04-14-2009, 05:07 | #1 (permalink) | |
Insane Poster Join Date: Aug 2008 Location: watching your mind
Member: 835794 Status: Offline Thanks Meter: 11 | how can i solve this problem of my k530i only sony logo then shut off blue screen when i thick identfy to my settol box the reading is k700 i try to repaire it via tp but still same problem here the logs of identfy Quote:
Code: ATTACH TP #1 AND PRESS "READY" RELEASE TP #1 AND PRESS "READY" TP #1 LOOKS OKAY DONE Elapsed: 38 secs. TESTPOINT REPAIR STAGE #2 STARTED Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 ATTACH TP #2 AND PRESS "READY" Trying to launch embedded bootloader... TP #2 LOOKS OKAY RELEASE TP #2 AND PRESS "READY" INT LDR:DB2020_PRELOADER_FOR_SETOOL2 WRITING EROM... DONE Elapsed: 41 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901240226 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER Flash ID check:2019 Flash props sent ok writing "D:\gadget\sarasoft\setool\setool version\v0.915034\gdfs_in_ssw_format\db2020\K530_gdfs_SSW.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:640 Will flash 32 blocks... SSW loading returns:0 writing "D:\gadget\sarasoft\setool\setool version\v0.915034\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is:40 Will flash 2 blocks... SSW loading returns:0 Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "57334511" SIGNING... Elapsed: 49 secs. with usb cable reading still thesame any know tricks about this can any one help me tia........ | |
04-14-2009, 05:25 | #2 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | TP procedure is use only for GDFS Repair and you were no need for this process coz there is another simple and ez way to solve this problem. now you plz only get info and post here, i just want to see that your phone has need to upgrade the Erom or not ? B.R., kashi4gul |
The Following User Says Thank You to kashi4gul For This Useful Post: |
04-14-2009, 05:27 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2006 Age: 36
Member: 265129 Status: Offline Thanks Meter: 281 | bro ther try to repair gdfs with cruiser ultimateunlocker. rgd. .::F@iz@/\/"::. www.gsmorbit.com www.image.gsmorbit.com |
The Following User Says Thank You to faizanbhatti94 For This Useful Post: |
04-14-2009, 05:48 | #4 (permalink) | ||
Member: 835794 Status: Offline Thanks Meter: 11 | Quote:
then shut off Quote:
04-14-2009, 06:01 | #5 (permalink) | |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
Use only COM/UFS interfaces! 1. (Optional): Back up the corrupt GDFS (yes, even though it's corrupted, so you have a full backup just in case). Again: "Read GDFS". Move it to a safe place on your HD, this is to avoid accidentally deleting it and for avoiding confusion with all the other txt-files that will appear later on. 2. Create a scriptfile (a normal txt-file will do) with the following contents: Code: gdfsread:00020e5a gdfsread:00020e48 gdfsread:00010851 gdfsread:00000006 gdfsread:0000000E gdfsread:00000013 gdfsread:0000001C gdfsread:00000018 gdfsread:000000AA Now save it. Name it "readsecunits.txt" or whatever. Select the file in SETool's MISC-field and press "Write SCRIPT". All the read units will be stored in a single file named by the phone's IMEI. rename it as "secunitsbackup.txt" to avoid confusion 3. Apply the GDFS from a working DB2020 phone. - Read it out from the source phone (it will be stored in the SETool basedir named by the source phone's IMEI) - Check "Format GDFS" in "Settings" and write it to the damaged phone by selecting it in the MISC-field and pressing "Write GDFS". If the phone in question is OTP/FLASH CID52, DO NOT CHECK "Format GDFS" Do NOT turn the phone on afterwards. 4. Now, you'll have to write back the original units. Apply the "secunitsbackup.txt" you created by selecting it in the MISC-field and pressing "Write SCRIPT". that's all. . . (i have to leave now. bye bye ) B.R., kashi4gul | |
04-14-2009, 06:09 | #6 (permalink) |
Member: 835794 Status: Offline Thanks Meter: 11 | i try to read gdfs but this show up why? Will backup GDFS now. ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35901901240226 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed: 2 secs. |
04-14-2009, 07:22 | #7 (permalink) | |
And i informe you that all above method is orignaly posted by sgn (not by me) Thanks to sgn B.R., kashi4gul Last edited by kashi4gul; 04-14-2009 at 07:27. | |
How can i solve this problem | Momo_Gsm | SETool2 | 4 | 11-02-2008 08:28 |
how can i solve this problem? | ..::Mobile Smoker::.. | HWK | 1 | 07-10-2008 15:14 |
how can i solve this problem | avn | Infinity-Box | 5 | 06-09-2008 21:12 |
how can i solve this problem | Zein Zozza | Cruiser Suite | 3 | 02-13-2006 00:24 |
how can I solve this problem | buddhabar | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-29-2006 17:51 |
