Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-06-2008, 22:59   #1 (permalink)
wirelessrush's Avatar
Member: 220548
Exclamation How to unlock Z310a and flash S710a
I just got done installing my new SE Tools3 v0.914029. Can someone briefly give me instructions on how to How to unlock Z310a and flash S710a? Thanks
Old 06-07-2008, 20:36   #2 (permalink)
Member: 220548
with all of these experts on this forum, noone has any idea?
Old 06-07-2008, 20:57   #3 (permalink)
chimeto's Avatar
Member: 463420
Man, search in support for version v***x.33 or 34 is the last version. After that install in folder where is your ***.29 version.
When make this operations search in www.mo*****-fi****.com!!!!! SEtool forum. there have video and manual..
You will be needed from operator card... or any TORNARDO SIM, MT SIM.
It's from me, just search for new method of unlocking db2020 cid52/53 and db2010/12 ....
The Following User Says Thank You to chimeto For This Useful Post:
Old 06-07-2008, 20:58   #4 (permalink)
Crazy Poster
Member: 430690
Restore mode :
http://www.techgsmnet.com/unlock-mob...re-method.html
Flash Mode:
http://www.techgsmnet.com/unlock-mob...sh-method.html
The Following User Says Thank You to abo amine For This Useful Post:
Old 06-07-2008, 22:00   #5 (permalink)
Member: 220548
thanks for the replies. I will try and post results in a few days.
Old 06-28-2008, 02:25   #6 (permalink)
Member: 220548
Abo amin,
Thanks alot man. It worked like a charm.
Old 06-28-2008, 03:02   #7 (permalink)
Member: 220548
I unlocked the Z310a. Any idea on how to flash the S710a? It is an older model so I cannot find any helpful posts when I do the search. SETool3 will not see the phone in USB mode. When I try to use UFS I get: v0.914036/UNI
CARD SERIAL: 000***xx
Loaded 51 flash descriptors
Connecting to UFS...
UFS subsystem unavailable (drivers not installed)
I would appreciate your help. thanks
Old 06-28-2008, 13:39   #8 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Solution is Already Given By Soft...
Old 06-28-2008, 21:05   #9 (permalink)
Member: 220548
Skylinks,
Thanks for taking the time to reply. So is this driver for the box and available from the downlad section of the support? A link would be much appreciated if it's not too much trouble.
Old 06-29-2008, 09:41   #10 (permalink)
Member: 300354
Sonork: 100.1577485
Drivers Can be Found In Setool Sub Directory
Setool%Setup\drivers\UFS_driver
Old 06-30-2008, 19:27   #11 (permalink)
Member: 220548
Sorry for all of these trivial questions. I have located the files in these three folders: 1.06.06, 2.02.04, and 3.01.04. None of the files are executable. What is the next step? Thanks
Old 07-01-2008, 13:24   #12 (permalink)
Member: 300354
Sonork: 100.1577485
Wich OS you are using?
Advice to Remove Already installed Drivers By Running "UFS2XXUN" & Then install "3.01.04"...
Old 07-02-2008, 01:50   #13 (permalink)
Member: 220548
I am running Windows XP.
Old 07-08-2008, 16:46   #14 (permalink)
Member: 220548
Any additional help would be appreciated.
Old 04-27-2009, 02:20   #15 (permalink)
Member: 391768
Can you please explain how the procedure how you unlock the Z310a? I have one and don't know how to unlock it. Please help
how to unlock w376g and flash file lilong_lee Smart-Clip 3 02-15-2010 12:42
how to unlock z310a cid51 derk Cruiser Suite 2 05-28-2008 08:09
how to unlock z310a with dreambox geepee777 DreamBox 4 05-11-2008 17:15
How To Unlock V600 And Flash? petermobil Cruiser Suite 2 09-27-2005 09:46
how to unlock N620 and flash r220? Siemens man VLSI, Conexant, Skyworks and Old Models 0 08-01-2002 00:56
Page generated in 0.42900 seconds with 11 queries
