOCKED:1 CID:17 PAF:0 IMEI:35329000693114 CERT:BROWN LDR:041214 0759 MATCXC1325712_PRODUCTION R2Z Flash ID check:890D Flash props sent ok Switching to USB... interface not changed writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_PHONE.ssw CURRENT FLASH FILE CID:17 SSW uses dynamic hash, dynamic hash len is:184 Will flash 184 blocks... SSW loading returns:0 writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_FS.ssw CURRENT FLASH FILE CID:17 SSW uses dynamic hash, dynamic hash len is:528 Will flash 528 blocks... SSW loading returns:0 writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_DRIVEC.ssw CURRENT FLASH FILE CID:17 SSW uses dynamic hash, dynamic hash len is:160 Will flash 160 blocks... SSW loading returns:0 writing E:\FLASH FILES\LG\setool\U8120\U8120_UK_Hutchison_v105+\U81 20_V105_UK_DRIVEMEDIA.ssw CURRENT FLASH FILE CID:17 SSW uses dynamic hash, dynamic hash len is:56 Will flash 56 blocks... SSW loading returns:0 Setting up GDFS... Writing simlocks... Insert any SIM, enter 2945#*88110#, then unlock code ALL UNLOCK/LOCK CODES SET TO "78284023" Signing... control keys complete. full sig complete. Phone detached Unlock Done Elapsed: 1858 secs. |
| The Following User Says Thank You to musmyl For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how can we repaire this? | risan | WD2 & APE (Symbian Phones) | 16 | 02-26-2013 04:46 |
| How can I repair this nokia 5220 with x-key | javierramirez | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-05-2010 03:51 |
| can i repair this 5220 with genie? | safvanp | Genie Universal | 4 | 11-15-2009 06:46 |
| how can i repair this phone | knok95 | Chinese Miracle & PinFinder | 1 | 09-10-2008 16:46 |
| how can i repair this kind of error by usb smart | gsmbac | Motorola P2K (USB-Smart) | 0 | 04-19-2006 17:10 |
