12-18-2012, 13:45 | #1 (permalink) |
Crazy Poster Join Date: Sep 2010
Member: 1396906 Status: Offline Thanks Meter: 4 | k 850i problem pls someone help Elapsed: 805 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:111000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED: DE57D50C3480DA791570E134 P96 AUTH PASSED RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN DEVICE KEY: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (2) LDR: 2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED: 07F385903480DA791570E134 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR: 2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "BLUE" SIGNING ... DEVICE KEY RESTORED writing "D:\sony\v1.1294\gdfs_in_ssw_format\A2\K850\Sofia_ TA.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 110 Will flash 12 blocks ... SSW file accepted LDR: 2010-03-02 17:54 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA [startFS] can't get NET header Elapsed: 356 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:111000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 2 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:111000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED: D8AF647F3480DA791570E134 P96 AUTH PASSED RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN DEVICE KEY: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (2) LDR: 2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED: 31988B353480DA791570E134 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR: 2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "BLUE" WRITING CLEAR SIMLOCK UNITS ... SIMLOCK CODES SET TO "52047365" SIGNING ... DEVICE KEY RESTORED Unlock DONE Elapsed: 51 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:111000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED: BDE2E0D83480DA791570E134 P96 AUTH PASSED RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN DEVICE KEY: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (2) LDR: 2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED: 0160D0F23480DA791570E134 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR: 2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "BLUE" SIGNING ... DEVICE KEY RESTORED writing "D:\sony\v1.1294\gdfs_in_ssw_format\A2\K850\Sofia_ TA.ssw" ALLOWED DOMAINS: BLUE BROWN MAXIMUM CID: 110 Will flash 12 blocks ... SSW file accepted LDR: 2010-03-02 17:54 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA PROCEDURE WAS STOPPED BY USER [startFS] can't get NET header Elapsed: 157 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:111000000000 ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 GOT SEED: B2A5B6DB3480DA791570E134 P96 AUTH PASSED RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN DEVICE KEY: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (2) LDR: 2009-06-26 15:54 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A082 LDR: 2009-06-26 15:54 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A082 GOT SEED: F73867C43480DA791570E134 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE ... RESTARTING ... ChipID: C802, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35887401216599] OTP: LOCKED:1 CID:52 PAF:1 IMEI:35887401216599 CERT:BROWN LDR: 2010-03-02 17:56 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 96 LDR: 2010-03-02 17:56 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 96 WRITING SEMCBOOT ... PREPARING SECURITY ... PHONE DOMAIN: "BLUE" SIGNING ... DEVICE KEY RESTORED writing "D:\sony\se flash\k850\r1fa035\R1FA035_APP_SW_1200_4400_GENERI C_SO_REDBROWNBLUE_CID52_49_DB3150.software" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 52 Will flash 701 blocks ... SSW file accepted writing "D:\sony\se flash\k850\r1fa035\R1FA035_FS_S_ASIA_LEVAN_SO_REDB ROWNBLUE_CID52_49.software" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 52 Will flash 465 blocks ... SSW file accepted LDR: 2010-03-02 17:54 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA [startFS] can't get NET header Elapsed: 774 secs. |
12-18-2012, 14:38 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,437 | 1 write gdfs k850.zip from setool forum (sticky gdfs request thread) 2 unlock/repair (signed mode + security bypass + set domain to red (semc a2 tab)) 3 flash as usual (settings without security bypass) |
