09-09-2012, 08:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | j108i unlock problem SIGNED MODE (USING SERVER) CFG:100000000001 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS): J108i MAPP CXC article: R7DA052 prg1239-0125_GENERIC_HO MAPP CXC version: R7DA052 Language Package: HUTCH-WORLD CDA article: 1248-0955 CDA version: R1A Default article: 1239-0196 Default version: R7EA011 PROVIDER: 000-00 SIMLOCKS NOT DETECTED SECURITY UNITS BACKUP CREATED. Elapsed: 14 secs. |
09-09-2012, 14:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | Two reasons: 1. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. 2. cause once user will run executor, phone will enter "5-locks" state ... the only way to fix it - restore secunits backup and run unlock procedure again, from step 3 , no more credits required |
09-11-2012, 06:57 | #3 (permalink) | |
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | Quote:
09-11-2012, 07:15 | #4 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: Dubai U.A.E Age: 36
Member: 1619775 Status: Offline Sonork: 100.1603044 Thanks Meter: 302 | Quote:
Try This Photos | |
The Following User Says Thank You to Parvez.Alom+H For This Useful Post: |
09-11-2012, 07:44 | #5 (permalink) | |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Quote:
HOW TO WORK WITH A2-BASED PHONES | |
09-26-2012, 16:16 | #10 (permalink) |
Insane Poster Join Date: Jun 2006 Location: Galway Ireland Age: 34
Member: 297474 Status: Offline Thanks Meter: 52 | USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01248500331889 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM164 Phone not responds to AT #1, retry 1 Phone not responds to AT #1, retry 2 Phone not responds to AT #1, retry 3 Phone not responds to AT #1, retry 4 Phone not responds to AT #1, retry 5 CSCA UNLOCK FAILED Unlock FAILED Elapsed: 71 secs. they take 3 credits but the phone is not unlocked.... |
09-26-2012, 22:34 | #11 (permalink) |
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | You need flash phone correct firmware. Read: HOW TO WORK WITH A2-BASED PHONES and unlock phone. |
The Following User Says Thank You to koperta4512 For This Useful Post: |
09-28-2012, 01:28 | #12 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1379587 Status: Offline Sonork: 100.1619552 Thanks Meter: 29 | FOLLOW THIS LOG EVEN IF YOU HAVE 5 LOCKS DOWN ALREADY BEEN POSTED http://forum.gsmhosting.com/vbb/f473...100-a-1520238/ Log RUNNING v 1.1289/01.15/UNI CARD SERIAL 00010963 USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) CFG:101000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100449264 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.APP_SW_1239_0125 _GENERIC_HO_REDBROWNBLUE_CID81_80_53_52_49_DB3350. SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 1009 blocks ... ssw file accepted writing "C:\Documents and Settings\Computer 2\Desktop\Sony\Flash\J108\R7EA011.FS_ADRIATIC_HO_R EDBROWNBLUE_CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 2338 blocks ... ssw file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/MC_MUSIC_HOOK_3.itm tpa/preset/custom/MC_PHOTO_HOOK_3.itm tpa/preset/custom/MC_VIDEO_HOOK_3.itm tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm tpa/preset/custom/preloaded_config.xml tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm tpa/preset/custom/Customize.xml Elapsed: 442 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100449264 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM103 PHONE READY TO PROCEED. GOT SEED: 00FFDED5 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 83 secs. |
