04-02-2009, 13:13 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: City Center
Member: 770272 Status: Offline Sonork: 100.1603193 Thanks Meter: 227 | how to solve this problum? how to solve can i downgrade cid50 to 49 v0.915034/UNI CARD SERIAL: xxxxxxxxxxxx Loaded 51 flash descriptors Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301474871 CERT:RED FLASH CID:50 COLOR:RED IMEI MISMATCH ! GDFS IMEI:04857555048575 Model (from GDFS):W810i MAPP CXC article: R4EK001 prgCXC1250316_GENERIC_HN MAPP CXC version: R4EK001 Language Package:S_ASIA_LEVAN CDA article: CDA102555/110 CDA version: R2A Default article: cxc1250324 Default version: R4CE012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE Elapsed: 286 secs. |
04-02-2009, 14:13 | #4 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | W 810 plz wait Quote:
hi brother go to setting tab CLICK ON SIGN MODE ENABEL ALTERNATIVE BYPASS ENABEL PRELOADER BYPASS click on 1st >patch otp gdfs chek in firmwear 2nd>allow to change imei when unlocking n then press unlock button n use USB CABEL FOR THIS cabel for it thanks Last edited by ehsas_ghum; 04-02-2009 at 14:19. | |
04-02-2009, 14:21 | #5 (permalink) | |
Member: 770272 Status: Offline Sonork: 100.1603193 Thanks Meter: 227 | Quote:
bro i thing cid 50 not support on thats option v0.915034/UNI CARD SERIAL:xxxxx Loaded 51 flash descriptors THAT ACTION IS ILLEGAL,IF YOU DOING IT FOR ANY PURPOSE, OTHER THAN REPAIR PHONE Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 OTP: LOCKED:1 CID:50 PAF:1 IMEI:35657301474871 CERT:RED phone CID not supported in that mode Elapsed: 10 secs. | |
04-02-2009, 15:08 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | you read faq for learning over tp procedure, you need repair gdfs and for it you need tp. IMEI MISMATCH ! GDFS IMEI:04857555048575 it is the problem. |
I how to solve this problem | Saulcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-30-2010 10:02 |
how to solve this problum[SL3 PHONE,UNSUPPORTED YET] | **Nadeem** | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-21-2010 19:19 |
2680s RM500 keeps on failing to unlock! how to solve this??? | Unlockemall | Universalbox | 14 | 02-20-2010 10:51 |
How to solve this.......... [SOLVED] | Kiranmistry | Cyclonebox | 6 | 11-21-2009 16:45 |
Your security card going to expired soon.How to solved this problem | hajji1 | Cyclonebox | 1 | 11-05-2009 17:05 |
