11-03-2011, 22:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | I can not unlock any phone!!!!!! Offline !!!! S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1201 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 26, UNLOCK 153 Elapsed: 5 secs. srv01.dontexist.com |
11-04-2011, 12:17 | #5 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | Try this Method to Unlock Ur Set.. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. Read Care Fully these lines on Yellow colour Try & Post Result... |
11-04-2011, 14:06 | #6 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | [QUOTE=Danish Shafiq;7860557]Try this Method to Unlock Ur Set.. you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. Read Care Fully these lines on Yellow colour Try & Post Result...[/QUO WHY THIS NOW RUNNING v 1.1107/01.12/UNI CARD SERIAL 00017215 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 llbug:read error: "El parámetro no es correcto" Can't load ID loader ! Elapsed: 94 secs. CFG:000000000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:0123820XXXXXXCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\Administrador\Escritorio\R7CA058.FS_CS_TO _REDBROWNBLUE_CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 2369 blocks ... ssw file accepted Elapsed: 323 secs. UNLOCKING RUNNING v 1.1107/01.12/UNI CARD SERIAL 00017215 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 llbug:read error: "El parámetro no es correcto" Can't load ID loader ! Elapsed: 94 secs. CFG:000000000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200XXXXXXCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\Administrador\Escritorio\R7CA058.FS_CS_TO _REDBROWNBLUE_CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 2369 blocks ... ssw file accepted Elapsed: 323 secs. SIGNED MODE (USING SERVER) CFG:100010000000 credits consumption for full signature unlock: S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1201 SERVER CREDITS LEFT/USED: 0/0 CARD COUNTERS: FLASH 27, UNLOCK 153 Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01238200XXXXXXCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 15 secs. |
11-04-2011, 14:34 | #8 (permalink) |
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | pla i u can see i am having SERVER CREDITS LEFT/USED: 14/16 RUNNING v 1.1201/01.12/UNI CARD SERIAL 00017xxx USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 credits consumption for full signature unlock: S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1201 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 27, UNLOCK 153 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 0/0 CARD COUNTERS: FLASH 27, UNLOCK 153 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 27, UNLOCK 153 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:012382009xxxxCERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 33 secs. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
