07-06-2010, 12:41 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: SL3;HTC DesireHD DIRECT UNLOCk Age: 44
Member: 476287 Status: Offline Sonork: 100.1587961 Thanks Meter: 834 | Conect phone to bootrom mode with volum up driver same as semc A2 |
The Following 3 Users Say Thank You to adelgsm For This Useful Post: |
07-06-2010, 14:10 | #3 (permalink) |
Freak Poster Join Date: Jun 2010 Location: morocco
Member: 1322811 Status: Offline Thanks Meter: 46 | after unlock your phone using setool box your phone is daed tested by me meracl phone revived by octopus for unlock your phone press + volum poton and conetc usb cable using octopus v1.40 tested by me |
07-21-2010, 16:43 | #5 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Birmingham U.K
Member: 251421 Status: Offline Sonork: 100.1609329 Thanks Meter: 439 | FOR CONNECTING USE VOLUME UP BUTTON PRESSED AND CONNECT WITH MICRO IF U USE 1.085 U DONT NEED TO FLASH PHONE AFTER UNLOCK I JUST UNLOCKED A GT400 ALL I DONE USED 1.085 SETUP 1. SELECT GT400 2. SIGNED MODE CHECK 3. CLICK UNLOCK & CONNECT PHONE USING MICRO USB PRESS & HOLD CAMERA & VOLUME DOWN BUTTON WHILE PHONE IS SWITCHED OFF. UNLOCK IS DONE NO NEED TO FLASH AFTER UNLOCK LOG IS HERE RUNNING v 1.085/UNI CARD SERIAL 0010XXXX USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35XXXXXXXXXXX] OTP LOCKED:1 CID:54 PAF:0 IMEI:35XXXXXXXXX7 CERT:RED LDR:YTRCXC1723918_C2_DB3200_PRODUCTION_LOADER_ACC_ SDRAM_SETOOL2 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:YTRCXC1723919_1C2_DB3200_PRODUCTION_LOADER_APP _SDRAM_JEFF_CABS_SETOOL2 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... SIMLOCK CODES SET TO "87747047" SIGNING... LDR:100119 1522 MATCXC1723917_3E2_DB3200_FLASH_LOADER_APP_SDRAM_CA BS_GDFS_ALL_R1A Unlock DONE Elapsed: 73 secs. |
The Following 6 Users Say Thank You to malikzahidawan For This Useful Post: |
07-31-2010, 16:51 | #8 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK
Member: 232050 Status: Offline Thanks Meter: 23 | not to worry guys, must need a full battery - worked perfectly when powered using power supply! thanks anyway... |
The Following User Says Thank You to canny2 For This Useful Post: |
08-08-2010, 10:47 | #11 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
10-09-2010, 16:49 | #12 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Pakistan < Karachi Age: 41
Member: 76456 Status: Offline Sonork: 100.1678368 Thanks Meter: 60 | Quote:
10-12-2010, 13:59 | #13 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | Drivers here Hope it helps took me a while to find them! http://www.the-emz.com/temp/GT400.zip Just to add a Nokia CA-101 cable works perfectly and press up on volume as described to connect! |
The Following User Says Thank You to The Dog For This Useful Post: |
10-12-2010, 14:36 | #14 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | Quote:
http://forum.gsmhosting.com/vbb/f473...l-box-1114546/ | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
