Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 08-06-2009, 17:50   #1 (permalink)
.:Gsm-Nikki:.'s Avatar
Member: 783315
Sonork: 100.1588917
Thanks Meter: 228
Arrow K550 ,,, not unlocking
HI
I HAVE THIS K550 WHICH I AM TRING TO UNLOCK,, BUT IT SAYS NO EXECUTOR FOUND .... I DOWNLOADED THE GENERIC FILE AND FLASH THE PHONE STILL THE SAME
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:101000100000000
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
PM FLASH CID: 0052
Speed:921600
OTP: LOCKED:1 CID:51 PAF:1 IMEI:35273302012750 CERT:RED
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
PM loader startup: executed
PM loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM81
PHONE READY TO PROCEED
There is NO EXECUTOR in phone !
Old 08-06-2009, 17:55   #2 (permalink)
Member: 431334
Thanks Meter: 5
your phone is k550 or K550 I mode ?
Old 08-06-2009, 18:09   #3 (permalink)
Member: 783315
Sonork: 100.1588917
Thanks Meter: 228
K550im
pls help
br
nikki
Old 08-06-2009, 20:11   #4 (permalink)
Member: 231133
Thanks Meter: 466
if cid 51 or 52 use old vertion lik v0.914023 , select :
-complet phone
-unlock after flash
-use server
-enable alternative
-do ful unlock
and flash it
Old 08-06-2009, 20:15   #5 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
Flash k550 52 and unlock using bypass 100%
Old 08-06-2009, 22:14   #6 (permalink)
Member: 783315
Sonork: 100.1588917
Thanks Meter: 228
@indikait
tried that but no luck
wbr
Old 08-06-2009, 22:15   #7 (permalink)
Member: 783315
Sonork: 100.1588917
Thanks Meter: 228
-complet phone
-unlock after flash
-use server
-enable alternative
-do ful unlock
and flash it
i used v0.914021
worked fine,, fully flashed
thanx
wbr
nikki
The Following User Says Thank You to .:Gsm-Nikki:. For This Useful Post:
my black berry 8100 is not unlock (Answered) ravin j tejura MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 11 04-08-2010 15:05
Nokia E65 not unlocked!! zeemar Cyclonebox 8 03-30-2010 12:59
lg bl20 not unlocking simlock Z3X-Team Products 1 03-29-2010 18:47
k550 repaired but not unlocked J3soft DreamBox 5 04-27-2009 19:41
k550 not charging help keeth_777 Sony Ericsson Hardware Repair 1 02-02-2009 13:55
Page generated in 0.14943 seconds with 9 queries
