Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-01-2012, 18:40   #1 (permalink)
HAMROUNI's Avatar
Member: 749906
j108i 5 locks??
i have j108i 5 locks
i try the first ,second etap of unlocking and in the 3 etap i have
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
in this etap i'm blocked b cause phone c'read any sim card
Old 06-01-2012, 20:07   #2 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Use search button, problem has been described and solution given so many times...
Old 06-01-2012, 20:43   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
I don't think u have any solution to repair this phone with 5 locks
Sent from my X10i using Tapatalk
Old 06-01-2012, 21:09   #4 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
There is, if backup has been done.
Read this at least, post n°7 :
HOW TO WORK WITH A2-BASED PHONES
Old 06-01-2012, 21:27   #5 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
you can do it if you have back up...if you dnt have back up no solution from se tool..
same problem for me...i dnt have back up!!!
how to unlock j108 phone without s1 signature server to be online ?
a:
you need to have setool2 v1.1285 or higher.
you need to have test sim card ( with mnc/mcc 00101 ) in phone.
you need to have memory card in phone.
you need to have valid username/password with at least 3 credits.
phone should be in working state.
procedure is complicated and definitely NOT for beginners.
1.
flash any R7EA011 firmware into phone.
fully power on phone, wait until phone setup will be completed.
this is absolute requirement.
2.
run setool2, check that valid username/password entered, then go to "j108 bypass" tab.
press "upload executor package"
insert test sim card, memory card, connect powered off phone while holding "C" button
after initial procedure, disconnect phone , power on it, wait until setup complete and power off phone again.
3.
press "upload executor extractor"
set usb connection in phone options to "file transfer" and copy from memory card "other\executor.b" to setool2\backup\%imei% .
setool2 will open that folder for you in minimized state, check taskbar.
( if your system recognize phone as MTP device, you can copy file without setting USB connection to "file transfer" )
power off phone.
4.
press "unlock phone"
set usb connection in phone options to "other OS"
install phone MODEM drivers, if required ( dist\drivers\Modem_Drivers )
wait, until setool2 finish procedure.
after setool2 finish procedure, do not disconnect phone from cable, do not remove phone battery, until phone powers on by itself.
otherwise you need to restore secunits backup and repeat step 3 from beginning.
this is not patch unlock, phone unlock is permanent
important !
delete executor from games !
cause once user will run executor, phone will enter "5-locks" state ...
the only way to fix it - restore secunits backup and run unlock procedure again, from step 3 , no more credits required
Old 06-01-2012, 21:29   #6 (permalink)
khem's Avatar
Member: 269035
Sonork: 1,618,0786
if u do not delete the executor after unlocking...then it become 5 locks.......
Old 08-12-2012, 18:16   #7 (permalink)
Member: 32656
how restore secunits backup for j108a
Old 08-12-2012, 18:21   #8 (permalink)
Member: 1379587
Sonork: 100.1619552
contact me 100% solution
Old 09-03-2012, 13:02   #9 (permalink)
CHAPRAN's Avatar
Member: 31906
please ex plane i unlock 5 phone and 3 phone come back with 5 lock how it bring back in working?
Old 09-23-2012, 18:55   #10 (permalink)
Member: 245026
write back most earlier .backup script from backup\%imei%\ folder ( signed mode, put .backup in misc. edit, press "write script" )
Old 09-27-2012, 18:45   #11 (permalink)
Member: 1609777
I tried, but the process did not succeed any other suggestion?
Old 09-28-2012, 01:24   #12 (permalink)
Member: 1379587
Sonork: 100.1619552
Click Link
**** Sony Ericsson J108 5 Lock Down Fix :D 100% ****
Log
RUNNING v 1.1289/01.15/UNI
CARD SERIAL 00010963
USBFLASH DRIVER VERSION 03.00.00.00
SIGNED MODE (USING SERVER)
CFG:101000000000
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100449264 CERT: RED
LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH SIGNATURE AUTH
LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096
LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA
writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.APP_SW_1239_0125 _GENERIC_HO_REDBROWNBLUE_CID81_80_53_52_49_DB3350. SOFTWARE"
ALLOWED DOMAINS: BLUE BROWN RED
MAXIMUM CID: 81
Will flash 1009 blocks ...
ssw file accepted
writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.FS_ADRIATIC_HO_R EDBROWNBLUE_CID81_80_53_52_49.SOFTWARE"
MAXIMUM CID: 81
Will flash 2338 blocks ...
ssw file accepted
using GENERIC phone customization
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/MC_MUSIC_HOOK_3.itm
tpa/preset/custom/MC_PHOTO_HOOK_3.itm
tpa/preset/custom/MC_VIDEO_HOOK_3.itm
tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm
tpa/preset/custom/preloaded_config.xml
tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm
tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm
tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm
tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm
tpa/preset/custom/Customize.xml
Elapsed: 442 secs.
CFG:100011000000
PHONE CID: 0081
Executing CSCA-based unlock.
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
Backup security data ...
Erasing locks ...
REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM103
PHONE READY TO PROCEED.
GOT SEED: 00FFDED5
ACTIVATION COMPLETED. USERCODE RESET TO "0000"
DO NOT DISCONNECT PHONE FROM CABLE
UNTIL PHONE TURNS ON BY ITSELF
Unlock DONE
Elapsed: 83 secs.
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-27-2012 11:00
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
Page generated in 0.36120 seconds with 11 queries
