07-14-2008, 23:46 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 682885 Status: Offline Thanks Meter: 69 | how to unlock A2 phones with setool could some one please give me detailed steps of how to unlock A2 phones e.g. K850, W910, W890 etc with setool. please could you also outline which settings i have to choose using setool v36. thanks in advance. |
07-15-2008, 00:15 | #2 (permalink) | |
Freak Poster Join Date: Apr 2005 Location: portugal Age: 46
Member: 134158 Status: Offline Thanks Meter: 30 | Quote:
Are u shure this tool is for u? Read FAQ on support forum... | |
07-15-2008, 07:15 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | Unlock A2 phones @power1977 , No need to be rude, we all was newbbies sometime.. and he post in this forum, so we answer in this forum too @mutuza, Follow this steps: select USB as interfase. select model in settings - tick "SIGNED MODE", "PERFORM FULL UNLOCK INSTEAD OF USERCODE RESET", and fill your logs account data. press UNLOCK / REPAIR , and connect it pressing "C" . if you have necesarry logs - you will get this message "RESPONSE" "SIGNATURE QUEUED FOR CALCULATION, CHECK BACK LATER" (this mean the calculation are added. this calculation may take 72 hours maximum. if after 3 days (72 hours) the sign are not be calculated- used logs return automatically when you press "information") If you get the message "QUEUE FULL, CHECK BACK LATER", (This mean all slots for calculationn are busy and try again ) Then - you can keep using phone normally and checking every half hour , repeating same process, ( tick in settings, press unlock ) If sign are done - you will see 'SUCCESS RESPONSE, If sign are not done - you will see: ""YOUR_IMEI" ALREADY IN QUEUE" - This means sign are still in calculation. If caclculation was succesfull, sign are stored in backup\"your imei" in setool2 folder then backup of gdfs are created if anything goes bad then, software tells to power phone: - Unplug it - Fully turn in on - Phone are in 5 locks condition, thats normal - Connect phone to usb cable - If ask fo change mode - Choose phone mode. - You will be asked for drivers ,if you dont installed before. - install all drivers Software serach all available COM ports till find your phone Process continue, phone will be power off and unlocked Cost is 7 logs split in 2 stages: calculation = 4 credits Unlock = 3 credits Best regards |
The Following 4 Users Say Thank You to renzox For This Useful Post: |
07-15-2008, 10:33 | #4 (permalink) |
Member: 682885 Status: Offline Thanks Meter: 69 | a2 unlock thanks, that helps alot. and power 1977 obviously ur a genius and you know everything, i have read the faq bt still want sure so asked hope its ok by you i mean i dont want to hurt ur sensitive feelings or anything. |
07-15-2008, 11:21 | #5 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Philippines
Member: 141418 Status: Offline Sonork: Davidlab Thanks Meter: 18 | dont mind him everyone has a way of learning everything and he has inborn knowledge and was never taught. bright kid. thats why we have forums so we can learn and ask questions and if you dont wish to help you can just shut up and read another thread. im sure the rest of the people reading this thread will agree with me. |
The Following User Says Thank You to brogitz0307 For This Useful Post: |
07-15-2008, 11:50 | #6 (permalink) |
Crazy Poster Join Date: Nov 2005 Age: 45
Member: 204317 Status: Offline Thanks Meter: 0 | guys i have w890 for unlocking. i have made the calculation part but now i cant get to normal mode because all 5 lock are locked. i`ve tried with motorola test card but it dosnt get in phone mode i have also tried with the sim card from the provider that was locked but still the same what should i do? |
07-15-2008, 17:38 | #8 (permalink) | |
Member: 598854 Status: Offline Thanks Meter: 141 | Quote:
connect power on phone without simcard and plug it to usb cable, setool find it in one COMport. B.R | |
07-22-2008, 21:28 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Ok I am trying to unock a K850i not working. I checked USE SIGNED MOD and FULL UNLOCK INSTEAD OF USER CODE and this is the following message:- 7/22/2008 12:51:56 PM v0.914034/UNI 7/22/2008 12:51:56 PM CARD SERIAL: 00059554 7/22/2008 12:51:56 PM Loaded 51 flash descriptors 7/22/2008 12:52:04 PM ChipID:C802,EMP protocol:0401 7/22/2008 12:52:05 PM BOOTROM MODE DETECTED 7/22/2008 12:52:06 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35887401303635 CERT:RED 7/22/2008 12:52:08 PM 7/22/2008 12:52:08 PM Model:K850i 7/22/2008 12:52:08 PM MAPP CXC article: R1CA029 prg12004400_GENERIC_SO 7/22/2008 12:52:08 PM MAPP CXC version: R1CA029 7/22/2008 12:52:08 PM Language Package:T-MOB-INT 7/22/2008 12:52:08 PM CDA article: 1201-5077 7/22/2008 12:52:08 PM CDA version: R7A 7/22/2008 12:52:09 PM Default article: 1200-5441 7/22/2008 12:52:09 PM Default version: R1CA029 7/22/2008 12:52:09 PM PROVIDER: 234-30 7/22/2008 12:52:09 PM Extended LOCKED 7/22/2008 12:52:09 PM 7/22/2008 12:52:09 PM Elapsed: 9 secs. 7/22/2008 12:52:27 PM ChipID:C802,EMP protocol:0401 7/22/2008 12:52:27 PM BOOTROM MODE DETECTED 7/22/2008 12:52:29 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35887401303635 CERT:RED 7/22/2008 12:52:30 PM LDR:2008-01-28 16:34 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A055 7/22/2008 12:52:30 PM LDR CAPS:SYSTEM FLASH 7/22/2008 12:52:31 PM LDR:2008-01-28 16:36 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A055 7/22/2008 12:52:31 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 7/22/2008 12:52:34 PM USERCODE RESET TO "0000" 7/22/2008 12:52:34 PM phone detached 7/22/2008 12:52:34 PM Elapsed: 13 secs. 7/22/2008 12:52:47 PM SIGNED MODE (USING SERVER). 7/22/2008 12:52:54 PM ChipID:C802,EMP protocol:0401 7/22/2008 12:52:54 PM BOOTROM MODE DETECTED 7/22/2008 12:52:57 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35887401303635 CERT:RED 7/22/2008 12:52:57 PM LDR:2008-01-28 16:34 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A055 7/22/2008 12:52:57 PM LDR CAPS:SYSTEM FLASH 7/22/2008 12:52:59 PM LDR:2008-01-28 16:36 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A055 7/22/2008 12:52:59 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 7/22/2008 12:52:59 PM Executing CSCA-based unlock. 7/22/2008 12:52:59 PM SECURITY UNITS NOT PREPARED ! 7/22/2008 12:52:59 PM Elapsed: 11 secs. 7/22/2008 1:21:06 PM SIGNED MODE (USING SERVER). 7/22/2008 1:21:07 PM SERVER CREDITS LEFT/USED: 21/9 7/22/2008 1:21:09 PM CARD COUNTERS: FLASH 35, UNLOCK 19 7/22/2008 1:21:09 PM Elapsed: 3 secs. What does that mean? What am I doing wrong ? |
How to unlock SE W302 with setool? | svchost | SETool2 | 4 | 04-10-2009 16:43 |
How to unlock SE K700i with setool??? | svchost | SETool2 | 3 | 02-17-2009 02:36 |
how to unlock ku 580??? withe setool | qodsgsm | LG | 2 | 11-19-2008 13:16 |
How to unlock your phone with SimEmu!! | ZIZOUTH | Sim Cloning and Scaning | 0 | 05-31-2003 18:09 |
How to unlock a phone with protected fields : 191,192,251,252 ;; | patric | Infineon C16X M51 & ARM7 M52 BASED | 1 | 07-20-2002 17:41 |
