01-10-2011, 16:23 | #16 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 921325 Status: Offline Thanks Meter: 20 | 1. Set options: - Signed mode - Perform "FULL UNLOCK" instead of "USERCODE RESET" - Disable flash mode activation for semc a2 2. select SEMC A2 3. select j10_ELM 4. press UNLOCK/REPAIR and follow instructions 5. don't disconnect phone after UNLOCK DONE, wait till phone enter in MASS STORAGE 6. disconnect phone 7. phone unlocked 10.01.2011 17:04:07 CFG:100011000000 10.01.2011 17:04:14 ChipID:F100,EMP protocol:0401 10.01.2011 17:04:14 10.01.2011 17:04:14 PHONE STATE: "RETAIL" 10.01.2011 17:04:14 FLASH CID: 0081 10.01.2011 17:04:15 OTP LOCKED:1 CID:81 PAF:1 IMEI:----- CERT:RED 10.01.2011 17:04:15 LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 10.01.2011 17:04:15 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 10.01.2011 17:04:16 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 10.01.2011 17:04:16 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 10.01.2011 17:04:16 Executing CSCA-based unlock. 10.01.2011 17:04:16 Checking for signature... 10.01.2011 17:04:16 signature found, skipping calculation 10.01.2011 17:04:16 Backup security data... 10.01.2011 17:04:16 Erasing locks... 10.01.2011 17:04:17 10.01.2011 17:04:17 DISCONNECT PHONE NOW 10.01.2011 17:04:17 REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 10.01.2011 17:04:17 INSTALL PHONE MODEM DRIVERS IF NEEDED 10.01.2011 17:04:17 10.01.2011 17:04:17 SEARCHING FOR PHONE, "STOP" TO ABORT 10.01.2011 17:05:02 PHONE FOUND AT COM262 10.01.2011 17:05:10 PHONE READY TO PROCEED. 10.01.2011 17:05:12 GOT SEED:00F32AF0 10.01.2011 17:05:13 ACTIVATION COMPLETED. USERCODE RESET TO "0000" 10.01.2011 17:05:15 Unlock DONE |
The Following User Says Thank You to diavas2007 For This Useful Post: |
10-13-2011, 08:54 | #19 (permalink) |
Junior Member Join Date: Dec 2006
Member: 412041 Status: Offline Thanks Meter: 0 | i was trying to unlock j10i2 with setool unlock done also 5 credit deduct but phone not unlocked, signed mode -perform full -disable a2 was selected what is wrong with setool tried three times. RUNNING v 1.1108/01.11/UNI CARD SERIAL 00176152 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110110000000 credits consumption for full signature unlock: S1 v1 05 credits ( OFFLINE ) S1 v2 10 credits ( OFFLINE ) S1 OPEN 05 credits ( AID 004 OFFLINE ) A1 phones 05 credits A2 phones 05 credits ( DO NOT USE FOR J108 ) S1 v2 alternative bypass 05 credits W100,W150 codes 05 credits current setool2 version: 1.1108 SERVER CREDITS LEFT/USED: 10/20 CARD COUNTERS: FLASH 51, UNLOCK 24 Elapsed: 10 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110110000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,35480804006819] OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Unlock FAILED Elapsed: 30 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 51, UNLOCK 24 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 23 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 51, UNLOCK 24 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Model (from GDFS):J10i2 MAPP CXC article: R7CA065 prg1231-1917_GENERIC_SU MAPP CXC version: R7CA065 Language Package: WESTERN-EUROPE CDA article: 1237-9393 CDA version: R6A Default article: 1229-0655 Default version: R7CA065 PROVIDER: 234-33 Network LOCKED SECURITY UNITS BACKUP CREATED. Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation server error:remote dongle not available Unlock FAILED Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM12 PHONE READY TO PROCEED. GOT SEED:00902895 ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 807 secs. SIGNED MODE (USING SERVER) CFG:100011000000 SERVER CREDITS LEFT/USED: 5/25 CARD COUNTERS: FLASH 51, UNLOCK 25 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM12 PHONE READY TO PROCEED. GOT SEED:00D5FB6C ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 91 secs. SIGNED MODE (USING SERVER) CFG:100011000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0081 OTP LOCKED:1 CID:81 PAF:1 IMEI:35480804006819 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM12 PHONE READY TO PROCEED. GOT SEED:00513F5A ACTIVATION COMPLETED. USERCODE RESET TO "0000" Unlock DONE Elapsed: 91 secs. |
10-13-2011, 09:15 | #21 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Quote:
11-22-2012, 20:34 | #23 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Romania
Member: 16269 Status: Offline Sonork: 1604924 Thanks Meter: 62 | Code: Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 359874******** CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 7/23 CARD COUNTERS: FLASH 33, UNLOCK 55 Elapsed: 2 secs. |
11-22-2012, 20:52 | #24 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | @glontz wrong settings repeat the procedure with these settings 1+5+6 carefully follow setool directives the drivers are located at setool\drivers\modem_drivers |
11-28-2012, 02:16 | #25 (permalink) |
Insane Poster Join Date: Dec 2005 Location: romania
Member: 207220 Status: Offline Sonork: adigsm2006 Thanks Meter: 8 | j10i unlock ok OTP: LOCKED:1 CID:81 PAF:1 IMEI:35480804084758 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM64 PHONE READY TO PROCEED. GOT SEED: 008D70A0 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 63 secs. |
12-26-2012, 14:38 | #26 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | OTP: LOCKED:1 CID:80 PAF:1 IMEI:35987403064451 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Unlock DONE Elapsed: 17 secs. CFG:000000000000 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
