05-22-2008, 14:40 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | k b00i after flash set dead v0.914014/UNI Card serial:00037726 Loaded 51 flash descriptors Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:2019 Flash props sent ok OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A FLASH CID:52 COLOR:RED Model:K800i MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI MAPP CXC version: R1KG001 Language Package:M_EAST_N_AFR CDA article: CDA102568/109 CDA version: R5A Default article: cxc1250490 Default version: R1KG001 Operator: 000-00 RESTORATION FILE NOT PRESENT "R1KG001_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK Elapsed:126 secs. SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok Switching to USB... Phone stays at current interface. writing H:\se file\K800\cid52\r1kg001\R1KG001_1250210_GENERIC_WI .ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... Send subblock NAK Elapsed:17 secs. SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok Switching to USB... Phone stays at current interface. writing H:\se file\K800\cid52\r1kg001\R1KG001_1250210_GENERIC_WI .ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... Send subblock NAK Elapsed:15 secs. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A FLASH CID:52 COLOR:RED phone CID not supported in that mode Elapsed:2 secs. SERVER SUPPORT ENABLED. Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35170701606929 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:2019 Flash props sent ok Switching to USB... Phone stays at current interface. writing H:\se file\K800\cid52\r1kg001\R1KG001_1250210_GENERIC_WI .ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 writing H:\se file\K800\cid52\r1kg001\R1KG001_FS_BALTIC_WI_RED_C ID52.ssw CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:4420 Will flash 221 blocks... Send subblock NAK Elapsed:540 secs. plz solved my problem.thanks |
nokia 5300 after flashing set dead | san9090 | Nokia Base Band 5 ( BB-5 ) | 8 | 07-02-2010 12:51 |
i flashed lg b2060 ....after flash set dead..help. | Rin2 | Infinity-Box | 2 | 03-21-2010 06:01 |
S3 after flash set dead | umesh garg | Infinity-Box | 3 | 08-29-2008 19:49 |
6110n after flash set dead | woreal.gsm | Nokia Base Band 5 ( BB-5 ) | 4 | 05-28-2008 18:48 |
P910i after flash set dead :( | GSMBALOCH | Cruiser Suite | 3 | 03-30-2008 19:00 |
