Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > SETool2
Old 05-22-2008, 14:47   #1 (permalink)
shaheb_anl's Avatar
Member: 622382
Sonork: 100.1625873 ( shaheb )
k 800i after flash set is dead plz help
set is softwrae problem i flash this process set is dead plz help me . :::
v0.914014/UNI
Card serial:00037726
Loaded 51 flash descriptors
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
Flash ID check:2019
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A
FLASH CID:52 COLOR:RED
Model:K800i
MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI
MAPP CXC version: R1KG001
Language Package:M_EAST_N_AFR
CDA article: CDA102568/109
CDA version: R5A
Default article: cxc1250490
Default version: R1KG001
Operator: 000-00
RESTORATION FILE NOT PRESENT
"R1KG001_CXC1250210_GENERIC_WI"
YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
Elapsed:126 secs.
SERVER SUPPORT ENABLED.
Open COM port OK
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
Switching to USB...
Phone stays at current interface.
writing H:\se file\K800\cid52\r1kg001\R1KG001_1250210_GENERIC_WI .ssw
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:9200
Will flash 460 blocks...
Send subblock NAK
Elapsed:17 secs.
Open COM port OK
Speed:921600
Flash ID check:2019
Flash props sent ok
Switching to USB...
Send subblock NAK
Elapsed:15 secs.
Open COM port OK
Speed:921600
phone CID not supported in that mode
Elapsed:2 secs.
Open COM port OK
Speed:921600
Flash ID check:2019
Flash props sent ok
Switching to USB...
SSW loading returns:0
writing H:\se file\K800\cid52\r1kg001\R1KG001_FS_BALTIC_WI_RED_C ID52.ssw
SSW uses complete hash, hash len is:4420
Will flash 221 blocks...
Send subblock NAK
Elapsed:540 secs.
plz solved my problem .thanks.
Old 05-22-2008, 16:51   #2 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
use latest version and full charge ur battery
Old 05-22-2008, 17:37   #3 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
v0.914014/UNI
Send subblock NAK
r u ok man?
do as mohamed75 said
Old 05-22-2008, 19:30   #4 (permalink)
shaheb_anl's Avatar
Member: 622382
r u ok man?
what u advise plz tell me details
Old 05-22-2008, 20:40   #5 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
ARE YOU BLIND???????????!!!!!!!!!!!
Old 05-22-2008, 20:49   #6 (permalink)
Professional's Avatar
Member: 362955
open Setool exe click on support download latest version from support. For more detail go to se tool forum and watch SETOOL VIDIEO
Old 05-23-2008, 08:38   #7 (permalink)
Member: 123458
Sonork: 100.1594535
use latest version
use fully charge battery
Old 05-27-2008, 05:54   #8 (permalink)
shaheb_anl's Avatar
Member: 622382
thanks my problem solved..........
kg 195 after formet wole flash phone is dead plz help me mobiletuch LG Hardware Repair Section 2 02-16-2010 16:16
e51 after dead usb flashing set is dead HUM Nokia Base Band 5 ( BB-5 ) 3 10-29-2009 05:27
n70 after flash set is dead shaheb_anl Nokia Hardware & Hardware-Repair Area 8 09-02-2008 03:21
k 800 i after flash set is dead plz shaheb_anl SETool2 2 05-27-2008 14:24
Page generated in 0.31282 seconds with 11 queries
