05-15-2009, 08:58 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | set com number nd press unlock nd connect cable if not boot press power button shortly if not then tick use server from setting nd try post result |
05-15-2009, 19:49 | #5 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Melilla, Espaņa
Member: 3389 Status: Offline Sonork: 100.1579083 Thanks Meter: 72 | setool and infinity select com port infinity in setool cable rj45 in setting signed mode and perform "full unlock.... press 2+5 insert cable pres on best regards |
05-16-2009, 13:00 | #7 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 201343 Status: Offline Thanks Meter: 26 | it is NEW MODEL CABLE .THEY ARE TWO TYPES .one was to back box&other was white box . which box are you using .then connect it.long cable with rj45 other end was like v3 socket in cable there are two hook for battery connecter donot connect it,insert battery then DIRECT UNLOCK. connect cable if not boot press power button shortly if not then tick use server from setting ..no logs want ENJOY |
05-19-2009, 11:58 | #10 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Prizren
Member: 841080 Status: Offline Thanks Meter: 177 | 5/16/2009 10:05:47 CFG:100000100000000 5/16/2009 10:05:47 PLEASE ATTACH TURNED OFF PHONE NOW 5/16/2009 10:05:47 PRESS "POWER ON" BUTTON SHORTLY... 5/16/2009 10:06:56 5/16/2009 10:06:56 EROM "R5A038" CID: 0001 5/16/2009 10:06:56 SOFTWARE CID: 0001 5/16/2009 10:06:56 SIMLOCK STATE: "NOT_TAMPERED" 5/16/2009 10:06:57 LOADER AID: 0002 5/16/2009 10:07:09 LOADER VERSION: "R3A006" 5/16/2009 10:07:09 5/16/2009 10:07:09 PHONE IMEI:30000000000000 5/16/2009 10:07:09 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" 5/16/2009 10:07:09 Checking for EROM signature... 5/16/2009 10:07:09 signature found, skipping calculation 5/16/2009 10:07:23 GOT SEED:B91978EAB37AD93E74D24974 5/16/2009 10:07:29 P96 AUTH PASSED 5/16/2009 10:07:29 Unlock DONE |
05-26-2009, 12:03 | #11 (permalink) |
No Life Poster Join Date: Jul 2004 Location: sri lanka
Member: 73323 Status: Offline Sonork: 1001664281 Thanks Meter: 68 | SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803312929 Checking for EROM signature... Waiting for calculation process... remote dongle daylimit reached signature calculation not done,err: 144 Elapsed: 19 secs. SIGNED MODE (USING SERVER) SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 2165, UNLOCK 2039 Elapsed: 3 secs. pls tell how to unlock |
05-26-2009, 23:24 | #12 (permalink) | |
Freak Poster Join Date: May 2008
Member: 763462 Status: Offline Thanks Meter: 8 | Quote:
05-27-2009, 05:35 | #13 (permalink) |
Member: 73323 Status: Offline Sonork: 1001664281 Thanks Meter: 68 | SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 22 secs. at what time will the server respond???? |
05-27-2009, 06:29 | #14 (permalink) |
Member: 73323 Status: Offline Sonork: 1001664281 Thanks Meter: 68 | SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 21 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 25 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 23 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 22 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 20 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... remote dongle is not working now signature calculation not done,err: 144 Elapsed: 31 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305615 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:185B2BFF0D5A54C1C7FB16D7 P96 AUTH PASSED Elapsed: 52 secs. SIGNED MODE (USING SERVER) SERVER CREDITS LEFT/USED: 28/2 CARD COUNTERS: FLASH 2165, UNLOCK 2039 Elapsed: 3 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803312526 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:266771487CB28053BD0870FE P96 AUTH PASSED Elapsed: 43 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803308833 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED:7EB60C8799FEDAD6415CDF54 P96 AUTH PASSED Elapsed: 35 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803305435 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:0B633ABE89AA803F20035D2E P96 AUTH PASSED Elapsed: 36 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803311684 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED:E7C2782057BFBF850DB90E6B P96 AUTH PASSED Elapsed: 38 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803312929 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:097C4392E14E4FA59C743D36 P96 AUTH PASSED Elapsed: 37 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803197818 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:593CFCBB07347EB712F4486D P96 AUTH PASSED Elapsed: 34 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" BAUDRATE NOT CHANGED FAILED TO SETUP PHONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 95 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803302061 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED:9C565DB67AB4A31F922EAF76 P96 AUTH PASSED Elapsed: 133 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803195769 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:AEFF89FCECDD66E92A7BB233 P96 AUTH PASSED Elapsed: 36 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 1 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803301871 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED5C2B3895E976773151AFAC1 P96 AUTH PASSED Elapsed: 39 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803195393 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:A1A257C32710E963FD239399 P96 AUTH PASSED Elapsed: 33 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" BAUDRATE NOT CHANGED FAILED TO SETUP PHONE Elapsed: 17 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 75 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803199835 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:189F101914056381744D9B27 P96 AUTH PASSED Elapsed: 32 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... PROCEDURE WAS STOPPED BY USER supported phone was not detected FAILED TO SETUP PHONE Elapsed: 215 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803194142 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2329) GOT SEED:E8109DE07AE09DCF0AE4BE23 P96 AUTH PASSED Elapsed: 36 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803205880 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED:5E1A379E494E0B2DA097DA7D P96 AUTH PASSED Elapsed: 39 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803193143 Checking for EROM signature... Waiting for calculation process... RESPONSE: "SUCCESS" (2359) GOT SEED:A8E5FF5E2E31788ACB4B6E30 P96 AUTH PASSED Elapsed: 36 secs. SIGNED MODE (USING SERVER) llbug: port 7 open error: "Access is denied" FAILED TO SETUP PHONE Elapsed: 0 secs. SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803311678 Checking for EROM signature... Waiting for calculation process... No credits left. signature calculation not done,err: 144 Elapsed: 19 secs. unlocked 15 thanks se tool |
05-27-2009, 10:13 | #15 (permalink) |
Member: 73323 Status: Offline Sonork: 1001664281 Thanks Meter: 68 | SIGNED MODE (USING SERVER) PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" CID: 0001 SOFTWARE CID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER VERSION: "R3A006" PHONE IMEI:35158803204207 Checking for EROM signature... Waiting for calculation process... remote dongle daylimit reached signature calculation not done,err: 144 Elapsed: 21 secs. again same problem! after i had unlocked 15phone's! At present i hav 120 phones to be unlocked! So i want an immediate solution for the above said problem! Best Regards, S.M.M. Zuhair |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
how to unlock se j132 and what cable need to unlock | masslarry | Sony Ericsson | 7 | 09-05-2009 10:10 |
Any solution to unlock Se J132 new security | noure30 | FuriousGold | 5 | 06-22-2009 19:28 |
help to unlock SE j132 with InfinityBo+Pinfinder | noure30 | Infinity-Box | 18 | 01-22-2009 00:20 |
