Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 05-12-2012, 18:31   #16 (permalink)
Member: 163933
Sonork: 100.1608969
Thanks Meter: 13
Yeah man i used micro sd card, 3V+ from Simos battery
Thanks for ur reply.
Old 05-12-2012, 22:13   #17 (permalink)
Member: 163933
Sonork: 100.1608969
Thanks Meter: 13
Boshko_Alfa
BRO U SUCEED ON WINDOW7 OR SP SERVICE PACK,
EVEN v1.62,WITH NEW VERSION I VE SAME ERROR........
TOMMOROW I WILL TEXT ON ANOTHER PC AM USING CORE i7, pc
Old 05-12-2012, 23:12   #18 (permalink)
Member: 163933
Sonork: 100.1608969
Thanks Meter: 13
Searching microSD disk...
MicroSD disk found:
Volume: H:\
Device: \\.\PhysicalDrive1
Label: HTCTOOL
Writing image to microSD disk...
Writing image to microSD disk: OK
Waiting for User's Actions...
MicroSD disk found:
Volume: H:\
Label: HTCTOOL
Reading codes...
Connecting to server...
Sending data to server...
Receiving data from server...
Server Error: Incorrect Phone Data
Action cancelled
Old 05-14-2012, 15:29   #19 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,313
I thik it's not a PC problem i use this service on cheap intel machine of 100$ with XP SP2. Also have one lap top fujitsu with i5 on win 7 32x work's perfectly.
Give more information about ur phone here and all steps what u doing.
Old 05-15-2012, 07:59   #20 (permalink)
Member: 163933
Sonork: 100.1608969
Thanks Meter: 13
I follow the instruction carefully ACCORDING to setool, only ommited step removed battery, HTC FLYER CANT REMOVED BATTERY, THEN I SWITCH OFF AND SWITCH ON BACK, REMOVED USB CABLE , DITACHED POWER SUPPLY FROM SD/CARD.
Old 05-28-2012, 09:20   #21 (permalink)
Cheater -Don't Deal with him-
Member: 354557
Thanks Meter: 592
LGE Tool version: 1.63
OS Version: Windows XP [NT 5.1] Service Pack 3
Administrative privileges: yes
Locale: UnitedStates / English
CPU frequency: 2499 MHz
Total memory: 2035 MB
Free memory: 1496 MB
Free space on system disk C:\: 2.00 GB
Free space on disk D:\: 43.00 GB
Free space on disk E:\: 45.00 GB
Free space on disk F:\: 38.00 GB
Free space on disk G:\: 42.00 GB
You have small amount of free space on system disk C:\. Recommended free space is 5 GB or more.
Connecting with One V
To connect with this phone you should use special microSD cable.
Press the button "Cable" to view pinout.
In order to make microSD cable you should do the following:
1. Get microSD card (from 8Mb to 4Gb, don't use SDHC).
2. Get two thin wires.
3. Solder first wire to microSD to pin4(+2.8V..+3.3V).
4. Solder second wire to microSD to pin6(GND).
5. You can use any +3V source (even 2xAAA) as power supply.
6. Also you should use microSD card reader.
7. External power supply(+3V) needed only for the phone microSD reader.
8. Do not use external power supply with PC microSD reader.
WARNING: Don't forget to click "Disconnect" at the end.
Connected
Reading codes
MicroSD disk found:
Volume: J:\
Device: \\.\PhysicalDrive3
Label: HTCTOOL
MicroSD disk found:
Volume: J:\
Label: HTCTOOL
Reading codes...
Unlock codes:
NCK: 27119445
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
The Following User Says Thank You to ...:::JamalMustafa:::... For This Useful Post:
Old 07-01-2012, 17:51   #22 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 769
i tried but not success
i sold thin wires on mmc and insert it in mmc card reader then
software cant search card reader
how to do that?
i have windows 7 64bit
i connect wires with powersupply means dragon box supply but cant detect card reader device
any advice?
Old 07-03-2012, 16:31   #23 (permalink)
Member: 44904
Thanks Meter: 43
where insert sdcard in phone Htc one x?
Old 07-09-2012, 14:11   #24 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
I used 1G sdcard.
MicroSD disk found:
Volume: G:\
Label: HTC STORAGE
MicroSD disk found:
Volume: H:\
Device: \\.\PhysicalDrive2
Label: HTCTOOL
Reading codes...
Unlock codes:
NCK: 32344573
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
nice trick lgtool, but need to be more user friendly for other users.
Old 07-09-2012, 14:20   #25 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
how to do that?
any advice?
In PC card reader do NOT put power supply. Power supply goes just when sdcard is in phone.
The Following User Says Thank You to unlock.mk For This Useful Post:
Old 07-10-2012, 15:07   #26 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 243
Here it is one more success. log:
Reading codes...
Unlock codes:
NCK: 52482372
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
I can not say that steps are explained like it should, it is not user friendly, but unlock works perfect. Ican confirm that.
Old 07-10-2012, 17:24   #27 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 332
Originally Posted by Boshko_Alfa View Post
1. put memory card micro sd 4gb in card reader
2. follow lg e tool operation
3. solder 2 wires and conect to power supply, set to 3v
4. put memory card in phone and try to power device, not in download mode/hboot mode - just press power - than will shown NOTHING just wait about 30 seconds
5. after that remove memory card from phone and put again in card reader and follow next instruction
6. after few seconds LGeTool will make calculation and give ur correct codes for unlocking.
7. but phone is stucked, press volume down + up and power about 1 minute and phone will restart/swtich on
tommorow i will post picutre of modifed memory card, but i think that this is no needed - it's very simple
HTC one X dosen't have any microSD
how to unlock it?
...on imei calculation tab via server I get UNSUPPORTED IMEI!!!....
Old 07-31-2012, 12:22   #28 (permalink)
Member: 67571
Reading codes
MicroSD disk found:
Volume: J:\
Device: \\.\PhysicalDrive4
Label: HTCTOOL
MicroSD disk found:
Volume: J:\
Label: HTCTOOL
Reading codes...
Unlock codes:
NCK: 36269538
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
Old 10-03-2012, 09:32   #29 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 855
1. Get microSD card (1Gb or 2Gb, don't use SDHC).
Connected
Reading codes
MicroSD disk found:
Volume: J:\
Label: HTCTOOL
MicroSD disk found:
Volume: J:\
Label: HTCTOOL
Reading codes...
Unlock codes:
NCK: 11213690
NSCK: NONE
SPCK: NONE
CPCK: NONE
SIMCK: NONE
Read codes success
Don't forget to post success story on official LGTool forum.
Disconnected
Old 10-03-2012, 11:30   #30 (permalink)
SJS
SJS's Avatar
Member: 14684
Thanks Meter: 59
HTC One X locked Austria three, vers. 4.03 unlock error
Connecting with One X
In order to connect with phone you should:
1. Install HTC ADB drivers
2. Turn on the phone
3. Enable Debug mode in phone (Settings->Applications->USB Debug)
4. Check your Internet connection
5. Plug USB Cable
Probing ADB Interface...
Android Debug Bridge version 1.0.29
Starting ADB server...
Waiting for device...
Device Found: SH273W101517
Connected
Receiving phone info
Waiting for data...
Waiting for boot completion...
Waiting for device id...
Getting data...
Serial Number: SH273W101517
Android Version: 4.0.3
Manufacturer: HTC
Model: HTC One X
Hardware: endeavoru
ROM Version: 1.29.771.11
BOOT Version: 0.96.0000
IMEI: 353426-05-861401-7
CID: H3G__106 / H3G-AT
Backup CID: H3G__001
Linux Kernel Version: 2.6.39.4-gc9932b1
Info received
Reading codes
Getting Root Privileges...
Probing #3...
Preparing exploit...
Rebooting device...
Sending exploit... Please wait...
Rebooting device...
Reading HBOOT...
Patching HBOOT...
Adb: AdbCmdFail: cmd=devices, exit=1, output=adb server is out of date. killing...
* daemon started successfully *
, error=** daemon still not runningerror: cannot connect to daemon
Can anyone help ??
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.37354 seconds with 8 queries
