Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 05-20-2012, 15:39   #1 (permalink)
Member: 747981
Thumbs up j 108i insert correct usim
RUNNING v 1.1286/01.10/UNI
CARD SERIAL 00092718
USBFLASH DRIVER VERSION 02.02.00.05
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100241205 CERT: RED
FIRMWARE VERSION NOT SUPPORTED
Elapsed: 17 secs.
i do new FIRMWARE VERSION flash but no solve
plsssssss halp me verry quick
Old 05-20-2012, 15:52   #2 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
correct method and procedure here :
HOW TO WORK WITH A2-BASED PHONES
Old 05-21-2012, 11:41   #3 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
q:
how to unlock j108 phone without s1 signature server to be online ?
a:
you need to have setool2 v1.1285 or higher.
you need to have test sim card ( with mnc/mcc 00101 ) in phone.
you need to have memory card in phone.
you need to have valid username/password with at least 3 credits.
phone should be in working state.
procedure is complicated and definitely NOT for beginners.
1.
flash any R7EA011 firmware into phone.
fully power on phone, wait until phone setup will be completed.
this is absolute requirement.
important !
do identify before unlock steps or make trim area backup.
that will greatly help you if anything will go wrong.
2.
run setool2, check that valid username/password entered, then go to "j108 bypass" tab.
press "upload executor package"
insert test sim card, memory card, connect powered off phone while holding "C" button
after initial procedure, disconnect phone , power on it, wait until setup complete and power off phone again.
3.
press "upload executor extractor"
set usb connection in phone options to "file transfer" and copy from memory card "other\executor.b" to setool2\backup\%imei% .
setool2 will open that folder for you in minimized state, check taskbar.
( if your system recognize phone as MTP device, you can copy file without setting USB connection to "file transfer" )
power off phone.
4.
press "unlock phone"
set usb connection in phone options to "other OS"
install phone MODEM drivers, if required ( dist\drivers\Modem_Drivers )
wait, until setool2 finish procedure.
after setool2 finish procedure, do not disconnect phone from cable, do not remove phone battery, until phone powers on by itself.
otherwise you need to restore secunits backup and repeat step 3 from beginning.
this is not patch unlock, phone unlock is permanent
important !
delete executor from games !
cause once user will run executor, phone will enter "5-locks" state ...
the only way to fix it - restore secunits backup and run unlock procedure again, from step 3 , no more credits required
Old 05-21-2012, 12:47   #4 (permalink)
Member: 747981
CFG:100000000000
PHONE CID: 0081
Elapsed: 17 secs.
1
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110000000000
PHONE CID: 0081
EXECUTOR.B NOT FOUND! DO STEP 1 AND STEP 2
Elapsed: 25 secs.
CFG:110000000000
PROCEDURE WAS STOPPED BY USER
Elapsed: 3 secs.
CFG:100000000000
PHONE CID: 0081
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
Insert Memory CARD into phone
Insert TEST SIM CARD into phone
POWER ON phone
After setup complete, POWER OFF phone
Then proceed to Step 2
2
Elapsed: 16 secs.
CFG:100000000000
PHONE CID: 0081
POWER ON phone
Set "USB MODE" in phone settings to "File transfer"
Copy file from card folder other\executor.b to :
C:\Documents and Settings\mahabub\Desktop\v1.1286\backup\0126110024 1205
POWER OFF phone
Then proceed to Step 3
3
Elapsed: 23 secs.
CFG:100000000000
BOOTROM MODE DETECTED
OTP DBG: [1,81,1,01261100241205]
EXECUTOR.B NOT FOUND! DO STEP 1 AND STEP 2 ????
Elapsed: 7 secs.
3 credit gone but no solve plsssss halp
Old 05-22-2012, 06:52   #5 (permalink)
Member: 1725478
CFG:110000000000
PHONE CID: 0081
Elapsed: 25 secs.
CFG:110000000000
Elapsed: 3 secs.
CFG:100000000000
PHONE CID: 0081
POWER ON phone
2
Elapsed: 16 secs.
CFG:100000000000
PHONE CID: 0081
POWER ON phone
C:\Documents and Settings\mahabub\Desktop\v1.1286\backup\0126110024 1205 ...................?????
POWER OFF phone
3
Elapsed: 23 secs.
CFG:100000000000
Elapsed: 7 secs.
brother first try again procedure
First flash and then unlock procedure after unlocking phone delete executer exe
after unlock phone on and go to menu and open game folder delete executer exe
i hope your problem solved
Br,
kashifgsm125
pls help: can not red correct cod from 7110 GURO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 08-22-2001 03:01
Need Correct Boot Loader for 8210 5.28 fls Penfold Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-23-2001 12:39
Problem with 8210, it says Insert sim card even when its inserted simbirley Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 06-17-2001 22:26
3210 - "Insert SIM", but SIM is inserted !?! MaRiN Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-29-2000 16:08
i saw 5110 5.28,5.29 prog.is it correct ? nightxyz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-08-2000 10:02
Page generated in 0.42702 seconds with 11 queries
