Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 03-29-2010, 11:38   #1 (permalink)
Member: 1041791
Thanks Meter: 12
HOW TO unlock SE v600i ??please help
HOW TO unlock SE v600i use se-tool ?
I can't find this model in se box .
please help
Old 09-26-2010, 17:18   #2 (permalink)
Member: 1285915
Thanks Meter: 35
Hello,
Is it possible to unlock V600i with Setool ? And what are the settings, please ? Thanks to all.
Old 09-26-2010, 17:59   #3 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Bro there two ways of unlocking this phone :
1. identify ur phone & download rest file from support , add in setool/rest folder then directly click on unlock tab. or
2. directly flash ur phone ( tick two options 1. complete phone after flash & 2. unlock phone after flash)
The Following User Says Thank You to sheikh1777 For This Useful Post:
Old 09-27-2010, 07:55   #4 (permalink)
vinaytoday's Avatar
Member: 130178
Thanks Meter: 42
v600 is there
go to sony erricson tab . select k600/V600/K608 model and do wht ever u want as regular
The Following User Says Thank You to vinaytoday For This Useful Post:
Old 09-27-2010, 09:17   #5 (permalink)
Member: 1285915
Thanks Meter: 35
Hello,
Please help me. My v600i is dead after flash. I chose the solutions 2 proposed by sheikh1777, and the phone is dead. Here is the log :
CFG:001100000000
ChipID:7100,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0049
Speed:921600
BAUDRATE DECREASED
OTP LOCKED:1 CID:49 PAF:1 IMEI:35683100009000 CERT:RED
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
STARTING BOOTLOADER...
INT LDR:050810 0923 DB2000_CRIPPLED_PRELOADER_SETOOL2_R2B
LDR:050926 1421 NPA1CXC1250164_SEMC_PRODUCTION R2D
FLASH ID: 200D
FOUND VERSION "R2T002_CXC1250074_EU_2_MI"
can't open file "C:\Documents and Settings\ordinatop\Bureau\Déblocage\SETOOL (Sony Ericsson)\V1.085\rest\R2T002_CXC1250074_EU_2_MI"
SWITCHING TO "USB"...
INTERFACE NOT CHANGED
Setting up GDFS...
WRITING CLEAR SIMLOCK UNITS...
SIMLOCK CODES SET TO "24012107"
SIGNING...
LDR:051125 1048 FILE_SYSTEM_LOADER_SETOOL2_V24
GDFS startup failed,error is 04 [1D]
loader GDFS startup failed, that is fatal
Elapsed: 90 secs.
After the settings, i clicked on "flash". Please help me to repair the phone.
Thanks to all.
Old 09-27-2010, 11:58   #6 (permalink)
Member: 99605
Thanks Meter: 57
gdfs corrupted you must doing reset procedure read faq
The Following User Says Thank You to siudziu For This Useful Post:
Old 09-27-2010, 12:50   #7 (permalink)
Member: 1285915
Thanks Meter: 35
Hello,
Thank you very much, siudziu, but i'm a beginner and i don't know much to use Setool. Then i think i can't make the thirst procedure in the faq. It's to much difficult for me. I don't understand it really.
Can you explain me simply what should i do step by step to repair the phone, please ?
Thanks to anyone can help me.
Old 09-27-2010, 17:02   #8 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Originally Posted by Adel_Khaled View Post
Hello,
CFG:001100000000
FLASH CID: 0049
Speed:921600
BAUDRATE DECREASED
THEN PRESS "READY"
FLASH ID: 200D
Setting up GDFS...
SIGNING...
Elapsed: 90 secs.
Thanks to all.
Bro where is flashing Log , Please attach it . i think u have done something wrong in flashing procedure
Old 09-27-2010, 17:22   #9 (permalink)
Member: 1285915
Thanks Meter: 35
Hello sheikh1777,
This was the log, after chosing 1 and 2 in settings, and clicking in "flash" button. What should i do now to repair the phone, please ?
Old 09-27-2010, 17:39   #10 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Hello sheikh1777,
this happened only because u have not added flash files as i say in point 2 .
now u download the two files from support area like this
1. r2t002_CXC1250074_EU_2_MI.ssw ( Main file)
2. r2t002_vfe1_fs.ssw (FS file )
while adding these two files follow point no. 2 it will be ok.
Old 09-27-2010, 20:26   #11 (permalink)
Member: 1285915
Thanks Meter: 35
Hello brother,
I have selected model k600/v600/k608. I have added the two flash files, as you ask me. Then i ticked options 3 (customize phone after flash) and 4 (unlocking during flash procedure). Then i clicked on "flash" button. But it failed to setup phone. Here is the log :
RUNNING v 1.085/UNI
CARD SERIAL 00145096
USBFLASH DRIVER VERSION 02.02.00.05
CFG:001100000000
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Elapsed: 131 secs.
What should i do, please ?
Thanks.
Old 09-27-2010, 20:50   #12 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,195
RUNNING v 1.089/UNI
CARD SERIAL 00000001
CFG:001100000000
Elapsed: 5 secs.
you can reproduce that error without phone
Check the cable, clean the connector with a needle
The Following User Says Thank You to :Aishur: For This Useful Post:
Old 09-28-2010, 20:32   #13 (permalink)
Member: 1285915
Thanks Meter: 35
Hello,
I have tried several times, and checked cable and connector. The phone doesn't start. It doesn't react at all.
Help me please. Thanks to all.
Old 09-30-2010, 08:10   #14 (permalink)
Member: 1285915
Thanks Meter: 35
Hello,
Nobody can help me more ? Any solution, please ?
Thanks to all.
Old 09-30-2010, 13:06   #15 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
Check cable and correct port setting
How to unlock motorola c385? PLEASE HELP ME maro176 Motorola P2k 1 01-29-2006 19:44
How to Unlock new Z500 !!! please help shotbyuzi QUALCOMM Models (3G) 2 06-10-2005 17:39
how to unlock sgh-a800...please help... mannny VLSI, Conexant, Skyworks and Old Models 6 04-21-2004 00:54
How to unlock SGH-S105 - Please help! yeldar Trident/AGERE Platform 2 11-03-2002 23:55
how to unlock sagem MC827FM please help hrflik Infineon C16X M51 & ARM7 M52 BASED 0 02-22-2002 11:44
Page generated in 0.44181 seconds with 8 queries
