03-16-2010, 09:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | how to change cid in w580i????? Loaded 51 flash descriptors SIGNED MODE (USING SERVER) CFG:10001000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100144115 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 FLASH ID check:897E Flash props sent ok writing "D:\w580 cid52\R8BE001_1123362_GENERIC_LA.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... SSW loading returns:0 writing "D:\w580 cid52\R8BE001_FS_HONG_KONG_LA_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 4260 Will flash 213 blocks... SSW loading returns:0 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed GDFS startup failed,error is 04 [1D] loader GDFS startup failed, that is fatal Elapsed: 676 secs. after repair gdfs( red blinking) Quote: Originally Posted by xerraco View Post Its on Sticky Thread Mate....Here Code: 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. if gdfs totally damaged, add to firmware area proper gdfs in ssw format,otherwise skip that step 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. I CFG:000000000000 RECOVERY MODE STARTED PROCEDURE WAS STOPPED BY USER Elapsed: 57 secs. SIGNED MODE (USING SERVER) CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:115200 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:4A9F38E02380072C00302F23 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100144115 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 72 secs. flashing ----------------------------------------------- ChipID:9900,EMP protocol:0301 Speed:115200 OTP: LOCKED:1 CID:51 PAF:1 IMEI:01127100144115 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\SETOOL NEW SETUP\v1.0\gdfs_in_ssw_format\db2020\W580_GDFS_SSW .ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Elapsed: 219 secs. p. help how to change cid49 to cid52 in w580i |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
03-16-2010, 09:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Add EROM then Flash. Code: 8. add to firmware area proper EROM (EROM CID >= OTP CID) |
The Following User Says Thank You to xerraco For This Useful Post: |
06-10-2010, 19:53 | #4 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Bolton Age: 44
Member: 41976 Status: Offline Thanks Meter: 33 | hi! after the gdfs you need to write erom. then if you want to change cid you need to do write script by selecting thr file in miscellaneous.the file is located in your setool folder. hope thats helpful to you. |
how to change cid 36 49 w800i help | Master Software | SETool2 | 2 | 03-07-2010 14:50 |
Please can anyone explain how to change cid 53 to 52 with Setool? | GSM_MANIAC | SETool2 | 14 | 01-02-2010 14:35 |
How to change CID 49 to another ? | aminnovelty | DreamBox | 2 | 11-02-2009 07:55 |
can anybody help how to change cid 52 to cid 53? | debmobile | Sony Ericsson | 9 | 09-05-2008 13:05 |
how to change CID whit UFS_KZF? | foufou | HWK | 5 | 08-21-2006 17:06 |
