07-15-2011, 16:28 | #2 (permalink) |
Insane Poster Join Date: Apr 2008 Location: Maroc
Member: 748202 Status: Offline Thanks Meter: 9 | 1. must have setool activated 2.go to setting enable signed mode 3.press volume down key + camera key then plug usb cable 4. press unlock 5. enter code gived on software |
01-19-2012, 14:44 | #3 (permalink) |
Insane Poster Join Date: Feb 2007
Member: 455931 Status: Offline Thanks Meter: 2 | RUNNING v 1.1094/01.13/UNI CARD SERIAL 00121459 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 29 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 54 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 42, UNLOCK 79 ALL SERVERS OFFLINE UNTIL 19:00 GMT+4 ( AT LEAST ) credits consumption for full signature unlock: S1 v1 xx credits ( OFFLINE ) S1 v2 xx credits ( OFFLINE ) S1 OPEN 05 credits ( OFFLINE FOR AID 004 PHONES) A1 phones 05 credits A2 phones 05 credits S1 v2 alternative bypass unlock 02 credits S1 v2 alternative bypass repair 05 credits W100,W150 codes 05 credits current setool2 version: 1.1203 Elapsed: 26 secs. SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 42, UNLOCK 79 Elapsed: 23 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 42 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 53 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 23 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 68 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 12 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 61 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 37 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 280 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 53 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 llbug:read error: "Fonction incorrecte" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 178 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 24 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 27 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 104 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 19 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100000000000 llbug:[\\?\USB#Vid_04e8&Pid_681b#3586670328472810#{a5dcbf 10-6530-11d2-901f-00c04fb951ed}] open error: "Paramètre incorrect" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 78 secs. SIGNED MODE (USING SERVER) CFG:100000000000 llbug:read error: "Accès refusé" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100000000000 llbug:read error: "Accès refusé" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 llbug:[\\?\USB#Vid_04e8&Pid_681b#3586670328472810#{a5dcbf 10-6530-11d2-901f-00c04fb951ed}] open error: "Paramètre incorrect" FAILED TO SETUP PHONE Unlock FAILED Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866703284728] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866703284728 CERT:BROWN LDR:090325 1251 RFACXC1723918_A9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P5C LDR CAPS:SYSTEM FLASH SIGNATURE LDR:090325 1345 RFACXC1723919_1A9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P5C LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM UNFREEZE CODE: 63519613 [NETWORK UNLOCK] #7465625*638*50504075# Unlock DONE Elapsed: 229 secs. |
03-13-2012, 21:53 | #4 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Tarragona, Spain
Member: 36126 Status: Offline Thanks Meter: 311 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,26,0,35866*********] OTP LOCKED:1 CID:26 PAF:0 IMEI:35866********* CERT:BROWN LDR:090325 1251 RFACXC1723918_A9_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P5C LDR CAPS:SYSTEM FLASH SIGNATURE LDR:090325 1345 RFACXC1723919_1A9_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P5C LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM UNFREEZE CODE: 26195029 [NETWORK UNLOCK] #7465625*638*94052090# Unlock DONE Elapsed: 224 secs. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
