Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 06-11-2010, 06:29   #1 (permalink)
anpha72000's Avatar
Member: 441539
Sonork: www.kythuatdidong.com
Thanks Meter: 130
I open setool v1.07>>error HELP me
I have problems :
Active OK,
but :I open setool v1.07>>error : "cannot find gdiplus.dll..".i copied to folder setool file gdiplus.dll,but not OK
Another PC>>>no OK
Please hepl me.Thank
The Following User Says Thank You to anpha72000 For This Useful Post:
Old 06-11-2010, 07:20   #2 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
help me plz Product Supporter
Old 06-11-2010, 07:26   #3 (permalink)
Member: 235906
Thanks Meter: 53
Which operating system are you using?
Old 06-11-2010, 07:29   #4 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
i using window xp 2
Old 06-11-2010, 07:35   #5 (permalink)
Member: 235906
Thanks Meter: 53
try install this - Download details: Platform SDK Redistributable: GDI+
Old 06-11-2010, 07:46   #6 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
thank bro but not work .where is folder extract file
Old 06-11-2010, 07:54   #7 (permalink)
Member: 235906
Thanks Meter: 53
On my pc i have 3 copies of gdiplus.dll in different folders -
1- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.0.0_x-ww_8d353f13
2- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.2600.3180_x-ww_80b67041
3- C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df
So, try to create the same folders on your pc manually and put gdiplus dll in...
The Following User Says Thank You to Dimon_daemon For This Useful Post:
Old 06-11-2010, 08:01   #8 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
thank bro but not working .same problem
Old 06-11-2010, 08:04   #9 (permalink)
Member: 235906
Thanks Meter: 53
have you try installing GDI+ from attachment?
Old 06-11-2010, 08:07   #10 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
yes i try but same problem
Old 06-11-2010, 08:08   #11 (permalink)
Member: 235906
Thanks Meter: 53
I guess you have try this latest build of setool RapidShare: 1-CLICK Web hosting - Easy Filehosting
Some peple reported they have same prob with previous releases
Old 06-11-2010, 08:18   #12 (permalink)
Member: 235906
Thanks Meter: 53
From one IT forum -
"I had the following problem: many programs would crash and the casue was always gdiplus.dll. Crashing programs included among others Office 2003, Paint Shop Pro, Corel Draw, AQQ and some others.
I found the reason, and fixed my system, but my solution is not included in this thread -- hence my post.
The reason was a CORRUPTED FONT. In my case it was ukai.ttf. After deleting this file from my C:\Windows\Fonts folder, the problem was solved.
To see if this is your case, we need to first replace all your fonts with good ones (from the original WindowsInstallation CD). If the problem is gone, then we go hunting for a of*****ng font file from your old set. So:
1) Open your Windows Installation CD and copy all *.tt_ files to some folder.
2) Extract all fonts using extract or expand tool (or any tool that you know and works). This is your "clean set of fonts". Delete the *.tt_ files (compressed ones) since we won't need them no more.
3) Move all your C:\Windows\Fonts\*.ttf files to some other folder.
4) Copy the "clean set" to C:\Windows\Fonts\.
Note: Points 3 and 4 may require doing it in some other tool than Windows Explorer. In my case I used File Commander, but I guess any other similar tool would work - Total Commander, FAR, etc.
5) Restart the system (not sure if it's needed, but just to be sure
6) Check if the probelm is gone. If so, then it was one of the fonts that causes the problem (see point 7). If not, just reverse points 3 and 4 and look for other reasons.
7) Open C:\Windows\Fonts\ in Windows Explorer (you should see font names, NOT file names!). In some external file manager (as mentioned above) copy fonts from the old set to C:\Windows\Fonts\ -- but do so in groups of 10.
8) After copying you should see additional fonts appearing in Windows Explorer window (showing font names). This means that Windows sees the fonts you copy, and activates them. After each 10 fonts are activated run the program that would cause gdiplus.dll error. If there's no error -- copy another 10 font files. If the error appears -- one (or more) of the last 10 copied font files is causing the probelem.
9) Continue until you have the probelm fixed, and almost all of your old fonts back in place.
Hint: it may be advisable to start with largest font files (in my case the of*****ng ukai.ttf was about 17MB or so)."
Old 06-11-2010, 08:23   #13 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
same problem plz supporter FIX version
Old 06-11-2010, 08:40   #14 (permalink)
Member: 235906
Thanks Meter: 53
In most cases problem is on your pc. maybe some soft changed system files and you got this error... you can try it on fresh pc or virtual machine like vmware. Just for sure.
Old 06-11-2010, 08:43   #15 (permalink)
anpha72000's Avatar
Member: 441539
Thanks Meter: 130
i setup new window xp this same problem
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.34039 seconds with 10 queries
