11-15-2007, 20:23 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | then you must need to download patch file for your required firmware then check use server and alternative security bypass option then you can unlock easily your phone with in few seconds ......................enjoy setool! |
01-29-2008, 22:12 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | Dear brother,, No need logs patch unlock free solution First upgrade ur phone 49-CID52 Select the file -in -misc folder Press-write script button..connect cable -cid upgrade in process """""""""""""""""""""""""""""""""""""""""""""""""" """""""""""""""""""""""""""""""""""" Press identify....u will see ur phone flash CID52 Step-2 Add flash file Main +fs according to cid52 Go to setting tab....Chk complete after flash +unlock after flash+use server for CSCA unlock(password- blank ***) + alternative security bypass Then press Flash............connect cable """""""""""""""""""""""""""""""""""""""""""""""""" """"""""""""""""""""""""""""""""""""" Use DCU-60 its always better........... Its complete free HERE |
The Following User Says Thank You to Jr Telecom For This Useful Post: |
08-03-2012, 14:30 | #7 (permalink) |
No Life Poster Join Date: Jul 2008 Age: 40
Member: 807542 Status: Offline Thanks Meter: 194 | SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: 9900, EMP protocol: 0301 PHONE DOMAIN: "RETAIL" PHONE CID: 0053 SPEED: 921600 LDR: 071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301578066 CERT:RED CURRENT CID: 53 COLOR: RED FLASH ID: 897E Downgrading security ... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 RESET: 070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA GOT SEED: 4B3744972380236C1520218D P96 AUTH PASSED Restarting ... PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") ChipID: 9900, EMP protocol: 0301 BOOTROM MODE DETECTED SPEED: 921600 LDR: DB2020 LOADER FOR SETOOL2 CURRENT CID: 49 COLOR: BROWN Setting up GDFS ... WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "03711202" SIGNING ... Unlock DONE Elapsed: 30 secs. |
How to unlock C702 with SE-Tool | kamransohail786 | SETool2 | 11 | 05-23-2009 03:29 |
how to flash p990i with se tool? | kapilkapoor | SETool2 | 5 | 06-08-2008 19:14 |
how to flash p990i with se tool.pls guide | kapilkapoor | SETool2 | 1 | 06-07-2008 18:53 |
how to flash p990i with se tool? | REMO | Sony Ericsson | 5 | 05-03-2008 19:01 |
