01-20-2013, 12:44 | #1 (permalink) |
Registered User Join Date: Nov 2006 Location: philipines
Member: 387616 Status: Offline Sonork: 100.1647857 Thanks Meter: 14 | E15i unlock error "always warming up" any idea how to solve this problem? heres the logs... TIA...! CARD SERIAL 001xxxxxxx USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R8A029" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: BFDF2084BFC7C18F2B968B3EB2043FFA1999C557 FLASH ID: "002C/00BC" LOADER VERSION: "R4A060" PHONE IMEI : 35845xxxxxxxxxxx Checking for signature ... signature found, skipping calculation REMOVE SIM CARD FROM PHONE FULLY POWER ON PHONE ENABLE "USB DEBUGGING" IN PHONE: MENU,SETTINGS,APPLICATIONS,DEVELOPMENT INSTALL ADB DRIVERS IF NEEDED MAKE SURE PHONE HAS ANDROID 2.x FIRMWARE WARMING UP ... |
01-20-2013, 16:47 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | Remove sim card from phone fully power on phone enable "usb debugging" in phone: Menu,settings,applications,development install adb drivers if needed |
The Following User Says Thank You to the_laser For This Useful Post: |
01-21-2013, 03:29 | #3 (permalink) |
Member: 387616 Status: Offline Sonork: 100.1647857 Thanks Meter: 14 | there is no simcard when i connected in usb cable, usb debugging is activated, and i have installed adb drivers.. any other solution of this problem? THNKS!!! |
