06-16-2013, 13:51 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Brother! tools: setool box w/1 credit usb cable testpoint wire procedure: run setool click PDA & select model click SETTINGS check 1,2 & 5 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE Regards |
The Following User Says Thank You to Haicha For This Useful Post: |
06-16-2013, 13:54 | #5 (permalink) |
Member: 330579 Status: Offline Thanks Meter: 67,515 | |
06-16-2013, 16:55 | #6 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: hungary Age: 43
Member: 78731 Status: Offline Thanks Meter: 4 | Quote:
this proced kill a phone whit a testpoint but not used credit i test a credit verzion monday | |
06-16-2013, 17:59 | #7 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | 1. from your log i can see, that setool2 did nothing to phone, so if phone dead after this log, it can only be because of badly done testpoint. 2. it is also possible, that usb port power not enough. to avoid this, when setool2 ask you to remove testpoint, do next: remove testpoint, insert battery in phone, then press "ready" 3. you using outdated setool2 version. always use current setool2 version. |
06-16-2013, 19:19 | #9 (permalink) | |
but a battery proc is not tested test from monday and send a log thx | |
06-18-2013, 11:10 | #11 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | if you used my advice with battery, then only option left for you - try different usb port/usb cable or even different pc. if still same things with different usb port/cable, then it seems that you had damaged something during testpoint application. |
