Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 06-14-2012, 20:23   #1 (permalink)
Member: 1105427
Sonork: 100.1613537
j108i unlocking urgentessage afther the last procedure
i had this message afther the last procedure
current updater version: 0.95
current setool2 version: 1.1287
SERVER CREDITS LEFT/USED: 4/26
CARD COUNTERS: FLASH 176, UNLOCK 79
Elapsed: 7 secs.
SIGNED MODE (USING SERVER)
CFG:100000000000
ChipID: F100, EMP protocol: 0401
PHONE DOMAIN: "RETAIL"
PHONE CID: 0081
OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01261100236488 CERT: RED
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1038]
EXECUTOR.B NOT FOUND! DO STEP 1 AND STEP 2
i did step 1 and two but as i copied the executer from card to the backup imei,i mistakenly delated all he imei's in my setool backup so i paused and identify fone and paste executer from card to imei.now this what i get when i try unlocking the fone
recv error [10054]
signature calculation not done,err: 144
Elapsed: 72 secs.
CFG:100000000000
unspecified server error [0x2746]
Elapsed: 2 secs.
credits has alredy been taken
Old 06-14-2012, 20:51   #2 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
q:
how to unlock j108 phone without s1 signature server to be online ?
a:
you need to have setool2 v1.1285 or higher.
you need to have test sim card ( with mnc/mcc 00101 ) in phone.
you need to have memory card in phone.
you need to have valid username/password with at least 3 credits.
phone should be in working state.
procedure is complicated and definitely NOT for beginners.
1.
flash any R7EA011 firmware into phone.
fully power on phone, wait until phone setup will be completed.
this is absolute requirement.
important !
do identify before unlock steps or make trim area backup.
that will greatly help you if anything will go wrong.
2.
run setool2, check that valid username/password entered, then go to "j108 bypass" tab.
press "upload executor package"
insert test sim card, memory card, connect powered off phone while holding "C" button
after initial procedure, disconnect phone , power on it, wait until setup complete and power off phone again.
3.
press "upload executor extractor"
set usb connection in phone options to "file transfer" and copy from memory card "other\executor.b" to setool2\backup\%imei% .
setool2 will open that folder for you in minimized state, check taskbar.
( if your system recognize phone as MTP device, you can copy file without setting USB connection to "file transfer" )
power off phone.
4.
press "unlock phone"
set usb connection in phone options to "other OS"
install phone MODEM drivers, if required ( dist\drivers\Modem_Drivers )
wait, until setool2 finish procedure.
after setool2 finish procedure, do not disconnect phone from cable, do not remove phone battery, until phone powers on by itself.
otherwise you need to restore secunits backup and repeat step 3 from beginning.
this is not patch unlock, phone unlock is permanent
important !
delete executor from games !
cause once user will run executor, phone will enter "5-locks" state ...
the only way to fix it - restore secunits backup and run unlock procedure again, from step 3 , no more credits required
The Following 2 Users Say Thank You to SHOEB AHMED For This Useful Post:
Old 06-15-2012, 07:44   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
good mannuls here
Unlock for Sony Ericsson J108 with setool
Old 08-07-2012, 19:05   #4 (permalink)
Member: 1794681
Sonork: london1961
system password
I`m in need of help in unlocking system password 4 a dell inspiron n5010. Thank U very much!!!!
Old 08-09-2012, 13:13   #5 (permalink)
Member: 27843
im 3 step but phone 5x closed ;/
Old 08-09-2012, 15:18   #6 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
you need restore security units backup ( put backup\%imei%\%imei%_%datetime%.backup ) in misc edit and press write script. ( enough to check only signed mode )
words from the_laser.
If you don't have security backup, phone is dead
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.24653 seconds with 11 queries
