02-23-2010, 14:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | .:imei change tutorial for sonyericsson:. Choose correct model (only DB2000/DB2010 phones supported, from 093 version CID49/51 DB2012/DB2020 phones supported via patch, from v0.914029 DB2010/DB2020/PNX5230 CID49/CID50/CID51/CID52/CID53 supported via patch) 2. Choose "SETTINGS" tab. Check "PATCH OTP<>GDFS CHECK IN FIRMWARE" "ALLOW TO CHANGE IMEI WHEN UNLOCKING" for DB2012/DB2020 only "USE SERVER FOR UNLOCK/FLASH" "USE ALTERNATIVE SECURITY BYPASS" 3. go back to SEMC tab, press UNLOCK 4. when prompted, enter needed IMEI, NOTE: for pnx5230/db2012/db2020 phones REAL IMEI NOT changed, flashpatch "forges" IMEI via some trick. no worry though, network (and customer) will see NEW IMEI. but, once phone will be updated on SEUS it will return to original IMEI. same applies to flashing main part of firmware. you need 1 credit to change IMEI for db2010/db2020/pnx5230 phones cid49/cid50/cid51 phones, you not need anything for cid52/cid53 db2010/db2020/pnx5230 phones (setool2 version should be >=v0.914029) you NOT need anything for cid49 db2000/db2010 phones. BE AWARE THAT CHANGING IMEI IS ILLEGAL AND PROHIBITED BY LAW. USE IT FOR EDUCATIONAL PURPOSE OR WHEN YOU HAVE CHANGED FLASH CHIP WITH ALREADY FILLED OTP!!! |
The Following 3 Users Say Thank You to roney_nexus For This Useful Post: |
02-23-2010, 14:17 | #2 (permalink) |
Insane Poster Join Date: Mar 2009 Location: Bangladesh Age: 36
Member: 997427 Status: Offline Sonork: 100.1590909 Thanks Meter: 26 | Emergency Mode (Part1) Procedure=Press Send+C+Camera+on/off Buttons Supported Models KE990,KU990,U990 (Part2) Procedure=Press 2+5+on/off Buttons Supported Models CU Series-CU500,CU720,CUXXX U Series-U300,U310,U370,U450,U830,U880,U890,U900,U960,U970 KU Series-KU250,KU310,KU380,KU385,KU450,KU730,KU800,KU950,KU 960,KU970 MU Series-MU515,MU550 L Series=L600I,L600V Note:-U300,U890... If Doesnt Show Emergency Mode They Will Appear 3 Logo On The Screen Add Infraction for roney_nexus Report Post IP Edit/Delete Message |
02-23-2010, 19:11 | #3 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
hay mate where i wrong for post,it is help us junior member..... | |
Changing imei for A2 | suhail1 | Cruiser Suite | 4 | 04-04-2010 16:27 |
** How to make PM & RPL Backup and restore for BB5 or DCT4++ **Tutorial For JAF ** | gopalhot | Nokia Hardware & Hardware Repair | 10 | 09-28-2008 17:39 |
Looking for a Tutorial for w900 house opening | mkk426 | Cruiser Suite | 3 | 02-23-2006 12:18 |
Font changing tutorial for 7710! | Reko | Nokia Multimedia | 0 | 09-13-2005 13:55 |
need tutorials for writing software for mobile phones | ruval | GSM Programming & Reverse Engineering | 0 | 02-27-2003 10:39 |
