04-22-2008, 11:32 | #1 (permalink) |
Junior Member Join Date: Apr 2008 Location: :: ALGERIA ::
Member: 741289 Status: Offline Thanks Meter: 1 | How can I Unlock K800cid51 using SE-Tool ???? TnanX Hello,,, How Can i unlock K800 cid51 using SE-Tool,,, ThanK U,,, |
The Following User Says Thank You to STeLaMioN For This Useful Post: |
04-22-2008, 11:50 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Albania
Member: 444251 Status: Offline Thanks Meter: 17 | U must flash it with flashes with cid52 and checking opsions on settings : 1.Complete phone after flash 2.Unlock after flash 3.Use server for csca unlock 4.Enable alternative security bypass and your phone would be unlocked |
04-22-2008, 12:01 | #4 (permalink) | ||
Member: 741289 Status: Offline Thanks Meter: 1 | Thank U all !! Quote:
ThanK U Kanwalgee But the help file [tutorial video] is mades for k550cid51 not for k800 cid51 Quote:
Thank u verry mutch man | ||
04-22-2008, 12:06 | #5 (permalink) | |
Banned Join Date: Jan 2008
Member: 677796 Status: Offline Thanks Meter: 102 | Quote:
B.R., kashi4gul | |
04-22-2008, 12:47 | #7 (permalink) |
Member: 741289 Status: Offline Thanks Meter: 1 | Can i unlock it using these instructions ??? >>> http://forum.gsmhosting.com/vbb/showthread.php?t=493507 |
04-22-2008, 12:55 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | yes u can unlock ur hand set which is mention in this thread http://forum.gsmhosting.com/vbb/showthread.php?t=493507 |
04-22-2008, 20:28 | #9 (permalink) | |
Member: 741289 Status: Offline Thanks Meter: 1 | Quote:
Thank U ,,, Succecfully Unlocked v0.914023/UNI CARD SERIAL: 00010646 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:115200 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401019652 CERT:RED FLASH CID:52 COLOR:RED Model:K800i MAPP CXC article: R1GB001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1GB001 Language Package:CENT_EUROPE CDA article: CDA102295/7 CDA version: R2A Default article: cxc1250490 Default version: R1CB001 PROVIDER: 234-33 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed:7 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. Abort all operations. phone pre-boot failed,possible RECOVERY needed. Elapsed:3 secs. SERVER SUPPORT ENABLED. ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401019652 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:35570401019652 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED bypassing security... ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 Flash ID check:897E Flash props sent ok writing D:\disk-2 (D)\Disque local (E)\mes document\k800\k800-52\R1ED001_1250210_GENERIC_WI.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9100 Will flash 455 blocks... SSW loading returns:0 writing D:\disk-2 (D)\Disque local (E)\mes document\k800\k800-52\R1ED001_FS_VFE_LIVE_2_WI_RED_CID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:7220 Will flash 361 blocks... SSW loading returns:0 full sig complete. USERCODE RESET TO "0000" Searching... Firmware lock check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed writing tpa/preset/custom/C3_PCA_G3v2.cer writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm writing tpa/preset/custom/customize.xml writing tpa/preset/custom/DESKTOP_HOOK_2.itm writing tpa/preset/custom/Entrust.net Root Certificate.cer writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm writing tpa/preset/custom/FM_THEMES_HOOK_3.itm writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm writing tpa/preset/custom/GAMES_HOOK_3.itm writing tpa/preset/custom/GTE_CyberTrust_Root.cer writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt writing tpa/preset/custom/Root.cer writing tpa/preset/custom/SEMC_E2E_Root_CA.crt writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm writing tpa/preset/custom/ThawtePremium.der writing tpa/preset/custom/ThawteServerCA.cer writing tpa/preset/custom/Utiroot.cer writing tpa/preset/custom/VeriSignClass3Root.cer writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed:821 secs. | |
12-02-2008, 08:47 | #12 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Quote:
http://www.plunder.com/CID-49-51-To-...jQVwrn75Xg.htm | |
12-02-2008, 10:22 | #13 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | v0.914041/UNI CARD SERIAL: Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701167580 CERT:RED FLASH CID:52 COLOR:RED Model:K800i Brand:Generic Trade MAPP CXC article: R1CE001 prgCXC1250211_VODAFONE_WI MAPP CXC version: R1CE001 Language Package:VFE_LIVE_3 CDA article: CDA102568/10 CDA version: R2A Default article: cxc1250490 Default version: R1CE001 PROVIDER: 234-15 Network LOCKED SEARCH:E:\PHONE\SE TOOL\Flash\SE\K800\CID51\R1GB001\R1GB001_1250210_G ENERIC_WI.ssw.cry RESTORATION FILE NOT PRESENT "R1CE001_CXC1250211_VODAFONE_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701167580 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed Writing GDFS var 0001:084E len:012F Success Phone detached Elapsed: 35 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701167580 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM22 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 67 secs. Not work for me .............. |
how can i will conect the se tool credit into v.40 | azad4u | SETool2 | 1 | 08-10-2009 09:25 |
how can i unlock my400v using codes | gabsgoosy | ARM9 BASED M62 / M62+ | 4 | 09-01-2006 22:04 |
How can I unlock v66 by Easy tool? | Argo_Andrew | Motorola P2K (USB-Smart) | 3 | 07-08-2006 12:18 |
how can i unlock V551 using smartclip?? | amps_jas | Smart-Clip | 2 | 04-29-2006 10:29 |
How can i Unlock MC60 using Java midlet w/o SimCard | sin_daemon | E-Gold Based Phones | 5 | 12-14-2004 03:38 |
