11-03-2010, 03:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 534073 Status: Offline Thanks Meter: 68 | SE TOOLS server dongle not available SOFTWARE AID: 0001 SIMLOCK STATE: "NOT TAMPERED" LOADER AID: 0004 FLASH ID: "00EC/0040" LOADER VERSION: "R4A044" PHONE IMEI:01219700002xxx Checking for signature... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 20 secs. to SETOOLS pls.post how long to wait SERVER dongle online.pls. send the user |
11-03-2010, 11:51 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Spain
Member: 595735 Status: Offline Thanks Meter: 20 | RUNNING v 1.087/UNI CARD SERIAL 00010051 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100369805 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 52 secs. |
11-03-2010, 11:55 | #7 (permalink) |
Member: 595735 Status: Offline Thanks Meter: 20 | SERVER STATUS S1 signature (finish part u1,u5,u8 AID 004,a2 cid81,full unlock/repair for s1 neptune,locosto) server status: OFFLINE please note, that s1 signature server not working on weekends and national holidays. A1/A2 signature server,A1/A2/S1 reset station,A1 csca station status: ONLINE support site status: ONLINE ...... and we cant unlock u10 and u5 :-( |
11-03-2010, 12:26 | #8 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | Posted 10x times CID 80,81 server-based full signature unlock 1. select proper model 2. on settings, check "signed mode","do full unlock instead usercode reset",fill login details 3. back to semc a2 tab, press unlock that method can not fix SCRC. if s1 signature server offline, you can not use quick (without modem drivers) unlock. instead, you should : 1. select proper model 2. on settings, check "signed mode", "do full unlock instead usercode reset", "disable flash mode activation for semc a2 phones", fill login details 3. back to semc a2 tab, press unlock 4. when prompted, install phone modem drivers (they can be found in drivers\Modem_Drivers or will be automatically installed if you install semc pc suite) 5. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. |
The Following 3 Users Say Thank You to :Aishur: For This Useful Post: |
11-09-2010, 10:24 | #9 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 541592 Status: Offline Thanks Meter: 45 | RUNNING v 1.085/UNI CARD SERIAL 00009914 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:F002,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01229100340356] OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100340356 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100340356 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... No credits left. signature calculation not done,err: 144 Unlock FAILED Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 29/1 CARD COUNTERS: FLASH 1230, UNLOCK 779 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100340356 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 7 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 27/3 CARD COUNTERS: FLASH 1230, UNLOCK 779 Elapsed: 2 secs. why use 2 credit ? |
11-09-2010, 10:48 | #10 (permalink) |
Freak Poster Join Date: Jul 2006 Location: lusaka
Member: 320108 Status: Offline Thanks Meter: 18 | OOPPSSS....I MANAGED TO UNLOCK W20 after losing 2 credits..... thanks AISHUR .... i feel setool should make some info available when updating the software.... |
07-23-2011, 01:41 | #12 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 158999 Status: Offline Thanks Meter: 41 | RUNNING v 1.1094/01.11/UNI CARD SERIAL 00071935 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 18/12 CARD COUNTERS: FLASH 189, UNLOCK 202 credits consumption for full signature unlock: S1 v1 4 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 6 credits ( AID 004 OFFLINE ) A1 phones 6 credits A2 phones 6 credits ( DO NOT USE FOR J108 ) by codes 4 credits current setool2 version: 1.1094 Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F002,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:01229100xxxxxx CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 16 secs. help admin setoll waths hapent |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
dongle.exe | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-22-2000 04:40 |
I will finished Dongle for Nokia WinTesla | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-14-1999 22:47 |
