02-24-2010, 03:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Pinas
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | How to work with a2-based phones Code: - a2 phones can only be served in signed mode. - same firmware can be flashed on allowed CID range, you can see CID range in fw name - firmware for specific phone domain (color) can only be applied to phone with same domain GSMBAGUIO |
02-24-2010, 03:25 | #2 (permalink) |
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | FLASHING OF A2 PHONES common for all CID: 1. go to semc a2 tab, select proper model 2. add to firmware area correct MAIN, FS IMAGE parts of firmware. order not important. 3. select in misc. field needed CUSTPACK (.zip archive with customization files) 4. if you do not have CUSTPACK, you MUST check on settings "customize phone after flash" 5. set "signed mode" on settings tab. 6. set other settings according your needs. 7. back to semc a2 tab, press flash. CID 54,60,185,186 skip step 3,4. |
The Following User Says Thank You to GsmBaguio For This Useful Post: |
02-24-2010, 03:25 | #3 (permalink) |
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | UNLOCKING OF A2 PHONES CID 49,51,52,53 standalone usercode reset 1. select proper model 2. on settings, check "signed mode" 3. back to semc a2 tab, press unlock CID 49,51,52 standalone full reset-based unlock 1. select proper model 2. select needed domain (leave "current" for no change) 3. on settings, check "signed mode","use alternative security bypass" 4. back to semc a2 tab, press unlock that method can fix damaged SCRC and fixing SEMCBOOT automatically. that is preferred method for such phones. server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. CID 53 server-based full reset-based unlock 1. select proper model 2. select needed domain (leave "current" for no change) 3. on settings, check "signed mode","use alternative security bypass", fill login details 4. back to semc a2 tab, press unlock that method can fix damaged SCRC and fixing SEMCBOOT automatically. server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. that is preferred method to unlock such phones. CID 54,60,185,186 standalone full unlock 1. select proper model 2. on settings, check "signed mode" 3. back to semc a2 tab, press unlock that method can fix SCRC. that is preferred method to unlock such phones. |
02-24-2010, 03:32 | #4 (permalink) |
Member: 1243303 Status: Offline Sonork: 1591167 Thanks Meter: 514 | POSSIBLE PROBLEMS AND METHODS OF REPAIR CID 49,51,52,53 damaged trim area (ta_open errors) 1. select proper model or model,based on same chipset 2. skip that step, if phone already r&d (brown). convert phone to r&d (brown) domain, for that unlock phone in alternative security bypass mode with brown domain set. 3. if your phone based on db3150 chipset - add to firmware area Shinobu_TA.ssw if your phone based on db3200 chipset - add to firmware area elle_ta.ssw if your phone based on db3210 chipset - add to firmware area Shiho_TA.ssw if your phone based on db3350 chipset - add to firmware area aino_ta.ssw 4. set ecc mode: none (0) 5. on settings, check only signed mode 6. press flash 7. get gdfs package from proper model working phone, add it to misc. field 8. press write gdfs 9. unlock phone using alternative security bypass mode 10. reflash phone fully. phone does not startup or stuck on "please wait" unlock phone using alternative security bypass CID 54 phone stuck on lg logo. first reflash phone fully with latest firmware version. if that not help, then 1. select proper model, on settings check only "signed mode" 2. if your phone db3150,add to firmware area kf75x_syspart_fix.ssw if your phone db3200, add to firmware area gt505_syspart_fix.ssw 3. press unlock 4. press clear name 5. reflash phone fully if phone still hangs on lg logo, redo operation with different step 2: 2. if your phone db3150,add to firmware area kf75x_syspart_fix.ssw,kf75x_drm_fix.ssw if your phone db3200, add to firmware area gt505_syspart_fix.ssw,gt505_drm_fix.ssw 6. if needed, write gdfs package from proper model working phone, unlock phone after CID 60,185,186 1. unlock phone 2. reflash phone 3. if needed, write gdfs package from proper model working phone, unlock phone after Attached Files * File Type: zip kf75x_drm_fix.zip http://rapidshare.com/files/35496295...m_fix.zip.html |
How to work with semc odm phones | GsmBaguio | SETool2 | 9 | 06-11-2010 11:46 |
How to work with semc pda phones | GsmBaguio | SETool2 | 6 | 02-24-2010 09:36 |
how do work e-gold base phone in INFINITY | debmobile | Infinity-Box | 6 | 07-17-2009 10:25 |
How To Flash Nxp Cpu Based Phone In Chinease Miracle | Vijendra Saini | Infinity-Box | 3 | 05-08-2008 10:55 |
How to work with Full flash in Samsung phones ! | GSM SNIPER | UFS2 + UFS3-Tornadoflasher | 3 | 01-30-2005 08:20 |
