J108.......unlocked......success....3...credit...c ost ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100337569 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert Memory CARD into phone Insert TEST SIM CARD into phone POWER ON phone After setup complete, POWER OFF phone Then proceed to Step 2 Elapsed: 39 secs. CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100337569 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert Memory CARD into phone Insert TEST SIM CARD into phone POWER ON phone Set "USB MODE" in phone settings to "File transfer" Copy file from card folder other\executor.b to : K:\Mobile\SEtool\Main setup\v1-2.1289\backup\01261100337569 POWER OFF phone Then proceed to Step 3 Elapsed: 12 secs. CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100337569 CERT: RED Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM63 PHONE READY TO PROCEED EXECUTOR STARTED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM63 PHONE READY TO PROCEED. GOT SEED: 00506FDA ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Elapsed: 148 secs. |
another one ======================================= ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01248500488737 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert Memory CARD into phone Insert TEST SIM CARD into phone POWER ON phone Set "USB MODE" in phone settings to "File transfer" Copy file from card folder other\executor.b to : K:\Mobile\SEtool\Main setup\v1-2.1289\backup\01248500488737 POWER OFF phone Then proceed to Step 3 Elapsed: 16 secs. CFG:000000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01248500488737 CERT: RED Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM83 PHONE READY TO PROCEED EXECUTOR STARTED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM83 PHONE READY TO PROCEED. GOT SEED: 00294239 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Elapsed: 118 secs. |
